Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Bulldog Remote Starter Installed!
Reply
Thread Tools
Old 02-09-2008, 06:16 PM   #1
bigapple
Baton Rouge LA
'02 XLS Touring
Vehicle Specs
(Original Poster)
i apologize for not getting pictures of the install where i spliced the wires but it was easier than i had thought... i had ordered a wiring harness to plug into the ignition harness in early november and it has been opn backorder for 3-4 months... i said screw it and just decided to check out the directions and see if i could manage... everything happened to be in the ignition harness rite there so i simply tapped into those and hooked up the necessary wires... u can see where i tapped into them in the steering column... theyre wrapped with yellow electrical tape... the first shot is of the security bypass for the PATS system so i can start from a distance... u have to put a factory key in the module to get a signal that it transmits... works like a charm... btw i already have the fusion key for lock/unlock so i simply use the new one for start/stop to prevent me from having two key fobs
i put this module behind the dash cover that is removed in this picture... it snugly fits into the hole rite there under the long black bar
__________________
2002 Ford Explorer XLS "Touring Edition"
Custom leveling springs from coilsprings.com, Bulldog Remote Starter, Flowmaster 40 Single with Magnaflow 3 1/2'' Chrome Tip, Custom CAI, Hunter Grille Guard, XLT bumper swap, 2 KC Fogs, 2 Small Projector Running Lights, Krylon Fusion Gloss Black Repainted Trim, LED Dome Conversions, LED Reverse Light Conversions; Silverstars: 9006, 9005, 3157/turn signals, H3 runners/Fogs (x4)
bigapple is offline   Reply With Quote
Old 02-09-2008, 08:18 PM   #2
asimp
Bardstown, KY
04 Limited
Vehicle Specs
What kind of distance are you getting out of it?
__________________
Aaron
asimp is offline   Reply With Quote
Old 02-10-2008, 12:26 AM   #3
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
how do u like the remote start i was thinkin of putting it on my 01 sport
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 02-10-2008, 03:29 AM   #4
JCUZ
Canberra, Australia
JCUZ's Avatar
2004 XLT 4x4
Vehicle Specs
bigapple - do you mind posting a link to the remote start wiring kit? Hopefully they do international internet/mail order.
__________________
2004 Explorer Limited 7 seater, LPG SVI powered 4.6L V8, 4WD (with BWM 2WD coming), Auto, Lukey mufflers, Roof mount DVD system, HID driving lights (high beam)22s with 265/35/22 Atturo AZ800s
JCUZ is offline   Reply With Quote
Old 02-10-2008, 09:03 AM   #5
m8r8j
ipswich, ma
02 xls, 4.0
Vehicle Specs
i have a python remote start system and i love it... i get 900 feet easily...
dont forget to turn your heat on when shutting your car off...
hehe it sucks if you start her up 20 minutes early to find that you didnt have the heat on...
__________________
02 xls 4.0 4x4 - silver
22s, dual exhaust, intake, billet grille, clear corners, grille lights, remote start, tinted tail lights, shaved emblems+roof racks+running boards, interior blue neon lighting, tinted...
next: getting bumpers+trim+doorhandles+mirrors painted silver, supercharger, double din touch screen dvd player, speakers
m8r8j is offline   Reply With Quote
Old 02-10-2008, 10:05 AM   #6
bigapple
Baton Rouge LA
'02 XLS Touring
Vehicle Specs
(Original Poster)
Quote:
it says rated for 400ft and im guessing thats about accurate because i walked down my street (guessing about 120ish yards) and it picked up the signal just fine... this is worth it for the money if u simply want a starter with no alarm... do remember that this system is only a 1-way though so u just have to hope ur car starts cuz it wont tell u if it is (like a 2-way)
Quote:
it is one of the most convenient things in the world... i cant even imagine when ill ever simply use the key again... i had a rental car after my incidental hit and run that had a remote start and that car alone made me want one
Quote:
well unfortunately thats the piece that never arrived to me in time... i ordered the "optional t-harness" on november 3rd and it is still on backorder... they told me that the company that manufacturers them is overseas and they recently expirienced a bankruptcy and handed the company over to bulldog security so it will be a while before i get one... i was against tapping into my ignition wires because i thought for sure if i did it, something wouldnt work rite... conveniently, the ignition harness that can somewhat be seen in my photo where the yellow electrical wire is had all the wires rite there and i printed out a sheet from bulldogsecurity.com with the wiring directions for an 02 explorer that told me where to find each wire, and what color each was... i couldve also installed the lock/unlock but all i wanted was the starter... if u want to search around, the site is directwholesale.net... my starter is the starter with lock/unlock and trunk pop which is the RS 1100
if i had looked into it before, since i didnt want the lock/unlock, i shouldve ordered the starter alone which is 10 fewer dollars (used to be about 20-30 less)
if u get this, be sure to have a spare key handy and order the 20 dollar security bypass
ill agree to that definitely... great to have it already warming up... im gunna have to get used to turning it on and leaving it because the rental car i had that had remote start had climate control and did it by itself... wish i had that beast in the X but hey i guess u cant have ur cake and eat it too
__________________
Old 02-10-2008, 01:44 PM   #7
Sams01XplrSprt
2001 Sport (sold)
Vehicle Specs
u should post a video of u doing a remote start
__________________
Old 02-10-2008, 01:51 PM   #8
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
does the security bypass disable pats permanently? or do you still need a pats key to start the explorer?
