Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
10 Second Temporary Fix for Blend Door Actuator Problem...
Reply
Thread Tools
Old 02-01-2008, 07:06 PM   #1
eqppwqqep
Jackson, TN
2002 4WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I got sick of driving in the cold today, so I decided I would figure out this blend door garbage. Mine is stuck blowing cold air, and knocking under the dash (front end HVAC only). This basically helps it shut either way so you get all cold or all hot air. But it will sure fix me until I get the part ordered next week.
Unhinge glove box
Swing glove box all the way out
Turn off the blower and set the temp gauge to where it is clicking. You want the blower off so you can feel the thumps as those will lead you to the door hinge.
Reach directly into this spot and try to go STRAIGHT down from there. Basically I was wrist deep into this cavity before I hit the door hinge.
There is the blend door hinge opposite of the actuator. If it is clicking when you try to get to it, you WILL feel this thing bouncing up and down on that sensor. Just push it the appropriate way to get HEAT/COOL.
This is obviously on the passenger side of the car. If you were to access the driver side similar to this, you would have your hand on that piece of crap actuator.
This should get you by until you get that part ordered. If you have an Oreilly's Auto, you can get part #604202, which is the correct actuator for the front HVAC on the 2002-2005 Explorers. I also think it fits the 01 as well???
eqppwqqep is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-01-2008, 07:16 PM   #2
eqppwqqep
Jackson, TN
2002 4WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
For those of you wanting to know where this POS actuator is, here is a pic from the outside:
It's a ghostly white (think glow in the dark plastic), so you should be able to spot it if you pry back the bottom console cover by the gas pedal (long lower plastic of console, no screw down there). You will also be able to hear it as it was apparently designed in the Borean by diseased orangutans that lack dexterity...
Old 02-07-2008, 09:19 PM   #3
dr0pthehammer
NW PA
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for this great post! My blend air door has been going on the fritz for the past few weeks. Started out with the annoying clicking sound (but still yielding heat), then progressed to other more pronounced bad sounds.
For awhile it would blow cold air then after a while if i played with all 3 knobs enough I would hear that hollow thunk and get some heat.
As of last Friday I haven't been able to get any heat at all... All the cold, frigid air I wanted from any vent or at any fan speed. The clicking is constant, the only way to get it to stop is to turn the center (blend air) knob all the way cold.
Today was the last straw... I was froze on my 26 mile drive home from work. When i pulled into my 50 degree garage, all the windows instantly fogged!
So i started researching on here and found your post...
So i went for your temp fix with a twist. Dropped the glove box and felt around in the area you indicated looking for the blend air hinge. Also removed the trim/panel around the stereo. In there i could see the right hand AC knob control doing its thing... upon turning it, i could see its actuator doing what it was supposed to.
Could not find the blend air door actuator hinge so i turned it from cold to hot to get it clicking. Then i found it by feel and flipped it back for heat. It kept trying to close back up on me. The linkage must still be somewhat intact because turned all the way to cold i cannot manipulate the door. Turn it to hot and it clicks and can be flipped open.
I'm not sure if my twist will work or not, but what i did was turned it to hot, flipped it door to heat position then while holding it, turned off the ignition. It seemed to hold in place, we'll see. Then, I unplugged the center/blend air control knob wire harness. (Wanted to unplug the actuator but could not get to it easily enough without the complete tear down.)
When i turned the ignition back on i still heard the clicking for a little bit. Didn't hear the door flip back shut, but it may have...
dr0pthehammer is offline   Reply With Quote
Old 10-20-2008, 12:51 PM   #4
dr0pthehammer
NW PA
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
UPDATE:
Shortly after the above post I found out that the door flips back shut upon turning the car off.
I had removed most of the center console at that time in an effort to change out the actuator. I was able to get in there and attach a long zip tie around the door lever, the tag end of the zip tie hung out in the console where the forward storage bin had been removed.
So when i turn the car on, i could turn the knobs to heat and reach down to pull the zip tie and actuate the door to allow heat to flow. The fan had to be turned up to at least 2 to provide the suction or whatever to hold the door to heat position. If I turned the fan back to 1 or minimum, the door would flip all the way back to close off the hot air.
