thepotroast
- February 24, 2009
- Asheville, NC
- 3rd Gen EB 4x4 V8
I am going to try to lower the whine in the rear end of my 03 4x4, reading a lot of threads on here that people have the same issues as me with the infamous roar or whine. Mine is constant from 30MPH and up....but most of the noise goes away when I let off the throttle....as soon as throttle is applied it comes back immediately....making me believe it's not a bearing issue (as bearings would whine or roar when the wheels are spinning...not stop when throttle is depressed).
I had the entire truck serviced at Cottman last year, which included diff fluid change, tranny fuild change, etc. However, I am sure they probably just put regular 75w-140 in there, no idea if they added friction modifier. I do have a limited slip diff (axle code D4).
I have been reading that a lot of people have luck with Amsoil 75w-140 and added 4oz of friction modifier. However, I only have access to Advance Auto and Auto Zone....neither seem to carry Amsoil products. They do have Lucas, but I read a few posts here that said the Lucas did not make the whine go away. I do believe that Advance carries Royal Purple...but haven't seen any posts on here regarding using it to get rid of the rearend whine.
How much diff lube should I get to fill? Do I just pump/pour it in?
I have searched the threads here about replacing the fluid, lots of tips and instruction...but not so clear on how to fill, and how much to use. Stock limited slip diff with 3.73 gears (code D4).
My next step will be replacing the hub/bearing assembly in the rear. Ford already replaced the diff clutch pack and pinion/gear set under factory warranty back in 2005, I do not believe that is what is happening in this case.
