EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Transmission and Axle codes.
Reply
Thread Tools
Old 03-12-2009, 10:50 AM   #1
konstan
Omaha, NE
'93 Explorer Sport
Vehicle Specs
(Original Poster)
Well, I searched but was not able to find it on this site. So in case someone else searches for them, I thought I'd post this info here:
Axle Codes
L - Limited Slip Differential
C - Conventional Differential
Code ... Ratio
41 ...... 3.27C
42 ...... 4.10C
43 ...... 3.08C
45 ...... 3.55C
46 ...... 3.73C
D1 ...... 3.27L
D2 ...... 4.10L
D4 ...... 3.73L
D5 ...... 3.55L
Transmission Codes
Code .................. Model
D (1997-2005) ..... A5LDE / 5R44/55E
D (1992-1996)...... M5OD-R1
J ....................... M5OD-R1
J (2002-2003)...... R1HD / M5OD-R4
M (2000-2001)..... Mazda M5D4
M (1997-1999) .... M5OD-R2
M (1992-1996) .... M5OD-R1
R (2002) ............. 5R55W
T (1992-1995) ..... A4LD
T (1996-2001) ...... 4R55E
U ....................... 4R70W
V ....................... 5R55S
X ....................... 6R60
konstan is offline   Reply With Quote
Old 03-12-2009, 11:21 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
I've moved your thread to the transmission section, and made it a sticky. We have a link on the main forum page with this information: http://www.explorerforum.com/ntrprize/Axle.htm
BrooklynBay is offline   Reply With Quote
Old 03-12-2009, 01:35 PM   #3
konstan
Omaha, NE
'93 Explorer Sport
Vehicle Specs
(Original Poster)
Quote:
Yeah and I didn't think to look in the dedicated transmission forum because I didn't even realize there was one.... this site just gets better and better.
Old 03-16-2009, 11:32 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
This is a list of axle codes for an Aerostar from this link: http://www.ford-trucks.com/forums/71...xle-codes.html
Code Ratios:
Conventional:
22 4.10
23 3.45
24 3.73
25 3.27
26 3.55
Traction-Lok:
B2 4.10
B4 3.73
B9 3.55
This link has information on how to identify differentials: http://badshoeproductions.com/rear.html
Old 04-05-2009, 11:50 PM   #5
Mr Ed
chicago
2002
Vehicle Specs
Can somebody please explain where the transmission id code is on the
door?
I found the door tag and the rear axle code but I don't see the word
"transmission".
Mr Ed is offline   Reply With Quote
Old 04-20-2009, 09:34 AM   #6
konstan
Omaha, NE
'93 Explorer Sport
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by Mr Ed View Post
Can somebody please explain where the transmission id code is on the door? I found the door tag and the rear axle code but I don't see the word "transmission".
Here is what my tag looks like (roughly, typing this from a note made with my wife dictating over the phone). Please let me know if an actual pic is needed, and i will make one when i get home.
M8102 ...... TYPE- ...... TRANS ...... AXLE
....................................T..............41
This means 'T' - A4LD transmission
Old 04-20-2009, 10:09 AM   #7
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
For fun, the axle codes in the original post only applies to Explorers, Rangers codes are different: http://www.explorerforum.com/ntrprize/Axle.htm
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 04-20-2009, 11:33 AM   #8
Mr Ed
chicago
2002
Vehicle Specs
Thanks for the help. My tranny is a 5r55s. It seems that this isn't the most
popular series in 02.
Old 12-15-2009, 10:38 PM   #9
shenanigans
'95 XLT 4.0L
Vehicle Specs
CAN possible error in transmission code on door?
I have a 1995 XLT with the transmission code 'T' on the door, however it has a 4r55e in it. I have been inside it once already and it is definitely not a a4ld as it has all 6 solenoids etc. curious if anyone else has noticed anything like this?
shenanigans is offline   Reply With Quote
Old 02-04-2011, 11:13 PM   #10
cattleshow
Central Texas
1999 explorer sport
Vehicle Specs
Quote:
looks like your truck is a 1996 .
cattleshow is offline   Reply With Quote
Old 02-05-2011, 05:54 AM   #11
truckerb1
Leon Ia
1995 Limited
Vehicle Specs
1995 was the first year for the 4R55E
truckerb1 is offline   Reply With Quote
Old 02-05-2011, 03:35 PM   #12
cattleshow
Central Texas
1999 explorer sport
Vehicle Specs
My 1999 explorer sport has on the door lable.
Axle code- D4 -which is ? 3.73L
Trans code-D
Under trans code , it says 97-05- A5LDE/5R44/55E
What does those codes mean as I;m trying to determine towing ability of my truck.?
Old 02-05-2011, 05:49 PM   #13
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
Trans code-D
My ford manual says 4800lb towing capacity.
__________________
Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex
swetrid is offline   Reply With Quote
Old 02-05-2011, 09:25 PM   #14
cattleshow
Central Texas
1999 explorer sport
Vehicle Specs
Question
thanks
The bumper frame says max tow 3500 lbs. with 350 max Tonge W.
The trailer I want to tow is about 3000 lbs max loaded.
Should I just get a regular class 3 hitch to be on the high side.
as for the 4800 lb , is that because of the tranny being a 5r55e.
or the 3.73 rear end.?
mine has O.D. shutoff on the columm.
Old 02-06-2011, 06:32 AM   #15
truckerb1
Leon Ia
1995 Limited
Vehicle Specs
a little of both
ALWAYS shut the OD off when towing
Old 02-06-2011, 10:37 AM   #16
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
I would put a proper trailer hitch on and not tow off the bumper.
__________________
Old 02-06-2011, 12:35 PM   #17
cattleshow
Central Texas
1999 explorer sport
Vehicle Specs
Quote:
Roger that -class III
Old 04-27-2011, 07:00 PM   #18
97ExplorerXLTAWD
Oklahoma
97ExplorerXLTAWD's Avatar
1997 Explorer XLT AWD 5.0
Vehicle Specs
I looked up my codes today..and idk if this will help any butttt.....
Wb|||BRK|||INT TR||||TP/PS||||R||||AXLE|||TR||||SPR (THEN UNDER IT)
112---4-------FX--------D-------------D4-----U-----1-F
So For rear end, u look at axle which is a D4.. so i have a 3.73 limited slip...and im assuming the TR is trans so i have a 4R70W.
97ExplorerXLTAWD is offline   Reply With Quote
Old 08-19-2011, 03:52 PM   #19
PhantomFord
Petaluma, CA
1995 Eddie Bauer Limited
Vehicle Specs
so i have an 1995 eddie bauer limited v6. do i have the A4LD or 4R55E. the transmission was swapped from the original and i do not have park. also it appears as if it doesnt exactly line up in one spot where the casing of the transmission meets the engine.
PhantomFord is online now   Reply With Quote
Old 08-19-2011, 04:05 PM   #20
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
Quote:
You have the 4r. As for the line up issue, a transmission's bellhousing's overall shape doesn't usually match that of the engine as a transmission model can fit multiple engine models and an engine model is often compatible with multiple transmissions. As long as the bellhousing is flat against the engine all the way around, then the two should be properly mated and aligned.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