So that got me thru the rest of winter satisfactorily, and i was somewhat content to leave the center console half torn out until this past weekend! Now going back into winter again, I am getting around to fixing it correctly.
I removed all of the console screws and bolts, as per the manuals posted on here elsewhere, but something else was holding it firmly in place. I gave up on the project once i got the zip tie workaround in place. Over this past weekend i cleaned out the vehicle and decided to finish the job. I found 2 more screws that were not called out in the manual and removed them. Then the console came out completely.
Today at lunch i picked up the new actuator for $70 at the local dealer. Now i just need to come up with a plan of attack for removing the 4 actuator screws and changing out hte module. Looks like a very tight space to work in... hopefully i'll be able to get to some of them with a 12pt 8mm wrench. Perhaps a gear wrench with a slight offset would be best.
I'll update on how the battle goes.
Any advice/tips/tricks on how to perform the change out will be most welcomed.
Old 10-21-2008, 06:36 PM   #5
Sleb
MB
03 XLT
Vehicle Specs
Quoted: 1 Post(s)
its all here http://www.explorerforum.com/forums/...d.php?t=198271
Sleb is offline   Reply With Quote
Old 11-24-2010, 04:19 PM   #6
texanbred
Fort Worth, TX
'03 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thumbs up
I know this thread is old but I just want to say thanks for posting this temporary fix. My air conditioner has been clicking for a couple of years now and I just learned to ignore it until I lost heat a few weeks ago (just in time for fall in Texas) and needless to say I don't do well in the cold. Just to let you know I am a girl and I can fix pretty much anything as long as I have enough information and determination to do it, and the 44 degree forecast was determination enough! Anyway, I temporarily fixed my actuator door hinge until I can get the motor replaced and it's wonderful to have heat again. Thanks again, you were a great help!
texanbred is offline   Reply With Quote
Old 11-24-2010, 07:07 PM   #7
D Hook
Omaha, NE
06 Explorer Limited V-8
Vehicle Specs
Quoted: 68 Post(s)
I had to do the same on my '98 Mark VIII to get heat because changing the blend door involves pulling the entire dashboard 6" away from the windshield and I just haven't worked up the guts to do it yet. So, after 5 years, I still have a piece of black sash cord hanging from the bottom of the dash to pull when I need heat. Classy! Fortunately, it seldom leaves the garage except on nice days.
__________________
2010 Expedition Limited LE --wife's DD & boat hauler
2006 Explorer Limited V8--Replaces the '02
1998 Mark VIII LSC--AKA Barca lounger on wheels. For Sale!
*Registered Smart Ass in all 57 states
D Hook is offline   Reply With Quote
Old 11-24-2010, 08:25 PM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Welcome to the forum!
Here is a step-by-step, with pictures, for replacing the blend door actuator: http://www.explorerforum.com/forums/...d.php?t=294140
Hope this helps out!! Good luck with the fix.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 11-25-2010, 01:04 PM   #9
texanbred
Fort Worth, TX
'03 XLT
Vehicle Specs
Quoted: 0 Post(s)
Just looked at your pictures...umm, that's a lot of fix for such a small part. Oh well, guess I know what my first project will be once the weather warms up. Thanks for the detailed information and great pics!
Old 11-26-2010, 04:04 PM   #10
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
You're welcome. Good luck with the fix. Keep us posted.
__________________
Old 02-14-2011, 10:52 AM   #11
isobarzo
Naco, Arizona
'05 4x4 xlt
Vehicle Specs
Quoted: 0 Post(s)
Thanks for your post!!!!!!! I closed the blend door in little more than 10 seconds. (maybe 20 sec.) 'till I feel on my finger wich way to push the handle.
The clicking noise still there but if you move the selector back to little bit before the hottest range, it will stop.
I found the actuator by rockauto.com at $ 41.00 including postal fees.
