Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Replacing rear steel brake line on 99/ questions
Reply
Thread Tools
Old 07-21-2009, 09:31 AM   #1
mikepier
Long Island, NY
99 XLT
Vehicle Specs
Quoted: 26 Post(s)
(Original Poster)
My rear brake line that goes over the diff is rusting bad and I would like to change it before it breaks. A couple of questions came up from the auto stores when I called, is it single, double, or bubble flared? Also what size is it?
Auto Zone has steel brake lines with the double -flared ends on for $6.99 for a 6 ft section( I believe thats what I need). Does anyone have info on what the specs are for the rear brake line?
mikepier is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-21-2009, 12:35 PM   #2
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 77 Post(s)
Not sure, but most likely a bubble flare. (I asked this question before and got no reply) Why not take it off and have a look? Take the line in and have it matched for size. 3/16 I think...
bluestream1 is offline   Reply With Quote
Old 07-21-2009, 04:50 PM   #3
texyank
'97 Sport
Vehicle Specs
Quoted: 0 Post(s)
I bought a stock length of 3/16" line from Pep Boys for about $5.00 for my 97 Sport. If I remember correctly it was 51" long and the ends were already on it. I bent it by hand since my bender wasn't made for anything smaller than 1/4". It took about 30 minutes from start to finish including bleeding the brakes afterward.
Don't wait to do this. I found out mine was bad when I hit the brakes hard when a semi pulled out in front of me and the line blew. Trust me, that's not fun!
texyank is offline   Reply With Quote
Old 07-21-2009, 05:12 PM   #4
bluestream1
Waterloo Ontario
Vehicle Specs
Quoted: 77 Post(s)
Yes, but OP wants to know if he should buy line with inverted double flares, or bubble flares?
Old 07-21-2009, 05:21 PM   #5
texyank
'97 Sport
Vehicle Specs
Quoted: 0 Post(s)
I'm not sure about the flares, I was not asked that question when I called around. However, I believe they were bubble flares.
Old 07-21-2009, 05:33 PM   #6
kyleyz762
syracuse, NY
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
i got the 3/16 line 60" long i think. had a little extra so i cut it off and had to flare only the 1 end. make sure to use a brakeline bender or it will kink. took me about 20min
__________________
kc's in front,hella's on top,ranchoRS5000,general grabber at2,cragars,procomp,cai,front hooks,billet grille,PA,alpine,jensen,usaspec,rockford fosgate,valvoline mxsyn,lucas
kyleyz762 is offline   Reply With Quote
Old 07-22-2009, 08:48 PM   #7
mikepier
Long Island, NY
99 XLT
Vehicle Specs
Quoted: 26 Post(s)
(Original Poster)
Thanks for the info. I ended up getting a 3/16" line 51" long at Auto Zone for $6.49. And just an FYI, the ends are double flared. It was easy to change. The hardest part was bending it in the right shape.
One thing I noticed on the new line is that one flare nut was longer on one end than the other. My old line did not have this difference, but the new line went in fine, no leaks.
While doing this job, I did notice my drivers side e-brake cable was rusted and it does not work when the pedal is pressed. The passengers side works, but not the drivers side. It appears the cable broke inside the armored/ rubber tube assembly. Look for my post on this problem.
Old 07-22-2009, 09:40 PM   #8
bluestream1
Waterloo Ontario
Vehicle Specs
Quoted: 77 Post(s)
Do you mean the flare was longer, or the flare nut was longer. If the nut was longer, that's no big deal
Glad to finally know what kind of brake like flares these truck use...
Old 07-23-2009, 05:29 AM   #9
mikepier
Long Island, NY
99 XLT
Vehicle Specs
Quoted: 26 Post(s)
(Original Poster)
The threads on the nut were longer.
Old 09-30-2013, 05:03 PM   #10
markie_g
manchester,ct
1999 Explorer (Base xls)
Vehicle Specs
Quoted: 0 Post(s)
Mine blew out today,Dumb-ass making a left turn,no signal.
we cut and flared the tube,only to forget to put the nut on.cut replace,repeat!
markie_g is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
