Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How to: 2002 Explorer rear wheel bearing replacement (pictures)
Reply
Thread Tools
Old 08-15-2009, 01:37 PM   #1
Tyler92
Saratoga Springs, NY
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Exclamation How to: 2002 Explorer rear wheel bearing replacement (pictures)
When my ’02 Explorer rear wheel bearings started grinding I knew this would be an expensive trip to the dealer so I decided to take the task on myself. I read many helpful posts here and last week I successfully replaced the passenger side bearing and coil spring.
Yesterday I took on the driver’s side and snapped a few pictures in hopes of helping others to avoid being ripped off at the dealer. If you have some mechanical background and some tools you can do it.The photos below are of the left rear of my ’02 explorer and your vehicle my differ if it’s from another year.
Some of the tools needed are:
Torque wrench
Metric sockets and wrenches
Hub puller (I borrowed one from Advance Auto for free)
Hammer
Small pry bar
Chisel
Spray all bolts and nuts and pins with PB Blaster at least one day prior to removing them. This will help loosen the rust.
To get started jack the vehicle up and USE JACK STANDS. Safety first.
First thing I noticed is the broken coil spring. This was broken in two spots. The right side in three.There's a good chance yours are also broken.
Remove the two bolts holding the caliper using a 10mm socket. Pry the top out first with a screw driver or small pry bar. Don't pry on the pads and don't whack it with a hammer. Once removed tie it up to the coil spring or somewhere out of the way. Don't let it dangle by the hose. After removing the caliper pull off the rotor. If the rotor is stuck you may need to use a rubber or hard plastic hammer to pursued it. You can then pull out the emergency brake cable and end from the back plate. This will slide right out. If the E brake shoes are in good condition you can leave them on. I chose to remove mine from the backing plate to clean a little of the rust off.
Next remove the axle nut. This nut is big and on very tight and requires a long handle 1/2 inch drive breaker bar to get it loose. Either put the emergency brake on or have someone press the brake to keep the axle from spinning while loosening. Almost every post tells you to use a 35 or 36mm socket. Who has one of those sitting around? I used a Craftsman 1 3/8 socket and it fit and worked perfectly. Once loose I used my 1/2 drive air gun to remove it. I also reused the same nut when reassembling. There was nothing wrong with it and I wasn't spending $15 to replace it.
Now it's time to tackle the two pinch bolts that hold the upper control arm and the toe link to the knuckle. You will use an 18mm deep well socket to remove the nuts. As mine were rusted in pretty good, the way I got mine out was to insert a chisel into the slot shown to help spread apart the knuckle. Tap lightly and it should come right out. Don't hammer it too hard as you can damage the end of the bolt.
This photo was taken after the job was complete.
Now comes the hardest part of the job which is separating the upper control arm and toe link from the knuckle. These will be rusted in and require force to get them out. Using the same chisel I hammered it back in the slot as far as I could to try and spread the knuckle apart. The toe link should come out easier than the upper arm. Once you have the chisel inserted, carefully start tapping the arms to get them out. I was not successful on the passenger side getting the upper arm off and had to unbolt it from the frame of the vehicle and pull it and the knuckle out as one piece. Then I could get at it better and it popped right out. On the drivers side it came out but with much force. Warning! Stay away from the rubber boots with all pry bars, hammers, etc and do not use any heat. If you tear the boot then you have even bigger problems.
Now remove the bolt holding the lower control arm to the knuckle.
Now it's time to pull the knuckle. This is where the hub puller comes into play. Without one of these you will not be able to pull the knuckle off the axle spline. Note I have not touched the backing plate for the emergency brakes. Every post on this forum is telling you to either cut it in half or remove the three bolts that hold it on. There is absolutely no reason to do this. It can stay attached to the knuckle through the whole process.
Success!!!!
Time to install the new parts. I purchased these from AutoPartsDirectToYou.com. One of the forums on here stated the bearings were Timken which is of very good quality and the price was very good at $60 each. The bearings are not Timken and there are no markings on them at all so I'm sure they are a Chinese part. They do come with a lifetime warranty but who wants to do this job again soon. Not Me.
I took the knuckle and new hub to NAPA to press out the old and press in the new. 1 hour and $30 later it was ready to go back together.
I didn't take pictures of the installation but here are a few tips.
Use some sandpaper or wire wheel to remove the rust from the pins on the toe link and upper control arm and used a generous amount of antisieze on them before inserting back into the knuckle. Clean the bolts and also use antisieze on them.
Install the axle nut first only snug and then reattach the toe link and upper control arm.
Torque the pinch bolts to 66 Ft Lbs. The axle nut shows 203 Ft Lbs. I feel this is too much so I went with 175 Lbs and will check it periodically. My thought is that possibly the bearings wore out prematurely do an over tight axle nut. Your call on this.
