Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Loud Knocking Noise (Lifters?)
Reply
Thread Tools
Old 07-22-2009, 11:35 AM   #1
ADonato
Lafayette, IN
2003 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have had my 2003 Explorer for the past year and a few months and have had a knocking noise from time to time when I start the engine. It was very light at first and barely noticable until this winter when it got a bit louder. At that time it would go away fairly quickly tho (10-20 secs). Now this summer it has been knocking much louder and continues to knock for a minute or up to 5 mins. I took it by a Ford dealer just to get a quick opinion to see if it was anything that needed attention and they said it was my lifters and that this happens with Explorers as you put mileage on them. Mine has 99,000 miles. They told me if I thickened my oil from the recommended 5W-20 to a 10W or 20W that it would stop the knocking noise. I changed it to 20W-50 and it completely stopped for a few days but the knocking noise is back now. It is very light but it is there again and stays for 30 secs to a minute or two. Can anyone give me an idea of what is going on or let me know if you have had this problem as well. I want to make sure this isn't serious and I am treating this properly.
Thanks for your help.
ADonato is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-22-2009, 12:45 PM   #2
07XLT4x2v8
Raleigh, NC
07 XLT
Vehicle Specs
Quoted: 0 Post(s)
I also have this issue on my 07 v8. I was told to try the oil change and will do that soon. Hope that this solves the problem.
__________________
Mark Duerst
07XLT4x2v8 is offline   Reply With Quote
Old 07-22-2009, 01:56 PM   #3
Joey P
Denver, CO
Joey P's Avatar
2004 Strac
Vehicle Specs
Quoted: 0 Post(s)
Changing oil may mask and even stop the problem as you noticed but you really need to find out what the problem is to fix it right. And then, don't go back to that dealer if that is what they told you to do. Changing oil won't "fix" anything. Is your explorer the v6 or v8? v6, I might lean towards timing chain issue? Just a guess because I do not know.
Joey P is offline   Reply With Quote
Old 07-22-2009, 02:27 PM   #4
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 2 Post(s)
First make sure you don't have a cheap oil filter in there, use Motorcraft Filter 820s (V8), been there done that.
i can't listen to your truck from here, . . .post a clip maybe??
with Worn Lifters noise is not so much a knock but more of a tap.
The frequency of the noise might point a finger at something. . imo.
Example:
tap, tap, tap, tap, tap, tap etc (all lifters are bad, or noisy injectors, or the cheap filter on startup for like 10seconds)
tap, x, x, x, x, tap? Each 'x' is kinda of like a single piston firing off no noise . . . (one bad lifter)
or are you hearing more of a
A knock, you can almost feel it too, is usually bottom end issue.
Ex.
knock, y,y,y,y,y,y,y,knock Each 'y' is a single piston (This would be a bottom end problem, Piston Slap, Rod bearing, doom)
sorry for the weird quesiton but . . . can you describe it a little better . . .hopefully this will point you in the right direction for starters.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 07-22-2009, 11:47 PM   #5
07XLT4x2v8
Raleigh, NC
07 XLT
Vehicle Specs
Quoted: 0 Post(s)
Well for my X (07 v8) it is definately more of a tap. Very consistent noise that finally goes away after several minutes. I have 65k miles on it.
i don't understand why the oil filter would cause this noise. I have to look tomorrow and see what brand is in there.
Thanks for the replies.
__________________
Mark Duerst
Old 07-23-2009, 11:25 AM   #6
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 2 Post(s)
cheap filters sometimes have a poor or omit the drain back valve, it prevents the filter from draining all of the oil out of it while its shut off, on startup the oil pump has to fill the filter first before oil get to the valves thus the 10-20 second delay, but this would be all valves, its sounds almost like a diesel.
If you really have a lifter problem it might be a diy as the cam/lifters are on top of the head.
__________________
Jim
Old 07-23-2009, 01:06 PM   #7
07XLT4x2v8
Raleigh, NC
07 XLT
Vehicle Specs
Quoted: 0 Post(s)
Well I checked and I have a Fram toughguard filter on there.
When I change my oil next - should be due very soon - I will put a Motorcraft filter on it.
__________________
Mark Duerst
Old 03-12-2015, 09:50 AM   #8
kawaleks
chagrin falls,Ohio
2000XLT
Vehicle Specs
Quoted: 0 Post(s)
I also have the knocking issue on my 2000 explorer, but it is constent. changed the oil and the back half of the exhaust to no avail, my mechanic thinks it may be the timing chain, he estimates at least $1400 to possibly fix with no gaurentees. the truck has 160,000 miles on it. any thoughts about oil additives that might reduce the sound. unfortunately it is at the end of its days and I want to get every mile I can out of it. any thoughts
kawaleks is offline   Reply With Quote
Old 03-12-2015, 02:22 PM   #9
Tech By Trade
Your mom's house
07 Sport Trac
Vehicle Specs
Quoted: 190 Post(s)
check cam phaser failure.
__________________
Bought a Sport Trac, Biggest pile of junk I have ever owned. I plan on letting everyone know about it.
http://www.explorerforum.com/forums/...d.php?t=385793
Tech By Trade is offline   Reply With Quote
Old 03-14-2015, 01:00 AM   #10
cober
1996 Ford Explorer
Vehicle Specs
Quoted: 1 Post(s)
replace rocker arms and knocking sound will go
cober is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