2005 ford explorer with manual controls use part Number 604-209
Maybe you not understand but here in southern arizona is very cold this winter.
Thanks again.
isobarzo is offline   Reply With Quote
Old 04-03-2011, 08:21 PM   #12
texanbred
Fort Worth, TX
'03 XLT
Vehicle Specs
Quoted: 0 Post(s)
It's me again, the girl from Texas with the broken actuator motor. Well I spent the past winter flipping the door hinge every time I got in my Explorer - which got very old, very fast. So today, in 80 degree weather, I did what I said I was going to do and I replaced my actuator motor! It took me twice as long as it took BigRondo, but that's probably cause I really didn't know what I was doing. However I must say, BigRondo, that the instructions and pictures were perfect - thanks again! I now have heat and it feels so good.
Old 11-17-2011, 02:07 PM   #13
tk1251k
1994 2005
Vehicle Specs
Quoted: 0 Post(s)
Same problem here with 05 blend door. I found a way to keep the door in the position you want it cold or hot until you change. AS others have stated quite well and shown pics of the pass. side handle which you can feel trying to move. When I get it in the position I want for hot or cold I take a piece of aluminum foil wadded up about the size of a baseball or just alittle smaller.Reach your hand the wadded foil with heat or a/c on and push down inside where the handle is trying to move. By placing it onto the handle with a small amount of pressure it will stay until removed. Mine has been there all summer and last winter. I think I will soon replace my acutator but this has been a good fix for now.
tk1251k is offline   Reply With Quote
Old 11-17-2011, 03:07 PM   #14
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
When you are ready to replace the actuator, here is a step-by-step, with pictures, for replacing the blend door actuator: http://www.explorerforum.com/forums/...d.php?t=294140
__________________
Old 11-20-2011, 05:50 PM   #15
26fan
Kansas City, MO
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Hey everyone. I have been reading these threads on this blend door for almost 24 hours and am hoping to have maybe a little more specific help.
Last night, after turning on my car, I heard a few loud sounds and then a constant, quieter, clicking....and no heat. My boyfriend and I (neither of us being very mechanically inclined), went out and tried to do this quick fix. And we are stumped. We thought we found the hinge to flip to heat, but nothing. Then he reached his hand in even farther and did something to where the clicking got quieter, but still, no heat.
Those pictures up top were helpful, but we're just wondering what exactly the hinge we're looking for looks/feels like. Does the silver bar that moves when you turn the blowers on and off have any bearing on it? Is this hinge deep in the cavity?
I think I can replace the actuator, but right now I am really just wanting a quick fix until I can get the replacement actuator, and the time to replace it.
Its gonna be a cold winter here in KC for my six year old daughter and I! Any help would be greatly appreciated!
Monica
26fan is offline   Reply With Quote
Old 11-21-2011, 01:06 AM   #16
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Monica
When you gently reach in behind the center dashboard area with your right hand/fingers thru the glove box opening, reach in at a slightly downward angle and feel for the hinge lever flipping up and down. The lever is trying to go upward, but you want to flip it downward for the heat side of the system. Get your finger (preferrably the infamous middle one and the longest) in behind the hinge lever and push it downward with a little bit of force and you can actually feel the weight of the blend door itself, rolling over to the hot side of the system, almost like pushing open a weighted door. Once you flip the hinge downward, it should stay there, but if it bounces back up, just flip it down again till it stays down. You do this with the vehicle turned on and the temp knob set to the hot temp side. The clicking or clunking noise starts up when you spin the temp knob to the hot side. The noise will stop when the blend door has been flipped over to the hot temp side and you will hear a distinct difference in sound coming out of your defroster vents when the heat starts to flow thru them. Once you get this done, don't adjust the temp setting knob, leave it be. Another tip, when you start the vehicle up each and every time, turn your blower fan speed to it's highest setting #4, prior to starting the vehicle. This should help keep the blend door from falling back over to the cold side. The force of blower air keeps the blend door from flipping back to the cold side during start up. It worked for me. Below is the repair post web link for the blend door actuator, when ordering the new actuator from Ford (approx $80-$90), use your VIN number, good luck.