It will all go back together 100 times easier than it came apart. For the average occasional backyard mechanic, plan on at least a full 8 hour + time frame for doing this.
If you have any questions or comments please post them here and I'll try and answer them. Hope this helps and good luck.
Finished job. This picture also shows a new spring and strut installed which I did along with the bearing replacement.
Tyler92 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-17-2009, 03:07 PM   #2
tv4fish
Minnesota
2007 EB V8 & 2002 EB V6
Vehicle Specs
Quoted: 1 Post(s)
Tyler: I see no one else has added a "thank you" to you for this post -- so here is one --- Thank you for taking the time and effort to do this - It will be beneficial to someone, I am sure.
tv4fish is offline   Reply With Quote
Old 08-17-2009, 08:32 PM   #3
Tyler92
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Thank you Tv. Yes I hope it helps people on here. It's a tough job but doable.
Old 08-17-2009, 10:13 PM   #4
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Vehicle Specs
Quoted: 0 Post(s)
Way to go - I admire your perserverance to go for it, and your generosity in the detailed post here. I suspect that some day I will need to tackle this job as well, and I must say I am not looking forward to it. However, your post may well save me some pain and frustration - two factors I already have plenty of in my life, so thanks!
Mods, how about a sticky?
__________________
Wife's: '02 Limited 4.6L/4x4
Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe
EasyRhino is offline   Reply With Quote
Old 08-18-2009, 07:26 PM   #5
Tyler92
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Rhino. I appreciate your comments. If you have to tackle the job feel free to drop me an email if you need help.
Old 08-18-2009, 11:08 PM   #6
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Quoted: 0 Post(s)
Excellent Post!
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 08-19-2009, 12:13 AM   #7
EasyRhino
Kailua, Hawai'i
Vehicle Specs
Quoted: 0 Post(s)
Quote:
You cold just drop by for a cold beer or three and a wrench, but I guess that Saratoga is a long way off (BTW, one of my favorite towns with some of my favorite, uh, shall we say, bars? - and restaurants).
__________________
Old 08-19-2009, 03:08 PM   #8
vannboy
Alta Loma, CA
2002 XLT V6 4x4
Vehicle Specs
Quoted: 0 Post(s)
Nice work! Couple of questions:
How did you know the bearings needed to be replaced? I'm getting some vibration while driving and it is magnified when I turn left. Was told by my local mechanic I needed one front and one rear complete hub assembly (bearings included). They want to charge about $500 labor for this. Wish I was a better backyard mechanic...lol. I need a mentor in SoCal to show me the ropes and help me spruce up my baby!!
Also - what strut/coil combination did you use? I have a 2002 XLT 4x4, just went over 100K miles and need to replace mine.
Thanks again!
vannboy is offline   Reply With Quote
Old 08-19-2009, 08:45 PM   #9
Tyler92
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
How bout I stop in around February? I'll even bring the beer. LOL. Living in Hawaii must be fantastic. I'm jealous.
Yes Saratoga is nice, and despite the economy is still thriving and growing.
Old 08-19-2009, 09:06 PM   #10
Tyler92
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks again!
The RR bearing started making a noise like I had a snow tire on that side. I ignored it but it finally after 6 months started to really grind. I jacked up the rear and tried to move the RR. It wobbled all over the place.
I bought MOOG springs and Monroe shocks from Advanced Auto. The springs were $112 for the pair and the struts were $89 each. I then had to borrow a spring compressor to remove the old and install the new. I did happen to find that Monroe now makes a complete unit called the "Quick Strut". It's the complete spring and strut assembly already assembled. All you have to do is install it in the truck. That's the way to go.
Old 08-20-2009, 12:54 AM   #11
vannboy
Alta Loma, CA
2002 XLT V6 4x4
Vehicle Specs
Quoted: 0 Post(s)
Awesome - thanks! I've seen some complaints about the quick strut for other vehicles, but hopefully it works out for the Explorer. It's a bit more expensive than buying the two separate but seems to be a lot less hassle.
Old 08-21-2009, 11:11 AM   #12
rgcme33
Florence, South Carolina
2002 Mounty AWD V8
Vehicle Specs
Quoted: 0 Post(s)
I have a question about the procedure (I have to do it next week), since it requires a puller to remove the knuckle from axle, is there any special tool or procedure to reinstall knuckle to axle? or will it just slide back on?
thanks for a great writeup by the way, very helpful!
rgcme33 is offline   Reply With Quote
Old 08-21-2009, 01:43 PM   #13
Tyler92
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes it will slide most of the way back on and then you can just draw it the rest of the way on with the axle nut. Good luck.
