| Explorer4x4 | Sportrucks | 2011 Explorer | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | My Posts | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). |
Thread Tools |
#1 |
Wannabe Elite Explorer
Auburn,Washington
'96 Explorer XLT
Hi every one,
my 96 Ford Explorer right turn signal light buzzing instead of blinking but left side works normal. I checked rt front and rear turn signal light bulbs and they all looked OK. I replaced turn signal relay(flasher) from auto part store but still have same problem.(of course it's not returnable) Can any one tell me what's the next step could be? |
| Sponsored Links (Less Ads) |
#2 |
ALL FIRED UP
Raytown MO (Kansas City suburb)
1997 Mountaineer 5.0
Your MFS (multi function switch) is bad. AKA your turn signal switch.
__________________ P r i c k me, do I not bleed Ford Blue. |
#3 |
Spokane, Wa
1996 Ex V8, AWD XLT
Sounds more like a relay to me, the click is the sound of the relay moving. A buzzing instead sounds like it isn't doing what is should. I'd start there anyway, just swap one side for the other if it doesn't change then it's some where else.
__________________ FOR SALE TT, Shackles, PA-853, Superlift k494=9" of lift! Manual 4406=LOW GEAR!, selectable front axle, 35x12.50.15 SSRs Next......gears (4.56), lockers (Aussie), coilovers..... Aw heck SAS it! 79 F-150 axles in the barn
#4 |
La Mirada, CA
'97 Mounty 5.0 AWD
mine does the same thing too when its cold although it rarely does it.. along side of that my wipers do occasionally stop in the middle of the windshield..
i've already swapped and replaced the wiper relays but havent touched the relay for the turn signal.. go4par, post your result if ever you decide to replace your multifunction stalk.. __________________ scanner, hitch cargo carrier, ballast+bulb, etc for sale: http://www.explorerforum.com/forums/...10#post2223710 |
#5 |
No1toldmeIcouldchangethis
El Paso, TX
97 sport, 02 xlt & 02 xls
Yup, mine was doing the same thing, got a new one for like 25dlls and changed it myself in ~20 min
__________________ If interior is to exterior and include is to exclude, then increment is to: |
#6 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
MFS. Mine used to do the same thing. Buzz on left turn, no buzz on right turn (or was it the other way?, I forget because I replaced it years ago).
Some people report smoke coming out. That's a bad thing. Maybe you want to replace it before it gets that bad, or maybe you like living on the edge. Your call. |
#7 |
Auburn,Washington
'96 Explorer XLT
Dan,Dog friend,jad2411 and others,
Thanks you very much guys. i replaced MFS(multi function swith) this morning and working fine. It took me about 40 min to remove and replace first time and cost me less than $60 include tax on local parts store. |
#8 |
Wasilla, Alaska
1994 Explorer Limited 4wd
I had the same problum but it turned out to be a short in the steering column for me, the wire would touch when i dropped the steering wheel down.looks like you got your fixed already though
#9 |
Tempe, AZ
'96 Explorer XLT
1996 Explorer flasher relay buzzing noise, inoperable windows.
Hi Everyone,
Just replaced my flasher relay switch due to signals not operating. Now, the signals work but I'm getting an intermittent yet steady buzzing noise from the new flasher relay and to boot, my power windows are not working now either. Would this also be an MFS problem? Thanks in advance for your help! |
| Thread Tools | |