Blend Door Actuator repair link below, give thanks to "BigRondo" for the repair post!
Exproblems is offline   Reply With Quote
Old 11-21-2011, 08:06 PM   #17
26fan
Kansas City, MO
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for your reply! I went and messed around for it for an hour or so tonight. I can feel what I believe is this hinge (I can feel the vibrating of the clicking), however it doesnt feel like a hinge. It feels like some kind of bolt with a hole on the end of it. I was using my fingers and the leverage of a screw driver, and when I put a lot of pressure on the screw driver, against the very tiny width of the "hinge", the clicking would almost stop, then the screw driver would slip and I could hear the door flap, then itd go back to clicking. At one point the clicking stopped....but no hot air.
Is this what the "hinge" is supposed to feel like? Any other ideas (besides replacing the actuator, at this time)? Being able to see my breathe while driving to work this morning was no fun!
Old 11-22-2011, 01:00 AM   #18
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quoted: 85 Post(s)
It's not exactly a "hinge" for lack of a better word, but close enough. It rotates up and down like a hinge. You can call it a lever, arm, post, tab etc. You can feel it moving up and down with your finger. Do not use a screwdriver! You may break something back there or short out some other electronics. Just use your fingers, that is all you need to do this. Slide all four fingers in of your right hand at the same time and use your middle finger to feel for it, it is the longest finger. Just like in the photos of the temp fix, up to your wrist your hand should go, depending on the length of your fingers. Get your finger behind the arm that is flipping up and down and push/flick it downward with a little force, it should flip downward and stay in the other position. Do this while the engine is running and the temp control knob is set to heat and defroster, but keep the fan speed on low at this time. Once you do this, you should get heat thru the defroster vents, if still no heat after doing this and the clicking sound has stopped, you may have another heat related problem going on besides the blend door actuator issue. Some Ex's have heater core valves on the passenger side valve cover area under the hood that go bad blocking coolant flow to the heater core. I did this temp heat fix on my Ex so many times prior to repairing the actuator I could do this temp fix in less than 30 seconds. It took me longer to un-hinge the glove box and roll it out of the way than it takes to flip this blend door tab.
Old 11-25-2011, 08:35 PM   #19
D Ryan
St. Louis MO
Vehicle Specs
Quoted: 0 Post(s)
The part that rotates up and down! Could this be part of the blend door or maybe its axel?
The door that actually moves from open and closed position! Does it swing direction simulate that of a door in your home( virtical), or a trap door ? (horazontal)
The part that moves up and down is it doing this because its broken?
Does a heater in working order also go up and down?
D Ryan is offline   Reply With Quote
Old 11-26-2011, 02:42 AM   #20
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quoted: 85 Post(s)
[QUOTE=D Ryan;2853028]The part that rotates up and down! Could this be part of the blend door or maybe its axel?>>>>>>>>>>>>>>>>>>>>>
I'm assuming it is some how connected to the blend door itself because when you flip this arm/hinge that is going up and down behind the dash, it rotates the blend door itself into the position you want it in which is hot or heat.
>>>>>>>>>>>>The door that actually moves from open and closed position! Does it swing direction simulate that of a door in your home( virtical), or a trap door ? (horazontal)>>>>>>>>>>>>>>>>>>>>>
The blend door doesn't open or close, it just switches from the cold side of the system to the hot side of the system. I can't remember if the blend door sits in the horizontal or vertical position, but if you go look for the "Heater Treater" ad in here, you can see a cut away picture of the blend door inside the blend door box and how it sits in there.
Does a heater in working order also go up and down?>>>>>>>>>>>>>
The part behind the dash that is moving is not what is broken. What is broken is the small gear/teeth inside of the blend door actuator. The actuator is what needs replacing. The arm/hinge that is moving up and down is just the thing you need to grab with your finger to manually flip the blend door over to the hot temp side. No, the heater core does not move up or down. The blend door when switched to the hot temp side, just allows the flow of hot air coming from the heater core and then thru the dash vents.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
