Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
Kirby's Spare Time Sucker.... 1995 Full Size Bronco Solid Axle Swap
Reply
Thread Tools
Old 06-23-2008, 10:59 PM   #1
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Kirby's Spare Time Sucker.... 1995 Full Size Bronco Solid Axle Swap !!PICS!!
This is where I have been putting in all my time lately. It is going to be sweet when it is done. I thought I would share. It is my buddy Phils rig. He has been driving it for a few years. It has never been modded at all ( OK, we built him a bumper a couple of months ago). He has never even had a lifted truc. He is determined to build it right the first time! He is doing all the research and the grinder work, rebuild work, etc. I am just there for experience, moral support, and welding. He has done an incredible job planning it out considering he started gathering parts a year and a half ago. It has been down for about 2 months now. We did the rear first.
Specs:
Rear- Stock 8.8. 4.56 Yukons, Aussie Locker, Sky Shackle Flip, Ruff Stuff Spring perches, welded axle tubes, shock mounts cut and turned for extra clearance
Front- 1977 F150 Dana 44 (1/2" axle tubes) Fully rebuilt with all new bearings, ball joints, seals and a paint job.
6" Deaver Coils, Yukon Chomo Shafts, 4.56s, Yukon Superjoints, Warn Premiums, Ballistic fab poly/ flex joint on trackbar, Chevy TRE conversion, Threaded DOM Tie Rod, drag link, trac bar, and Tera 2.5" Johnny Joints on the Radius Arms, Stock f150 Coil Buckets. Full height. Probably stock Super Duty upper shock mounts too, but we haven't decided quited yet.
He also has a new set of 35" BFG Mudders he will be running.
Unlike explorer swaps, the Tranny crossmember has to go on these full size swaps. The front driveshaft can't move with down travel at all really with the stocker. That caused us to have to build a crossmember for the tranny, and we decided we might as well attach the radius arms there too.
The Radius arms are fully plated with 1/4" flat stock, then the threaded stud was ground smooth and a piece of small DOM was slid over it and plug welded in two spots as well as the ends. Then another piece of DOM was threaded for the Johnny Joints and bent in the bender to keep the link mounts near to the frame rail and to make the mounts paralell to the frame. It was plug welded in two spots and of course on the end. They are 15" extended over stock.
Side Shot As it sat tonight:
Now we are working on the tracbar. We are using Ruff Stuff brakets top and bottom. The tracbar will need to be bent to clear the crossmember/ steering box. We hope it will be done by the end of June. More to come...
__________________
SOLD 93 Sploder- HP Dana 44 Front, 37" MTRs, 4.56s, 1354 doubler, ARB, Detroit, Winch, Kirby Built Armor, etc...
05 Jeep Rubicon Unlimited LJ 4" Lift, 33s,
94 F150
Kirby N. is offline   Reply With Quote
Old 07-01-2008, 07:00 PM   #2
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
We made some more progress this weekend. Got the trac bar mounts made and attached and got the drag link/ trac bar mocked up for measuring. They are being made by a local machinist who is taking DOM and threading it for us as well as putting flats on it so we can fit a end wrench on.
On with the pics!
Some of the Radius Arms
Comparo:
Radius Arms in Crossmember
Trac Bar Upper Mount
Lower Trac Bar Mount
Finally, Truck on all 4s at ride height
__________________
94 F150
Old 07-01-2008, 10:16 PM   #3
zainyD
Lakeland, FL
zainyD's Avatar
'96 Ranger 4x4 XLT
Vehicle Specs
Looks good man!
__________________
'96 Ranger 4x4 XLT with some stuff....and more to come when I actually have some money
zainyD is offline   Reply With Quote
Old 07-01-2008, 10:28 PM   #4
94 Crawler
Stantonsburg,NC
94 Crawler's Avatar
'94 Ranger SuperCab
Vehicle Specs
did you thread the dom with a tap or a lathe? Also are those 1 1/4 x 12 thread joints? And finaly if so is that 1 1/2 x 1/4 wall dom?
You already answered the first ? all the pretty pictures
__________________
http://www.explorerforum.com/forums/...d.php?t=200101Michael Howell
94 Supercab Ranger
63 Chevy C-10 (Lowered and on the bottle)
86 Ranger, 90 Montero, 03 Protege' 5 (Wifes)
74 VW Bug "Ilsa The Volksrod" http://www.volksrods.com/forum/showthread.php?t=30689
94 Crawler is offline   Reply With Quote
Old 07-01-2008, 10:50 PM   #5
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
It was threaded with a lathe. I am not sure what a 1 1/4 x 12 thread joint is...
