bodiea
- November 3, 2008
- Temple,Ga.
- 2000 XLS
Ok guys I hope I post this correctly and in the right place. I have been doing most of my normal post in the Transmission area. I have a 2000 XLS 4WD that has the common O/D light flashing issue. I did a valve body rebuild and still have the issue. So I read a few thousand more post and found one about possible failures in the Intermediate and O/D servos. So I ordered two new servos and covers to replace mine with. I have gotten the servos out. But the delima is I cannot get them to go back in far enough to get the snap ring that holds the covers back on.
I cannot get them to compress or go into the bore far enough the get the snap rings back in. I'm thinking the end piece that hits the band (dont know what its called) may have slipped down? Is that possible? And if so is there a way to get it back into position? Can I drop the pan and see this piece from below and work it back up and into place if it dropped? Page 51 of the pdf link. Also attached a somewhat blurry pic of the servo bore.
Dead Link Removed