Old 08-21-2009, 06:17 PM   #14
rgcme33
2002 Mounty AWD V8
Vehicle Specs
Quoted: 0 Post(s)
Thanks!
Old 08-21-2009, 11:30 PM   #15
EasyRhino
Kailua, Hawai'i
Vehicle Specs
Quoted: 0 Post(s)
Feb is fine (weather) here .
The only thing I do not miss about Saratoga is the winter!
__________________
Old 08-28-2009, 07:04 PM   #16
vannboy
Alta Loma, CA
2002 XLT V6 4x4
Vehicle Specs
Quoted: 0 Post(s)
Well I chickened out and had Ford replace my front driver hub assembly ($450). WHAT A DIFFERENCE!!! I was getting a pretty bad grinding noise, especially when turing left. The ride is A LOT smoother now. Ford told me the right one is starting to make some noise, and the upper control arm bushing is starting to tear, so maybe I'll have the huevos to tackle those when the time comes...
FYI - thepartsbin.com is selling the Timken front wheel hub assembly for $128.
Old 08-29-2009, 03:26 PM   #17
Attila
Clinton Township, MI
02 xlt
Vehicle Specs
Quoted: 0 Post(s)
Great pics! Your post should be a sticky..
I did my driver side rear bearing 3 weeks ago. I had to replace because the rear end was grabbing and pulling to one side. That thing was noisy, sounded like the when the u joints used to go out.
Did the work myself in my driveway, not to hard to do. I did have a shop press the bearing for me. The old bearing was in pieces when the shop guy gave it to me. I also replaced the cv shaft as a well because boot was toast.
Darn thing was stuck until i used a wedge between the shaft shoulder and the gear case to free it.
I decided to do the front bearings/cv shafts at the same time because one side was starting to growl. Front was easier to do. I found easier way to get at the 3 hub assembly bolts. Once you get the wheel nut off and the brake caliper out of the way, push the cv shaft in with the special pusher tool to the point where you can get an actual socket on the bolts. Then start wrenching away. Way faster than the offset wrench. It went faster because i snapped one of the bolts. who cares, you get set of 3 with new hub assembly.....
Attila is offline   Reply With Quote
Old 09-14-2009, 11:29 AM   #18
lrm
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
I replaced my rear bearing/hub 2 years ago on the passenger side, yesterday I worked on the drivers side. I mangled the top ball joint rubber boot with a tie rod separator (whoever said do this gently hasn't worked on an old truck, those things are stuck) and tie rod end rubber boots. I cover them with replacement boots when I'm done.
I could not get the hub off using a three armed wheel puller. I hit with hammers, pried behind it with the tie rod separator, broke three tools tightening the puller. Would an impact wrench work to shake it loose?
I think I'm going to have to replace the CV joint since the spindle and hub are locked together. Does this involve opening up the rear axle? I'm probably taking it to a shop unless someone has a sure fire way to get the hub off - hammers, heat, and puller aren't doing it.
Thanks for the help!
lrm is offline   Reply With Quote
Old 09-15-2009, 10:23 AM   #19
j_b_5_2
Vehicle Specs
Quoted: 0 Post(s)
You either need bigger tools or more muscles.lol. But seriouly they dont just pop off. You gotta put some weight behind it.
j_b_5_2 is offline   Reply With Quote
Old 09-15-2009, 11:09 AM   #20
rhs7
Pittsburgh, PA
2002 Explorer
Vehicle Specs
Quoted: 0 Post(s)
US One more follow up question...
Excellent post -- you probably saved me hundreds of dollars in collateral damage due to heat and really big hammers.
I am going to pull my hubs and spindles to replace the rear differential seals. No damage yet, just leaking. My question is should I replace these bearings while I have the hubs off? Or just antiseize everything up real well so the spindle comes off easier when the bearings finally go bad? Also, can someone direct me to the BEST post on replacing these differential seals.
I have got 90k on a 2002 XLT 4X4.
rhs7 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear wheel bearing replacement question. 96743explorer Stock 2006 -2010 Explorers 5 11-28-2014 08:44 AM
How to replace rear wheel bearing on 2003 ford explorer ALKADEEM Stock 2002 - 2005 Explorers 1 09-10-2011 06:17 PM
2002 rear wheel bearing llwta76 Stock 2002 - 2005 Explorers 1 03-23-2009 04:05 PM
1998 rear wheel bearing replacement Cruehead Stock 1995 - 2001 Explorers 2 01-14-2008 10:32 AM
2003 Explorer rear wheel bearing replacement spazik697 Stock 2002 - 2005 Explorers 1 07-07-2007 06:05 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
