Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
91-94 Stock Air Box - Filter - CAI - and more
Reply
Thread Tools
Old 04-06-2009, 07:01 PM   #1
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...This is for all the 91-94 Explorer/Ranger owners looking for answers on their Stock Air Box setup, Filter options, adding a CAI (Cold Air Intake), and for those who want to return their Intake Air System back to stock and don't know where to begin....
_________________________________________________________________________
...The 91-94 Explorers/Rangers have what is called a Thermostatic Air Cleaner, Intake Air System and is an important part of your Emissions system...If you do not have this in proper working order, you will fail both the Visual, and your Emissions Test....
The below info can be found here and is used just to describe the following...
http://www.wivip.com/index.html?te_idletest.html
The Thermostatic Air Cleaner System is an early emissions control device that was designed to deliver temperature-regulated air to the intake manifold such as warm air for cold engine conditions and cool air for engines at normal operating condition. Thermostatic Air Cleaner systems usually consist of an enclosed air filter housing, with an air intake snorkel containing a thermostatic control valve. This thermostatic control valve controls whether cool air or warmed air enters the intake manifold through a vacuum signal. Later models have used electrically activated thermostatic control valves. After the engine has reached normal operating temperature, the thermostatic air control valve returns to a position to allow cool air to enter the intake manifold for normal engine operation.
Thermostatic Air Cleaner items checked:
1. Exhaust shroud is missing or not secured properly.
2. Heat riser tube, cold air duct, air cleaner cover, plugs, flexible material between air cleaner and vacuum motor, is missing, broken, plugged, taped or disconnected.
3. Vacuum lines or hoses are missing, broken, plugged, taped or disconnected.
4. Air cleaner is missing or "unsealed" for a Pulse Air type system. Wing nut(s) missing.
5. Vacuum motor port is not properly sealed (if dual snorkel).
These pictures show how your vacuum lines properly hook up and also the locations of it's parts...
...This is where your 2 vacuum lines connect at the top, rear of your Stock air box lid..(The bottom half of your airbox is mounted on top of the right front fender) This lid fits on top of that piece...
...This is a pic of the underside of your stock air box lid...Note the vacuum port on this side...Nothing connects to this...(But on the top side of this port is where the vacuum hose for the thermostatic control valve connects)
...This picture shows the proper placement of your vacuum hoses...
...And last but not least, this is your Thermostatic Control Valve located in your Cold Air Intake duct...It is located behind the passenger headlight and most people can only see the vacuum hose heading down to it...Be sure this hose is connected...
Stock Air Filter Options
...In this picture the top filter is an STP filter which comes designed with a ridge that keeps all the individual pleats from closing together...The bottom filter is a Fram air filter...I have found that these tend to close up and clog when they are in a real dirty/dusty environment...This shows the bottom, pleat side of the filter...
...This is the top side of your air filter...The fresh air is drawn in from the bottom of the filter, througt this top side of the filter, to your MAF, on through the duct, and to your throttle body...(Again, notice the pleat separation from the STP air filter)
Optional Cold Air Intake (CAI) Upgrade
...There are several models to choose from...K&N and KKM, are 2 of the most common to be found on Explorers...I have the KKM that was designed for our motors...Here is a link to their site... http://www.kustomz.com/054094.html
They have installation info so, here is a pic of my setup...The KKM filter pretty much sits just above the bottom half of the stock airbox and attaches to the existing tube...It takes a whole 10 minutes for the swap to stock for the smog test.. (Note the capped off vacuum line from the motor, the one with the bolt in it)
Note:...If you live in California, these will not pass Smog
Is the True-Rev Induction kit emissions legal in my area?
The True-Rev Induction Kit is designed for competition use and though it does not eliminate any required emissions devices, it does not carry any emissions exemption certificates. The bottom line is check with your state testing stations for guidelines on engine modifications. Our Kits are not C.A.R.B. certified.
...And here is a link for C.A.R.B...
http://www.arb.ca.gov/homepage.htm
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-06-2009, 07:29 PM   #2
cybergasm
B
Humboldt Ks
cybergasm's Avatar
1997 Mountaineer 5.0
Vehicle Specs
Quoted: 0 Post(s)
so umm did you pass?........
cybergasm is offline   Reply With Quote
Old 04-06-2009, 08:04 PM   #3
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...Why yes, yes I did...
