Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Drivers side front door latch for 97 Explorer
Reply
Thread Tools
Old 05-21-2007, 05:30 PM   #1
dantes990
San Francisco, CA
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I need to replace mine and have a couple questions:
- on a 4 door, are the front and rear door latches different? Ebay has some rear door latches but no fronts.
- do any other models such as Ranger use the same door latch?
- anyone know where I can pick up a used latch?
A spring broke in my latch which causes intermittent door lock problems. Sometimes I can only unlock the door by using the inside handle. Not a huge deal, and I would prefer to find a used latch as the dealer wants $60 for a new one.
Any info is appreciated.
dantes990 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-21-2007, 05:34 PM   #2
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
The latch is probably not the same as the ranger, you can try a few of our used parts vendors..
Ped5Stang
http://www.explorerforum.com/forums/member.php?u=14280
Kbabiak
http://www.explorerforum.com/forums/member.php?u=44601
Blee1099 is offline   Reply With Quote
Old 05-21-2007, 07:35 PM   #3
MONMIX
I fix dents
Millersville , Maryland
MONMIX's Avatar
2000 Explorer Sport
Vehicle Specs
Quoted: 78 Post(s)
front and rear ARE different
ranger and explorer have different part numbers
A junk yard would be a good possibility, however most will not sell just the latch but a complete door
$60.00 for a brand new OEM latch is quite reasonable.
__________________
MONMIX
ASE certified Master Collision Repair Technician
I-CAR Certified Platinum Structural Technician
Live your life for a change
My Explorer
MONMIX is offline   Reply With Quote
Old 05-21-2007, 07:58 PM   #4
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 211 Post(s)
I paid $10 for my LF at a local yard. All four are unique, I swapped all of my new latches into my 91 and 93 doors. You need a 95-01 latch for the 97. I told someone else here how to do that, was that you in a different thread?
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is online now   Reply With Quote
Old 05-21-2007, 08:56 PM   #5
dantes990
San Francisco, CA
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
No, wasn't me. Any tricks I should know before diving in? I tried searching for info on replacing door latches, but didn't come up with much.
Old 05-21-2007, 10:40 PM   #6
nolimitssjca
San Jose, CA
95 XLT, 96 XLT, 97 Mounty
Vehicle Specs
Quoted: 2 Post(s)
Dantes, It's good to see another Northern CA user here.
The Door Latches are pretty straight forward. Just pay attention to what you take off so you can put it back on.
You can definitly use a tool for pulling the door panel.
__________________
1995 4WD XLT 4.0 OHV 263k (sold)
1996 AWD XLT 5.0 160k
1997 AWD Mounty 5.0 123k
2002 Kawasaki Vulcan
1990 Four Winns 200 Horizon
nolimitssjca is offline   Reply With Quote
Old 05-21-2007, 10:54 PM   #7
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 211 Post(s)
Check out this other thread where I posted for another.http://www.explorerforum.com/forums/...90#post1673090
If you are sure that you need a whole latch, find the replacement first. Reaching into the door to remove all of the linkages for the latch is the hardest part. Take your time and remember where those linkages all go. I learned the trick about this window guide recently.
The task is a bunch easier if you spend the 45 seconds that it takes to remove the glass guide bar. Also take your time with the yellow locking clip which holds the door handle link on. Look at the replacement part carefully. That yellow tab/arm is very easy to remove with pressure at the proper point. Learn where that is before diggin in there with so little room and lack of view. Good luck,
__________________
Don
Old 05-22-2007, 01:28 AM   #8
dantes990
San Francisco, CA
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Cool, thanks for the tips!
Old 09-26-2007, 10:01 PM   #9
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'98 TJ Sport
Vehicle Specs
Quoted: 1 Post(s)
Well, I just fixed the problematic internal return spring on my drivers side door latch. Unfortunately my interior door handle broke before I got a chance to fix it, so I gotta head over to Ford tomorrow and get one.
We'll see how long that dinky little spring lasts. I figure it made it 139.5k miles and 9.5 years, maybe it'll make it a little while longer
Once again EF and more specifically - the search button - saves the day
Elite fees pay off once again!
__________________
Brett
I get paid to play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 09-27-2007, 02:31 PM   #10
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'98 TJ Sport
Vehicle Specs
Quoted: 1 Post(s)
Another reason I love driving a Ford Explorer-ish vehicle...
New driver's side interior door handle
at dealer: $33
Advance Auto: $10.65 out the door Its actually one of their Help! items b/c the D/S handle breaking is that common among explorers
__________________
Brett
Old 09-27-2007, 02:41 PM   #11
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 211 Post(s)
Those handles are left and right, passengers seem to rip the back ones off. I have heard as little as $13 for them at Ford. My friend bought two recently for just over $30 for the pair.
__________________
Don
Old 09-28-2007, 05:37 PM   #12
Space Truckin'
North Texas
'98 Exp XLT 4.0 SOHC 4WD
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Originally Posted by dantes990 View Post
...the dealer wants $60 for a new one.
Try another dealer. They don’t all charge list prices. I recently paid $34.50 when I replaced mine. (Ford P/N 6L5Z*7821813*C) The new revised latch eliminates the earlier flaws like that #!%*& little spring that breaks.
Space Truckin' is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