I don't know what wall the DOM is, but it is beasty. We asked the machine shiop to use the DOM that would work well with the Tera Joints.
__________________
94 F150
Old 07-01-2008, 11:19 PM   #6
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Oh, what are the joints eh? They are teraflexes and I think they are the 3" or something. They have a 9/16" hole.
__________________
94 F150
Old 07-02-2008, 01:17 AM   #7
colindo94
Cameron Park, CA
94' XLT
Vehicle Specs
Ballistic joints?
__________________
Full width Dana 44/8.8, 36x12.5 TSL radials
Ostman Bros. Fab Shop
colindo94 is offline   Reply With Quote
Old 07-02-2008, 08:00 AM   #8
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
Cool... the OJ Simpson model!!
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is online now   Reply With Quote
Old 07-02-2008, 07:25 PM   #9
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by colindo94 View Post
Ballistic joints?
Yep. The trac bar is getting one poly and one flex from ballistic.
__________________
94 F150
Old 07-02-2008, 07:25 PM   #10
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Quote:
RUN OJ RUN!
Oj is going to be harder to catch now that he has some suspension travel...
__________________
94 F150
Old 07-02-2008, 07:36 PM   #11
94 Crawler
Stantonsburg,NC
94 Crawler's Avatar
'94 Ranger SuperCab
Vehicle Specs
Sorry I was refering to the thread pitch and size of the stud on the joint. Your set up is similer to the one I have planed for mine.
__________________
94 Supercab Ranger
Old 07-29-2008, 07:25 PM   #12
Joe93
Elite Dakota
Colorado Springs, CO
Joe93's Avatar
Vehicle Specs
Wow looks good. So this is what my reamer was needed for?
Joe93 is offline   Reply With Quote
Old 07-29-2008, 09:39 PM   #13
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Yep! Thanks for the loan joe! We need to hang out sometime. Lets go wheeling!
The OJ bronc is on the road now and it is sweet. It sits about a foot taller than the Navajo at the roof/ hood, but it looks pretty proportional. Wheel travel is exceptional! I will post up some pics when I get some.
We are really pleased with how it turned out.
I guess the progress we made since the last update is: f250 shock towers and crazyedsperformance.com shock tabs, Rancho big bodied shocks in the 9012 style so they are 13" travel ones, and the rear leaves were redone with 3 leafs added for a stiffer spring and more height.
I should also add that everything for this build was purchased at http://crazyedsperformance.com/ at a great price!
__________________
94 F150
Old 08-02-2008, 10:14 PM   #14
Joe93
Elite Dakota
Joe93's Avatar
Vehicle Specs
I saw the bronco today and I must say turned out great. Everything looks really beefy.
Old 08-03-2008, 11:19 PM   #15
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Thanks Joe! I think it is ready for a shake down run this weekend! You want to wheel this weekend?
__________________
94 F150
Old 08-03-2008, 11:48 PM   #16
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Looking great Kirby N.!
I can not forget and thank you enough for all the tips you gave me on my first SAS thread.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 08-04-2008, 02:41 PM   #17
Joe93
Elite Dakota
Joe93's Avatar
Vehicle Specs
Quote:
Cant make it this weekend. I need to get out sometime though its been way to long.
Old 08-08-2008, 10:30 PM   #18
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Quote:
OK... give me a call sometime! I will post up pics of wheeler lake on Sunday for everyone to see. I am driving my Sisters TJ because my rig is down. Phil is installing some street truck drop shackles and he hacked the rear quarter for clearance. We moved his axle back about 5". The rear driveshaft had to be seriously lengthened! As soon as we get the rear height nailed we will weld on some shock mounts and order some shocks for the rear.
__________________
94 F150
Old 08-11-2008, 06:38 PM   #19
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
Shakedown run Pics From Wheeler Lake. It did AWESOME. No breakage. Rear shocks need to be added asap soon.
Wheeler Lake Trail:
__________________
94 F150
Old 08-11-2008, 06:52 PM   #20
Kirby N.
Ogden, UT
1993 Sploder
Vehicle Specs
(Original Poster)
The rest of the pics are here:
http://www.explorerforum.com/forums/...94#post1996994
__________________
94 F150
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
