Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Air bag readiness light flashing code 37
Reply
Thread Tools
Old 11-25-2007, 08:16 PM   #1
Glock40cal
St. Charles, Missouri
00' XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2000 Explorer XLS 4.0L V6 OHV 4x4 with 71,100 miles that just started flashing the Airbag readiness light at me. Sequence is 3 flashes pause 7 flashes pause then it starts over again. It does this for about a minute then the light stays on. I assume that the code is #37 but i can not find any air bag codes on the net. Anyone else have this problem?
__________________
2000 XLS 4X4 4.0L V6 OHV
Glock40cal is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-25-2007, 08:59 PM   #2
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
LFC 3-7 is for an improper voltage level in the side airbag on the passenger side of your Explorer. This could be caused by a short to ground or, more likely, a high resistance connection between the Restraints Control Module and the PS side airbag assembly.
Even if your truck doesn't have the optional side airbags, it still has the wiring for them and uses a yellow resistor cap to simulate the side airbag. Same story - probably a poor connection at the RCM or at the resistor cap under the passenger seat.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
rwenzing is offline   Reply With Quote
Old 11-25-2007, 09:27 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
This is a common problem on these vehicles. Try to clean the yellow connector, and see if the code goes away. It doesn't always work for everybody, but it's worth a try.
BrooklynBay is online now   Reply With Quote
Old 11-25-2007, 09:27 PM   #4
Glock40cal
00' XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Rwenzing and Brooklynbay thank you. When i read your post the first thought that came to my mind was that when i took my daughter out of the back seat her sippy cup had rolled under the passenger seat.
I just went out to take a look and sure enough i found a yellow wire harness connector hanging down from under the passenger side seat. Must have been a bad connection because the light does not come on anymore. Got it nice and secured and out of the way now.
Thank you both for your help. Theres no telling how much agrevation and money you saved me.
__________________
Old 11-26-2007, 10:11 AM   #5
ThePhoenix
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
i get a lot of those codes as i am always moving passenger seat in my sport....but atleast I know what causes it
Old 11-26-2007, 10:13 AM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Thanks for the update!
Old 03-27-2009, 05:14 PM   #7
rickpotz
Utah
2000 Sport
Vehicle Specs
Quoted: 0 Post(s)
Just wanted to add some information.
I have a 2000 Ford Explorer Sport.
I also had an airbag light problem and a 3 7 code.
It was exactly what was mentioned above. A loose connection.
Both the passenger and driver seats have a yellow connector.
The passenger side connector was loose. I disconnected and then reconnected it. I also taped the connector to the bottom of the seat.
On the passenger side foot compartment, there is a kick panel which I removed. Behind the kick panel is a module and other wires. I pushed them in.
As I ran the car and tied to tighten the connection, the light stayed on but when I turned the car off and restarted the car. My airbag light went off and stayed off. I tried to tape all the wires and connections in place so that they would remain stable.
Hope this helps others that have the same problem.
rickpotz is offline   Reply With Quote
Old 02-12-2012, 11:08 PM   #8
lnfar39
Vehicle Specs
Quoted: 0 Post(s)
Thank you for the information..failed inspection and was so frustrated...this forum helped me and my husband figure out the problem...my husband said forums like this is so helpful to us consumers..
lnfar39 is offline   Reply With Quote
Old 12-05-2014, 05:43 PM   #9
Ford madness
Richmond BC
2001 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
I have the same trouble code on my 2001 Sport. I removed the passengers seat to facilitate changing the body mounts and found the white wire was completely broken off right at the airbag sensor. There's no way to reconnect the wire. Has anyone else had this broken wire problem? Can you buy a new sensor with pigtail wire attached or do you have to buy the whole wiring harness?
Ford madness is offline   Reply With Quote
Old 12-06-2014, 07:27 AM   #10
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 350 Post(s)
Very easy get one from a salvage yard, or on the classified ads here. Splice it in and you should be golden.
drdoom is online now   Reply With Quote
Old 12-06-2014, 10:57 AM   #11
Ford madness
Richmond BC
Vehicle Specs
Quoted: 0 Post(s)
I never thought about a salvage yard. Thanks. I'll give that a try.
Old 05-12-2015, 01:28 PM   #12
whataman00
Houston, TX
2000 Ford Explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
US A late thank you...
Thank God for this forum! I bought my Explorer used last year and I love it! However, I don't know how much I'd love it if not for this forum! I am having this airbag light issue right now, and I am so excited to solve another small problem thanks to this forum! Thank you all!
whataman00 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