...Except in my rush after fixing my CEL problems, I almost forgot to swap my Stock filter back in...
__________________
Old 04-06-2009, 08:44 PM   #4
cybergasm
B
Humboldt Ks
cybergasm's Avatar
Vehicle Specs
Quoted: 0 Post(s)
cool My turn comes up next week
Old 04-06-2009, 10:07 PM   #5
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Originally Posted by DeRocha View Post
This Video (from the airbox operation thread) shows what the lower airbox intake assembly looks like and how it operates.
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 04-06-2009, 10:16 PM   #6
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...Thank you for adding that great video...
...Is that you speaking on the video???..
__________________
Old 04-06-2009, 10:27 PM   #7
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Your welcome I hope it adds some info to this thread which you did a great job at creating.. I certainly can appreciate the time and effort that goes into creating a well thought out, articulate, and visually pleasing thread . And yes that is my voice on the video clip (Narrating a video is something I'm not the best at.. obviously )
__________________
Old 04-06-2009, 10:39 PM   #8
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...You did Great ..
... I would have never thought of doing a video on that , but it is probably the most important and highly overlooked item of this particular system...
...And Thank You very much for the high praise...
__________________
Old 04-07-2009, 10:03 AM   #9
Verno
Waynesboro, TN
94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Both you guys are awesome. Really simplified the process of figuring out those two vac hoses for me! Gonna look at the Ex when I get home tonite.
Verno is offline   Reply With Quote
Old 04-07-2009, 12:41 PM   #10
boggs1227
Flowery Branch , Georgia, 1994 sport 2wd auto
2005 colorado 2wd 5spd
Vehicle Specs
Quoted: 0 Post(s)
thermostatic control valve / sensor (Air Cleaner Temperature Sensor ) :
duralast brand
auto zone part number # E108
price $ 11.99 est' (may be diff from state to state )
__________________
Scott .
boggs1227 is offline   Reply With Quote
Old 04-07-2009, 02:05 PM   #11
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...Thanks for adding that...I'm sure it will help others locating that part as these tend to go out over the years...
__________________
Old 04-07-2009, 03:55 PM   #12
rustbucketMI
Michigan
'94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Thats a lot of money for a filter and a flange adapter.
My CEL had been coming on for about a year, gave the truck to my brother for a while and didn't care to fix it, so i decided to replace the MAF that had gone bad. Instead of using the stock MAF housing i went to teh junk yard and pulled a MAF out of a 4.6L T-Bird and replaced the sensor with a new 4.0L sensor i bought. I went to my local autozone and bought a spectre cone filter. All in all i spent $25 on the cone filter, $10 on the sensor on ebay, and $30 on the MAF housing (would have been $10 but i didn't have safety torx to get the 4.6L sensor off).
For this $65 i got a new MAF, essentially the same cold air setup and the KKM or K&N and approx 50% better air flow. This results in a lot more power. For kicks i put the old housing back in and felt a very noticable difference in power.
Instead of plugging the vaccum line i put the whole thermostatic control valve and vaccum line on the air tube after the MAF. There is essentially no difference in air properties on either side of the MAF. I didn't know about the control valve so i obviously didn't do anything about it.
Since my mod i havn't thrown a CEL and my power is great. The gas millage is about the same but with the added power im having trouble keeping my foot out of the gas. I dont have the misfortune of have to be inspected every year but as far as i know my emissions havn't changed. I've had this for about 5 months and absolutly no complaints. Just a suggestion for a cheap easy upgrade as opposed to paying for more for less
__________________
'94 Explorer XLT - Warn Manual Hubs, Pro Comp Trail lights and agressive tires, 4.6L MAF, Spectre cone filter, flowmaster exhaust
'07 F150 - MBRP Exhaust, AEM Cold Air Intake
'78 Nova - LSX engine, Ford 9" rear end, Custom roll cage and suspension
2012 Mustang Boss 302
- AM
rustbucketMI is offline   Reply With Quote
Old 04-09-2009, 04:19 PM   #13
seth247
Tulsa, Oklahoma
'92 XLT 4X4
Vehicle Specs
Quoted: 1 Post(s)
Great info.
small correction.