techieman33 is offline   Reply With Quote
Old 02-10-2008, 04:30 PM   #9
bigapple
Baton Rouge LA
'02 XLS Touring
Vehicle Specs
(Original Poster)
Quote:
the bypass has a key inside of it that is programmed to ur car... theres a ring that wraps around it and uses its signal... the wire goes from the bypass module to this large ring that wraps around the ignition... it basically uses the signal from the key to fool ur system into thinking there is a key in the ignition... theres no modifications to the ignition and PATS works just fine
__________________
Old 02-10-2008, 04:31 PM   #10
bigapple
Baton Rouge LA
'02 XLS Touring
Vehicle Specs
(Original Poster)
soon to come
__________________
Old 02-10-2008, 11:05 PM   #11
cybergasm
B
Humboldt Ks
cybergasm's Avatar
1997 Mountaineer 5.0
Vehicle Specs
How long would say it took u to install this?
cybergasm is offline   Reply With Quote
Old 02-10-2008, 11:37 PM   #12
bigapple
Baton Rouge LA
'02 XLS Touring
Vehicle Specs
(Original Poster)
Quote:
well i had a little issue before the install... i undid the steering column cover and undash panels and i realized i should probably disconnect the battery... my terminals were so corroded i couldnt get them off and had to break it... i had to run to autozone, buy new ones, and reinstall them... that took about 45mins to an hour... as for tapping into the wires, with the colors of wires from the printout from the site and the booklet that came with it explaining each wire's function, it went pretty smoothly for about an hour or hour and a half installation... i had an issue after reconnecting it to where the relays inside were clicking and nothing was working but i logged onto the site and discovered that this clicking was in program mode for my remote... i grounded a wire, pushed down on the brake, pushed a button, and BAM car started... like a charm
__________________
Old 02-11-2008, 12:59 AM   #13
m8r8j
ipswich, ma
02 xls, 4.0
Vehicle Specs
i love the remote start with the dual exhaust. its just sexy. can hear a VROOOMMmm with the push of a button.
__________________
Old 02-13-2008, 09:45 PM   #14
Scott2008
Hudson, WI
2002 Explorer V8
Vehicle Specs
I use the Omega AL-2000edp. I get very long range... down to the end of my block, starts at the end of a parking lot from inside stores. I used to be a reseller of 12V equipt, now just a hobbiest. I really like this peice. If I were going to a best buy or circuit city, I'd go after a viper or dei 2-way. One thing about the pats units. You can use the universal integrator were you are stuck losing a key under the dash. Now however both DEI and Omega make a pats bypass module that requires no key.
The biggest issue I have run into is the factory alarm. After a while it automatically arms. Then when you use the transmitter to unlock it, the factory alarm goes off. If I remote start it (or apply ign) it automatically disarms the factory alarm. I still haven't fixed the issue, but one worth noting if you are doing a full keyless/remote start.
Nice work on the BullDog!
Scott2008 is offline   Reply With Quote
Old 02-14-2008, 08:13 PM   #15
bigapple
Baton Rouge LA
'02 XLS Touring
Vehicle Specs
(Original Poster)
haha yea mine was much more basic than that... i just wanted a simple starter; no alarm needed... i was looking for a two-way that didnt include an alarm system but that seemed to be pretty much only one way systems... this works pretty well though and im pleased with the ease of installation... thanx for the compliment
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
