LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
Today I was in the process of removing the passengers front knuckle to do a list of maintenance and ran into a problem. The axle nut, outer tie rod end nut, and both upper and lower ball joint nuts came of pretty easily. I applied PB ahead of time as I knew I would be doing this and I also test loosened everything the other day before wading in. The caliper came of easily as well.
The problem is that I just can't get the bolt on the upper ball joint to release from the knuckle. It just won't pop out. I have tapped and banged on the knuckle with a 5lb hammer and it just seems jammed in there. I can easily rotate the knuckle around the bolt and the upper control arm goes up and down as it should. I would expect the weight of the lower control arm and knuckle to pull out from the bolt pretty easily. I tried banging up on the control arm. I put the nut back on the bolt and tried banging up on the bolt. I jacked up under the lower control arm and then released the jack several times. I put a length of 2x4 under the upper control arm near the ball joint and jacked on the bottom of the board to lift the arm. This lifted the truck off of the jack stands but did not free the ball joint, even with allot of hammering. I hammered down on the knuckle in several places but nothing seems to free the bolt.
I really need to get this off to continue. I don't know that the lower ball joint is any better but I can't tell until I get the upper loose. This control arm and ball joint are newer then the drivers side so I wasn't planning on replacing it.
Is it possible to remove the upper control arm with it still attached to the knuckle? I am skeptical but I could give that a try. Maybe I would have better luck with the knuckle out. At least I could use a bigger hammer, or a grinder.
Any suggestions would be appreciated. I don't know if pictures would help but let me know if there is anything you want to see.
LMHmedchem
LMHmedchem