You say that the air is pulled into the top side of the filter but I beleive it's the other way around.
__________________
-Matt
Forest Green'92 XLT 4X4 302/4R70W
To all those in uniform, past and present. Thank You.
seth247 is offline   Reply With Quote
Old 04-11-2009, 10:31 AM   #14
Four0Sport
West Virginia
1993 2dr
Vehicle Specs
Quoted: 41 Post(s)
eh that sounds bout right to me
__________________
1993 Explorer Sport, Narrowed HP44 SAS, UA2015 survivor
Four0Sport is offline   Reply With Quote
Old 04-12-2009, 10:14 AM   #15
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
My CEL had been coming on for about a year, gave the truck to my brother for a while and didn't care to fix it, so i decided to replace the MAF that had gone bad. Instead of using the stock MAF housing i went to the junk yard and pulled a MAF out of a 4.6L T-Bird and replaced the sensor with a new 4.0L sensor i bought. I went to my local autozone and bought a spectre cone filter. All in all i spent $25 on the cone filter, $10 on the sensor on ebay, and $30 on the MAF housing (would have been $10 but i didn't have safety torx to get the 4.6L sensor off).
I did something very similar.
I went to the boneyard and grabbed a 5.0 MAF housing. This housing doesn't require an adpater to clamp on a filter. The conical filter just slides right on. I already had a K&N filter, so I just slid it on the end of the 5.0 housing and clamped the filter on. Reattached my stock MAFS, and i was good to go.
Great write-up!
__________________
-P.J.-
Winter Beater: 1994 Explorer XLT 4wd
Summer Car/ Daily Driver: 1998 Mustang Cobra coupe #4941 of 5174 Born on June 19, 1998. 263rwhp/258rwtq untuned, with nonfunctioning IMRC's. Hoping for 285-290 next spring with a much needed tune.
YourNameHere is offline   Reply With Quote
Old 04-12-2009, 10:40 AM   #16
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Just to be clear for others reading this thread: If you remove the stock air box in favor of a cone type of filter the Bi-metal sensor and vacuum lines are no longer needed (just plug the lines). Routing warm/cold air to the stock airbox does very little anyway, and provides Zero benefit when using a Cone filter.
__________________
Old 04-12-2009, 09:18 PM   #17
safn1949
Mankato, Minnesota
M60A1 my first offroader
Vehicle Specs
Quoted: 2 Post(s)
That was my next question,thanks.
__________________
1994 XLT,4.0,3.73 LS
149,000 miles.
Need a Panasonic Toughbook? I have them,email me for details.
safn1949 is offline   Reply With Quote
Old 04-12-2009, 10:30 PM   #18
jtb1689
Woodinville, WA
'93 Sport Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Don't know about other states, but here in Washington State, in one of the bigger counties where they require 2-year emissions testing (no visual, just numbers/diagnostic) I took out every part of my old air box system including the part that goes from the headlight area to the airbox with the thermostatic air flow part when I put in my KKM and passed with flying colors. I've actually passed twice. Once just one year after I installed it and again just recently (3 years after installation)
__________________
Says I live in Woodinville, I also go to school in Bellingham so I could be down for runs or get togethers in either area.
My 1993 Eddie Bauer Sport Registry
jtb1689 is offline   Reply With Quote
Old 04-13-2009, 03:45 PM   #19
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 294 Post(s)
(Original Poster)
...Then this thread will be a great reference in the future..
...It is very common as people will pull out their stock boxes and want to return it to stock when they sell the vehicle...The questions always come up on where the hoses are going and coming from...
...It is good to save your stock items and reinstalling them when you sell the vehicle...That is how I got my KKM filter for cheap....
...Again, thanks to HappyGilmore....
__________________
Old 04-13-2009, 09:09 PM   #20
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Just to be clear the thermostatic air control is only used to warm up your engine a few minutes faster than normal. This equipment saves maybe 1-2 gallons of fuel over the course of a year. Obviously not a huge deal, but when you add in a few million vehicle you can see were things make a difference at the global level. Anyway once your engine reaches Normal temp your emissions will be the same with or without the thermostatic temperature system, so its no surprise you passed your emissions test.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
