Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
96 Ex Power Window Bushing Fix with Pics!
Reply
Thread Tools
Old 07-24-2008, 08:13 PM   #1
lunchboxx
Roanoke, VA
2000 pontiac bonneville
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
As I have posted before..I dont even own an explorer, But I married in to one!
So I have one to work on now. This forum is one of my new best friends.
Well, my sister in law went to Italy for a freakin week and her Explorer came to my driveway to visit, so I figured I would poke around.
Here is the window fix: I apologize in advance for not noting the nut and bolt sizes, but I figure if you are going to take on this project, you have a set of tools and are dangerous enough to think you can use them....
This would be the time to disconnect the battery if you were a "Safety Sam" kinda guy..I however, enjoy the feeling of 12V in my body..so I didnt.
Approach the door..ask it to dance
Remove these two screws. And then use a flat blade screwdriver to Jimmy off the inner door handle trim cover
GENTLY start to pull the door off or use the special plastic insert remover tool.
Unhook this trim light. it twists and then comes out IIRC
This is the back of the lock/unlock and window up/down button switch. The whole thing just pushes in towards the door.You dont even have to unhook it
Start a pile on your well manicured lawn
lunchboxx is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-24-2008, 08:16 PM   #2
lunchboxx
Roanoke, VA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Slowly peel off this plastic. Try not to rip it, it needs to be there or Ford engineers would not have put it in there, right?
Removing this green Ground screw will allow the wiring harness to dangle and give you some more room to move and work
Remove the 3 speaker retaining screws
Detach speaker clip w/ screwdriver
Old 07-24-2008, 08:25 PM   #3
lunchboxx
Roanoke, VA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
You need to drill a 1/2 inch hole RIGHT HERE
It will end up looking like this
Pull the three motor bolts out and take it somewhere to work on it. My wife loves me, so I get the kitchen table Remove the TORX bolt (T20 i think)
Pop off the top w/ a screwdriver
Using a set of needle nose, push back on both sides of the retaining clip at the same time and shoot it across the kitchen. CUSS, ALOT. Find the clip and take a picture of it
Remove metal and plastic gears..Notice a significant LACK of bushings..and a funny smell...
Old 07-24-2008, 08:32 PM   #4
lunchboxx
Roanoke, VA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
BUY some of these
If you are comfy with the guts of an electric motor, and are feeling Ballsy..do what I did and take the armature out and look at all the little bits of old bushing that would never have been cleaned if you didnt take it apart. But, if you get it back together and then the motor wont work..dont blame me..I warned ya!
Clean the little bits of bushing out of everything with a jewlers screwdriver if you have one..
Then assembly is reverse of removal..I greased everything up pretty good with grease. You may have to put the motor where it goes and start the screws, then run the motor in short bursts while pushing toward yourself with your arm inside the door cavity until the motor teeth pop into the regulator teeth. Then just button her back up.
Difficulty rating: 6 beers
Old 07-24-2008, 08:46 PM   #5
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 222 Post(s)
Very good work. Now... what, no blood? That's good work to finish with no busted knuckles.
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 07-25-2008, 06:24 AM   #6
lunchboxx
Roanoke, VA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Oh there was blood..just no knuckles..LOL
Old 07-25-2008, 03:09 PM   #7
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 222 Post(s)
Well still, you have all of your fingers, the window regulators are very dangerous if loosened. You only worked on the motors, which is the safest job.
__________________
Don
Old 07-26-2008, 07:25 AM   #8
lunchboxx
Roanoke, VA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Truly they are big ugly Spring loaded finger removing machines!
Old 09-20-2008, 08:33 AM   #9
geoclint
'96 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for the great instructions and pictures. The only addition I would add is to drill the hole a little larger than 1/2" since the bolt was not perfectly centered with the dimple. By the way, no blood, no sweat, no missing fingers thanks to your warnings.
geoclint is offline   Reply With Quote
Old 09-22-2008, 07:30 AM   #10
lunchboxx
Roanoke, VA
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Glad that I could be of help. It seems silly for everyone to go at it blind after one of us has done it already.
Old 09-22-2008, 03:00 PM   #11
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
very good work
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 07-20-2009, 05:54 AM   #12
luvmyexpl
Loxahachee,fl
1996
Vehicle Specs
Quoted: 0 Post(s)
Cool Life Saver. Nice Work!
LunchBox, all i can say it thanks for the great pictures and directions. I bought the 96 Explorer I have now for my 16 year old daughter. When I got it the Windows did not work. I just pumped $700 into it for brakes, tires, checkup. I also painted all the Trim that was faded. You know all that Black trim that always fades on the Explorers?
Well I could not afford to have them do the Windows also so i followed your directions. I even found the same exact gear plugs from Bennet Auto Supply. They have them behind the counter. I printed out the picture you took and they found them immediately. These help parts are at most Auto Parts stores. They cost me $7 for two pairs. I also bought some grease to re apply. I saw someone mentioned they had to shave the bushings to get them to fit. These bushngs are rubber and do move. I slided them in and used the back of a flat head screwdriver to snug them in.
