Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
2005 Ford Explorer: 4.0L SOHC - cam/crank timing marks
Reply
Thread Tools
Old 02-23-2008, 09:31 AM   #1
LambsTech16
Austin, TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I recently did head gaskets on a 2005 Ford Explorer equipped with the SOHC 4.0L Flex Fuel engine. I don't work at Ford so I don't have the special tools for this particular job. I put the cams/crank back how they were removed and got the truck running, but it's running piss poor due to cam/crank timing. I've called the 3 Ford dealerships here in town and they all send me the same information dealing with the use of special tools. Seeing as how I don't have those tools, I've also searched the internet numerous times with numerous search criteria and came up with pretty much nothing. UNTIL I found this forum.
Basically, I'm asking if there is anybody out there that knows where the crank should be set and also where to position the camshafts for correct timing. Is the 0 degree, 10 degree markings on the crank even useful?
All help is greatly appreciated, I'd really like to get this truck out of here and make the customer happy. Thanks again
Steven
Lamb's 16
LambsTech16 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-23-2008, 10:20 AM   #2
BIGHVM
UK, Richmond, Surrrey.
2000 Northface
Vehicle Specs
Quoted: 1 Post(s)
The way to time this engine is to take out the plugs and rotate the engine till you feel compression on no 1 spark plug hole- stick your finger on the end, as it rises you will feel pressure- look at the timing marks on the front, when it lines up on TDC its correct. The tools you refer to are unigue as far as I know and are deigned to lock engine and stop rotation. Please do not run the engine again till you have this set up as you run the risk of wrecking it big time!
I hope this helps- let us know how you get on please.
Also double check your plug leads are in the correct position, It is so easy to get this wrong and have poor running problems- This forum is the best place for real results as far as our cars are concerned, I am sure you will all the info you need here mate.
__________________
H
http://www.reverbnation.com/scratchthemonkey
Kevin P shackles, TT twist, induction kit.
UK 2000-Northface.
BIGHVM is offline   Reply With Quote
Old 02-23-2008, 10:36 AM   #3
LambsTech16
Austin, TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ive been looking for timing marks on the front since i started this job...can you point me to where they are?
Old 02-23-2008, 05:01 PM   #4
LambsTech16
Austin, TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
re-timed and everything is ok...test drive monday morning
thanks guys for all the help
Old 02-24-2008, 08:21 AM   #5
BIGHVM
2000 Northface
Vehicle Specs
Quoted: 1 Post(s)
Glad to be of help, hope I never flooded you with pms. Its a nasty car to do the timing on, I long for the days when all you had to do was twist a distibuter a little with a timing light- I am an old school guy who cut my teeth on dwell angles, and ignition bits- Hell I remember b4 electronic ignition!
Hmmmm the good ol days!
__________________
H
UK 2000-Northface.
Old 02-24-2008, 02:08 PM   #6
LambsTech16
Austin, TX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
next time i get any kind of timing issue with this motor, ill know what to do...just like the northstar v8 oil pan gaskets...such a pain, but easy once youve done it
Old 02-24-2008, 04:46 PM   #7
BIGHVM
2000 Northface
Vehicle Specs
Quoted: 1 Post(s)
Good on you mate, brave man with a big will!
Not many would attempt that without the locking tools- well done
__________________
H
UK 2000-Northface.
Old 06-04-2008, 02:08 AM   #8
shreck
central coast N.S.W. AUSTRALIA
Vehicle Specs
Quoted: 0 Post(s)
hey how are u guys? i was just wondering what procedure u used to get your cam timing on your explorer without the special service tool...we have the engine on TDC no.1, our problem is just lining up the camshafts...we have replaced the FRONT chains and guides only, so any help given would be very much appreciated...thanks guys
shreck is offline   Reply With Quote
Old 07-31-2009, 10:26 PM   #9
BRIAN517
long island ny
01 ranger
Vehicle Specs
Quoted: 0 Post(s)
found tool on line for 160 at network tool ware house
BRIAN517 is offline   Reply With Quote
Old 01-12-2010, 11:11 PM   #10
cadillacgm
Vehicle Specs
Quoted: 0 Post(s)
Can you let me know how to time cams? please
Steven
Lamb's 16
cadillacgm is offline   Reply With Quote
Old 09-22-2010, 02:13 AM   #11
kenny808
Paia Hawaii
2003 Ford Ranger
Vehicle Specs
Quoted: 0 Post(s)
Can someone please send me a picture of the timing marks on the primary chains cause I have to change all of the chain guides and the cassette guids please help me....
kenny808 is offline   Reply With Quote
Old 09-22-2010, 06:39 AM   #12
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
SOHC V6 timing chain marks
There are no timing marks on the SOHC V6 timing chains. There are slots on the end of each camshaft. See SOHC V6 Camshaft Timing
2000StreetRod is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
