The infamous OHV 4.0 rattle, tap, tap, is indeed the lifters! | Ford Explorer Forums
Kyle0614
Greenville, NC
'95 XLT
hi all just letting everyone know that i took my truck to the mechanic today and the infamous rattle tap tap top engine noise is indeed the lifters..
i'm going to be replacing my lifters, rocker arms, and pushrods whenever i gather up some moohah...
anyways hopes this helps all the OHV's on this site...
Happy Explorations!
and BTW Happy New Year 2008'
BTW ...if any of you know how to change these items...all info/detailed work involved is much appreciated
i'm only basic tool knowledge/how to so SLOW english please lol
have a good day...Kyle
Kyle,
First of all, upper valve train noise does not necessarily mean a problem exists. My 1992 ohv (in the 10 years I owned it) had EXTREME use…. Because of work it would idle 2-3 days at a time, averaging this type of service every two weeks. I can guarantee the amount of engine hours this vehicle saw will rival >500k miles of driving. The valve train was “noisy” but from what I witnessed this is inherent to the engine. My motor never burned oil or had any leaks. I would suggest getting a second opinion. Hydraulic lifters are by nature “noisy”.
Good luck. The ohv is one extremely tough and long lasting engine.
Drake
The tap usually does mean worn lifters, but it's not a huge deal. Mine has done it for a couple years, hasn't gotten worse, doesn't make a difference on anything. Just annoying, that's all. Say, I gotta ask, why did you have to idle for 2-3 days at a time for?
I was able to quiet mine down using 5w-20 synthetic oil. So far its been about 2000 miles since the oil change and its still quiet.
Dan
Agreed lifter noise is normal. Geologist…when out on the drilling rig, my truck is my home (I sleep in it) and it NEVER shuts off, winter, summer it does not matter. It is common practice and FORDS rule the American oil field…..period:us:
Man that's gotta be rough on the gas bill
Yes, but actually a day worth of idling will burn about a ¼+- tank of gas. Plus I’m not paying for it.:D
Not as bad as I thought it would have been, helps when your not paying though.
Alright, I'm done
[/hijack]
ok let me be more elaborate, 95.9% of the time it's usually going to be worn lifters...
is this just and can this cause un-angled incorrect arms and a couple of bent pushrods?? i'm going to replace all three hoping this sound will just dissapear lol it is really driving me bonkers but got to get some moohah first :( found a rebuilt set of lifters on ebay for $90 dang thats good deal but i have no cash to spend shucks
when I bought my Limited, well, about 9 or 10 years ago lifters made noise - I took it to the dealer and they told me it's OK - some trucks will do that... so I kept on driving and now after 100,000 miles it still makes that same noise - lifters tap tap... especially when cold.
some things we just have to get used to...
After looking at two motors that I've taken apart recently I have noticed that the rocker arms seem to take the most abuse, not the lifters. I re-used the lifters from my old motor (355k+ miles) and put on new rocker arm assemblies and pushrods from DeltaCam.
I also looked at a lower mileage motor (< 150k miles) and it also had wear on the rocker arms. It seems the tips of the rocker arms wear (push in) which increases the clearance.
I'd start with replacing just the rocker arm assemblies and pushrods before going after the lifters as they can be done with just removing the valve covers. To remove the lifters you have to pull the heads which is quite a bit more work..
I have a few rocker arm assemblies (at least for another couple days) from high mileage, medium mileage and very low mileage (but installed on a bad head) that I can take pics of it you need them.
~Mark
oh wow just the person i was looking for
could you by any chance explain in detail what is involved with installing the lifters, rocker arms and push rods
thank you.......Maniak
The rocker arm assembly and pushrods are easy to do.. You only need to remove the valve covers to get to them. On the 1st gen X you need to remove the coil pack to get the passenger side valve cover off.
Once the covers are off there are 3 bolts that hold on the rocker arm assemblies.. Just take them off and once off pull out the push rods..
there really ins't anything special for removing the pushrods/rocker arms..
When installing the rocker arms it is a little tricky getting all the pushrods in the little cups of the rock arm assembly but once you have them all on you torque down the rocker arm assembly bolts to about 50ft lbs BUT DO IT IN PHASES... e.g. 15lbs on all 3, then 25lbs etc..
Now the lifters are another story.. To do this just following the instructions for pulling the heads.. Once the heads are off you can just lift out the lifters.. Its not a "hard" job to do, but you are pulling off the plenum, fuel rail, lower intake, a/c bracket, alternator + bracket and some other parts.. I've done it a few times and it takes me almost 3 hours to pull the heads. Keep in mind, I'm in Arizona and don't have inner fenderwells so pulling the exhaust from the heads is easy for me to do.. If they have never been pulled OR your in the rust belt, its gonna take longer..
Lemme know if you need any other info
~Mark
Good to know. I help run adventure races and if I'm manning an overnight checkpoint when it's really cold or really hot, I like to idle the whole time, too. I've done this at rest stops as well when I'm driving late at night and just need to catch an hour or two of sleep.
My 2000 Explorer OHV engine rattles but under the bottom passenger side the noise is most prevalent. I have an itchy feeling it's something else besides the rockers, etc.
Ideas are welcome. I WISH mine were rockers but I don't think I'll get that lucky.
KT
Wow...reviving the dead! But if the noise is on the bottom of the engine, it's not valve train noise. Anything in the crankcase making noise is not a good thing...
mine makes a tap tap noise on start up sometimes as well mainly on colder days and is coming from the bottom passenger side. But it goes away once the engine warms up and wont do again until it had sat over night and cooled all the way down. Still don't know what is going on.
It's not hurting ANYTHING...my 2.9L 1988 Ranger tapped like a SOB for 100,000 miles (and it went for 273,000 miles).
My 1994 Jeep Wrangler 2.5L tapped for 70,000 miles.
Easy fix, though, if you don't want to hear it.
There's a company (?) that manufactures heat-treated pushrods (at the tips)...much more durable...the Cologne V-6's have ALWAYS had poor oiling at the tips of the pushrods, wearing them out prematurely.
I've wanted the pushrods with heat-treated tips for a long time, might go ahead and do it if the rockers and pushrods can be replaced just by pulling the valve covers. Not so much for the noise as for performance. Pretty sure the deformed tips on the rods and the wear on the rockers result in the valves not opening as much as they could.
Anime, I would imagine there's a lot of truth to that...the heat-treated pushrods aren't that costly, either.