You will even like this. When I took the motor out I showed my wife where you wrote that the work had to be done on the kitchen table. Thats where i did it! Also thanks to your posting I was careful when taking the clip off so it would not fly through the kitchen! I did scre one thing up though. When I took the panel off I busted the vanity bulb on the bottom and it shorted and blew the fuse that controls the interior lights and also happens to control the Power Windows.The windows were not working after I tested them and they did work. I replaced the fuse in the interior panel and good to go.This was relatively easy and dare I say a fun project for me. It was gratifying knowing that I could fix both windows for less than $10!
Thank you Lunchbox.
luvmyexpl is offline   Reply With Quote
Old 08-02-2009, 05:57 PM   #13
covshark
Ocala, Florida
96 xlt 4.0 OHV
Vehicle Specs
Quoted: 0 Post(s)
Thumbs up
great write up. My power window was making a clicking noise whever the window button was pressed, sure enough all 3 of those window regulator gear plugs were chopped into tiny lil bits.
Great thread with great pictures and info. Thanks This needs a Sticky
covshark is offline   Reply With Quote
Old 04-04-2010, 10:42 PM   #14
Yerba1
Wasatch Front Utah - Love the Canyons of Sanpete County
1993 Clean one owner
Vehicle Specs
Quoted: 0 Post(s)
great job! thanks a million!
Without this post - I would have never found that third screw. I was about 5 minutes from drilling out the rivets - when I decided to check here! I had the motor out in 10 minutes - clip off - I had to "bend" the cover up because the fourth screw was a rivet. The plastic beads cost me 8 dollars at Autozone - the plastic mounting pins were garbage so I'll get some universal pins tomorrow and secure the door completely. I can't believe that the three plastic beads were all that I needed. I'll bet more than one customer has paid for a new regulator + shop time for an $8.00 fix. My '91 is ready to be passed to my next sixteen year old. My fourteen year old is already hinting that she wants it next...
Yerba1 is offline   Reply With Quote
Old 08-09-2010, 09:49 PM   #15
96_sport_ct
Florida
96 Sport control trac 4wd
Vehicle Specs
Quoted: 0 Post(s)
THANK YOU THANK YOU THANK YOU. i thought that my window motor was shot on the passenger side because it wouldnt make any sound at all when i hit the button. i could never find the last bolt till i read this. my gear plugs are shaped like beans. you just saved me tons of money and tons of time. i would imagine most people that have problems with their motors could simply fix them this way.
__________________
Put on a pot of bourbon and load my thinking bong, it's story time!
96_sport_ct is offline   Reply With Quote
Old 08-10-2010, 09:11 AM   #16
Ricardo Brennan
Vehicle Specs
Quoted: 0 Post(s)
You can remanufacture like this and hope it works for awhile. I called Central Florida Mobile Power Window Repair and got a new power window regulator and motor installed for less than $160 while I was at work out in the parking lot. They gave me a warranty on the parts and labor. Their number is 407-415-5401
Ricardo Brennan is offline   Reply With Quote
Old 08-10-2010, 10:44 PM   #17
96_sport_ct
Florida
Vehicle Specs
Quoted: 0 Post(s)
well considering i only had the problem with the motor its definitely worth the $15 to do both sides. both motors work like new now. i wouldn't mess with the regulator because i know of the dangers but i would imagine that most window related problems are from the motor considering that the regulators are pretty solid and the motor has weak plugs as well as a plastic gear inside. thanks lunchboxx for this amazing write up
__________________
Old 10-27-2010, 03:09 PM   #18
Project95
Wilmington, NC
1995 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Dude!
Guys, thanks SOO much for posting this! This saved me lots of "MONEY" buy DIYing it the Ford dealer wanted $95 an hr plus $120 for the motor which I got at autozone for $33.99 at the link below. 10 mins later and I few swear words because I keep dropping the screws inside the door but no bloody knuckles.
thanks
Project95
http://www.autozone.com/autozone/par...6&sortType=low
Project95 is offline   Reply With Quote
Old 11-15-2010, 05:07 PM   #19
MUL8KC
Mobile, AL
'96 XLT
Vehicle Specs
Quoted: 0 Post(s)
Electric Window Motor Bushings
How do you get the window up (out of the way) when it fails in the down position? I've heard that removing the motor with the window down can be dangerous as the regulator has a spring?
MUL8KC
MUL8KC is offline   Reply With Quote
Old 07-07-2011, 09:57 AM   #20
vett82ce
Rincon,GA.
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Hey,
I'm bringing this post back because someone referred me to it for my passenger side window that was not operating. I utilized the original post and it worked great but I took it to the poster's next level and removed the armature for cleaning. He was right - there was to much chunk in there to make me comfortable for leaving it there.
Anyway, got a perplexing problem because I'm not electrically inclined. After wrestling with the brushes and springs for a while I finally got it done and the window operates beautifully except that up is down now and down is up?? From the switch on the armrest when I press the up button the window goes down and when I press the down button the window goes up. Obviously I missing something in putting back together an electric motor. It sure seems straight forward - remove armature from housing, clean, spring load your brushes and return armature. Any ideas?
vett82ce is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
