Shen2187
- July 10, 2008
- Medford, Oregon
- 1991 XLT 4x4
Does anyone know if the "Mitsubi 5 Speed" out of a B2 would bolt up to a '91 X 4.0 OHV with the "A4LD"? I've searched for hours and have not found really much of anything about the particular swap or if it's even possible without super "adapterness".
Was planning on taking the Trans + Xfer case and doing the swap. Should be only about .4" of length difference between the two transmissions, if the info I DID find was correct.
I've also got to check and see if it has a D35 instead of the D28 (so I can steal the manual hubs) But I doubt it since it's Pre- '89.
