Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Hood release cable broken - With Fix
Reply
Thread Tools
Old 03-25-2008, 03:33 PM   #1
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
well guys....my hood release cable has been giving me trouble for a long time and it quit again two days ago. So i did the old trick of pulling the cable with my hands and it worked so that i could jump my truck(my parents didnt drive it while i was away at school so the battery was dead ). So today i was going to fix the hood struts so i could stop using a lacrosse shaft to hold the hood up, and while i was at it i was going to change the oil....so i went to open my hood with the old "reach around" :P but the cable came undone. Or snapped i can't tell. Not in the middle either all the way at the end of the mechanism. I can see the little end when the cable should be looped but it appears to have slipped through. So can anyone give me any ideas on how the hell to get this thing open?
__________________
2005 F-150
SkanlaxJMO is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-25-2008, 06:31 PM   #2
99SportX
Duluth, MN
1999 Ex & Mounty
Vehicle Specs
Quoted: 12 Post(s)
Sawzall. lol
Seriously though, that sucks. I would like to know the best way to get it open also for future reference.
__________________
'99 Explorer Sport 5.0 2wd Lowered, etc
'99 Explorer XLT 4.0 SOHC 4x4 daily driver
'99 Mountaineer 5.0L V8 AWD other daily driver
'96 ZJ Limited on 33's, front long arm, rear 8.8 swap
99SportX is offline   Reply With Quote
Old 03-25-2008, 06:35 PM   #3
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
yeah i might go to the junk yard tomorrow and get a new mechnism and a cable...then go to town with my angle grinder.
__________________
2005 F-150
Old 03-25-2008, 06:48 PM   #4
pkwolf3
st. louis, mo
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
open hood
i had to help a buddy with his 99 hood. get a long flat screwdriver and a flashlight, look thru the grill from the pass. side of center to see the mech. towards the bottom back of it you will see were the cable should be, slide the screwdriver thru the grill and push towards the driverside. it will take some time to figure it out if you are not sure what you are looking for.
pkwolf3 is offline   Reply With Quote
Old 03-25-2008, 10:16 PM   #5
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks man...ill try it first thing tomorrow
__________________
2005 F-150
Old 03-26-2008, 09:26 AM   #6
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
any more hints???....i just spent an hour trying to figure out where it goes...and i still cant find it.
__________________
2005 F-150
Old 03-26-2008, 02:48 PM   #7
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok guys i got it...actually right after i posted that last message. What i did was reach around the back of the mechanism till i felt the little lever/knob that the hood release is on then i stuck a flathead behind it and pushed...thanks guys for all your help
__________________
2005 F-150
Old 12-29-2009, 10:35 PM   #8
jeannette752
St. Louis, Mo. 63125
mercury mountaineer 2001
Vehicle Specs
Quoted: 0 Post(s)
I am having this same prolem with my 2001 mountaineer. Do I pull on the cable from the inside of it? or do I go through the front grill with the screwdriver? i was afraid to pull on it too hard that i may cause damage in another area?
jeannette752 is offline   Reply With Quote
Old 12-29-2009, 10:51 PM   #9
my pos mounty
Land of Corruption
06 F-350
Vehicle Specs
Quoted: 4 Post(s)
Quote:
Depends where yours broke. Mine broke way out by the mechanism under the hood, just like this post. This is what I figured out on my own as well.
__________________
1999 Mountaineer, RIP
my pos mounty is offline   Reply With Quote
Old 12-29-2009, 11:15 PM   #10
my pos mounty
Land of Corruption
06 F-350
Vehicle Specs
Quoted: 4 Post(s)
If its just difficult to pull, have someone push down on the hood while you pull the handle. That worked for me until my cable broke. May I suggest lubricating the cable when you do get it opened? Go to a motorcycle dealership and ask them for cable lube. It comes in a very small tube with a needle on the end. Works wonders. Also lube the mechanism under the hood, I used lithium grease.
__________________
Old 04-22-2010, 02:00 PM   #11
royrogillio
El Paso, TX
2001 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
PLEASE HELP! i am having the same problem with my 2001 Ford Explorer Sport, my batteries dead, the keys are in the car, and i cant open the hood, is there a manual release on the 2001 Sport? if so where is it?? i cant find it anywhere
royrogillio is offline   Reply With Quote
Old 04-22-2010, 02:04 PM   #12
my pos mounty
Land of Corruption
06 F-350
Vehicle Specs
Quoted: 4 Post(s)
Your sport has the exact same setup as what you will read here. Good luck, and have patience.
Old 04-25-2010, 02:18 PM   #13
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
Quote:
If you have a spare remote that (normally) works on the truck, attach a set of jumper cables... the positive to the large terminal on the starter and the ground to the frame rail, and that should power the truck well enough to get the truck unlocked and pop the hood.
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 01-18-2011, 12:35 PM   #14
komdori
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I'm having a similar problem where this might help--manual door locks are all frozen/broken, but remote/keypad works fine. Light left on truck, so I can't get inside to release hood to jump it. Is the best way maybe to use a screwdriver to release the mechanism, maybe pull the cable, or maybe hook the jumper cable to the starter as this post suggests?
Is it easy to find the starter to attach a jumper cable to it?
komdori is offline   Reply With Quote
Old 03-16-2015, 12:33 PM   #15
Albert Danraj
Fishersville VA
1995 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
I tried to replace the striker bolt on my 1995 Explorer rear driver side door and the nut fell into the cavity. I tried poking around with a magnet with no luck. Is there a way to recover the nut?
Albert Danraj is offline   Reply With Quote
Old 04-07-2015, 10:36 AM   #16
Spoofed
91 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
Damn, I hate when my nuts get stuck in a cavity. My suggestion: lots of lube.
Spoofed is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cheap Fix For Broken A/C Fresh Air Door TonyinFL Stock 2002 - 2005 Explorers 25 11-08-2014 04:20 PM
Now that I've installed a new hood release cable .... davem Stock 1995 - 2001 Explorers 13 06-30-2014 07:51 AM
Tighten hood release cable? superskid Stock 1995 - 2001 Explorers 3 11-24-2009 04:37 PM
broken(?) e-brake cable saxon Stock 1991 - 1994 Explorers 0 05-19-2006 12:51 PM
Hood Release Problem Maduro Under the Hood 6 05-08-2001 12:09 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
