which is why I'm trying to figure this crap out
since Ford
used to use double-cardan shafts, there's gotta some design changes that forced them to use a GKN cv instead. Unless, of course, it was cost. But I believe a double-cardan is cheaper. A replacement rebuilt GKN cv joint is around $160. Just the joint.
And there must be a reason they went away from the single-cardan shaft too, because it's the least-expensive of the 3 styles of shafts.
Waking the dead!
The thing that changed from 95/96 to 97+ was the front diff vacuum disconnect.
91-94 = TTB front suspension, which means a moving front diff, which necessitates a slip-joint driveshaft. The 91-94's used either auto or manual locking hubs, so any rotation forward of the t-case was only part-time. 91-94s used a double-cardan joint at the t-case end. (Edit: Cardone Part # 65-9661)
95-96 = IFS, which means a fixed front diff, which means no slip-joint is needed. The front diff in the 95-96 used a vacuum disconnect (Edit: only the V6s), which I think disconnected the passenger side half-shaft when not in 4wd, but I'll need someone else to chime in as to whether the front driveshaft rotated only in 4wd like the 91-94s or it rotated full-time even in 2wd like the 97-ups.
Edit: For 96, Cardone lists part # 65-9623 (28.25") and 65-9622 (27 13/16"), the latter has the circular flange. For 95, Cardone oddly lists the 65-9623 as for a 4-door and they specifically don't sell a 2-door front DS. Why would they be different?
97-up = Same IFS as above, however no vacuum disconnect, just full-time front end rotation, which I'm guessing is the reason for the GKN CV style joint at the t-case end.
Now I don't know how all this plays into the lengths of the driveshaft. Maybe there was some difference between the vacuum-disconnect front diffs and the non-vd diffs. It is of note that a 91-94 driveshaft fitted with NeapCo N2-83-287X adapter, which would make the driveshaft a couple of inches longer, fits 97+.
Now, here's my question. I have a '99. I am converting my 4405 t-case to a manual 1354 t-case from a '94. I either have to install the 4405's GKN CV cup flange on the 1354 to use my stock '99 front driveshaft (which may not be bolt-on-possible), OR keep the 1354 flange and use a '91-94 front driveshaft. The latter sounded ideal, since double-cardan looks more badass, and apparantly more stout than a GKN, however, this always-on front driveshaft rotation setup of my '99 got me thinking that the non-GKN CV joint might not be up to the task and cause vibration issues. Does anyone know?
Also, I have searched and can't find an answer. Did ANY explorers come with a REAR driveshaft that had a double-cardan joint?
