Started my install - 04 Eddie Bauer | Ford Explorer Forums
Beastb15
Kansas City, Missouri
'04 EB
Area is being fiberglass for 4 10" Memphis shallow mount subs. Rainbow Germanium components up front. 2 Boston Acoustics GT-24s to run the components and subs
good work on the sound deadening, but why would you do shallow mount in an explorer, all that room, i put mine to good use
I've done installs using the entire cargo area in my previous explorers. I've always regretted not having my cargo room. Thought I'd try something a little different this time
yea thyats true, the huge boxs ive been through usallly are a pest when i need to haul other things, i have a biggg problem with my whole car raddleing, my back is deadened but the plastic still shakes like crazy
Got some more work done today...however I didn't get as much as I'd like. It started to rain a while ago...and I got caught up using some swirl remover this morning.
Jealous of your amps....I want them.
those 4 subs could handle a little more than that gt 14 couldnt they
yep, yo i checked out your pictures, back when i first got my car i had the SAME exact idea on the guages, whered you get those from, i wanted the white background with blue/aqua numbers shining through, ***** tight tho yo, i like it alot
That was my 03 XLT. Someone ran me off the road about 8 months ago and subsequently led to the totally of that Explorer. However, I got those gauges off of Ebay.
that sucks dude, what yo drivin now?
Well I am going to chalk this one up as a work in progress. I have it all hook up, but I'm going to tinker with it for a while. I still have to figure out an acceptable spot for the amps...
Boston Amps are so good looking.
throw some carpet on the top of that box and it will look amazing. nice work. what are you going to do to protect the subs from objects in the cargo area? grills? what type if so?
Well, I'm actually debating on recessing the subs or not. As far as grills go, JL has some grills that will fit these subs...but they are far from attractive. Soo, I'm not sure.
What are you looking to get for the Eclipse headunit?
where dud you wire the power wire for the amps. I have a 2004 ford explorer limited and i would prefer not to drill. if you could show me pictures of how you did it it would be great
I'll see if I can't get you some pictures tonight. However, drilled through the firewall in the bottom left corner.
