Valve Body Explorer Forum discount!! | Ford Explorer Forums
sean99
Sunnyvale, California
01 Limited 5.0
I sent my valve body to Central Valve Body to have it tested because of my 2-3 flare.I had them add the Sonnax master inplug kit with o-rings and an elevated pressure spring to bring it up to spec.everything else tested out fine.Donny at Central agreed to offer a discount for us.Just mention explorerforum.com when you call to get these these prices.
Valve body test $49.99
Rebuild service $119 plus parts
Off the shelf rebuilt valve body with Sonnax upgrades and a new separator plate with a 12 month unlimited miles warranty.$229
He said the Sonnax upgrades are:
Large ratio boost valve & sleeve
Elevated pressure spring
Master inplug kit that have o-rings on them.
I think only the parts that don't fall into spec. are replaced on the rebuilt v.b.'s
Here is the number 1-877-341-0266
I installed the valve body yesterday and the transmission shifts great!!!
I also installed the pressure riser that I left out the first go round.
Sounds like a good deal. Thanks for passing on the info.
Good info. Thanks.
Is there a section on this site for group buys and forum discounts?
Did the trick for me too! Even had a local tranny shop tell me I needed a total rebuild. Had the shift flare & the P0732 - P0735 codes. All gone now. Thanks to Donny @ Central Valve Bodies!
That is a very attractive price for a rebuilt VB.
