| Explorer, Ranger - Computers, Chips, Tuning Programmers, chips, modules, dyno tuning for the Ford Explorer, Ranger, Mercury Mountaineer, Bronco II and Mazda Navajo. |
Thread Tools |
#1 |
Greenville, SC
2000 Sport SOHC 2WD
Best Wideband O2 Sensor Location?
I just received an AutoMeter 5978 Wideband Air/Fuel Ratio Monitor kit. The instructions say to install the sensor "as close to the cylinder head as is reasonably possible. . . . For cast iron manifolds install the sensor in the pipe just below the manifold. . ."
My 2000 SOHC V6 has the stock manifolds and I don't plan to ever replace them. There are two stock catalytic converters with O2 sensors installed before and after each one. For those of you who have a wideband A/F monitor, where is your sensor located? In your opinion, where is the best location? __________________ My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank |
#2 |
Germantown, MD
Just anywhere upstream of the cat really. But the problem is that you're only able to read the O2 data from one bank - in other words, you only get data from 3 of the 6 cylinders.
__________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#3 | |
Wannabe Elite Explorer
North East New Jersey
'99 4dr. XLT SOHC A4WD
Quote:
1.) If the sensor is installed in the pipe, it MUST be powered through the controller/display any time the engine is running. An unpowered wideband sensor is very quickly ruined by running the engine w/ an unpowered sensor. The only exception is : 2.) In order to avoid cracking the sensor from heat shock, from cold condesation blowing on a heated sensor; Start the engine first, wait about 10-20sec, then turn in the wideband/sensor. This give the engine a chance to blow out any water that collected in the pipe while sitting. You might want to also weld a bung on the right side pipe, in a similar location, and put a pipe plug in it for now. This way, you can occassionaly switch the sensor to the other bank, to see if there is any difference in A/F bank-to-bank, which there very well could be. I would bet that someone willing to spend the time to tune each bank seperately would find some hidden HP and fuel economy. __________________ 1999 Explorer XLT 4dr, 4.0L-SOHC, 5R55E Auto, A4WD K&N FIPK Cold Air--XCAL3 w/ custom tunes from Henson Performance On The Way: Gibson Cat-Back,U/D pulley,Professional Products Polished 70mm Throttle Body **Planned soon:80mm MAFS,Removal of the Cats,Electric Fan Best Time 15.87 e/t @ 86.6MPH in the 1/4 |
#4 |
Greenville, SC
2000 Sport SOHC 2WD
Thanks CarGuy3J!
Your information was very informative and helpful! I may mimic your installation.
#5 | |
Greenville, SC
2000 Sport SOHC 2WD
Only choice
#6 | |
Greenville, SC
2000 Sport SOHC 2WD
Confirmed your choice
Quote:
I will have my new bung inserted in the same location as yours - just downstream of the stock sensor. However, if the threads are the same, I will replace the stock sensor with the wideband sensor. I'll screw the stock sensor into the newly inserted bung. The wiring will be routed above the downpipe and thru the grommet that the speedometer cable passes thru. You can see the wiring harness is covered with heat shield sheathing in the vicinity of the downpipe. The AutoMeter A/F meter has no user Off/On switching capability. The meter automatically heats the wideband O2 sensor 20 seconds after the ignition voltage exceeds 13.5 volts. My ignition voltage is normally 12.6 volts when the engine is not running so the heater will not be activated until 20 seconds after the engine is started. __________________ My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank Last edited by 2000StreetRod; 10-12-2009 at 09:15 AM. |
#7 |
Greenville, SC
2000 Sport SOHC 2WD
Sensor installed
I finally finished my remote oil filters and coolers installation http://www.explorerforum.com/forums/...d.php?t=247990 and was able to drive to a local exhaust shop to have my wideband O2 sensor installed as shown below.
As planned I had the technician remove the stock sensor and screw it into the newly installed bung downstream. Then he installed the wideband sensor in the stock bung closer to the exhaust manifold. Both sensors were installed with antisieze compound applied to facilitate future removal. The photo below shows the functional A/F meter. I was surprised at how quickly after starting the engine that the A/F ratio increased from around 11.0:1 to 14.7:1. It was also interesting to notice the meter max out when letting off the gas and coasting in gear. I'll drive for a while in this configuration until I become familiar with the stock A/F ratio characteristics. Then I'll install my replacement intake system using a Lightning 90mm MAF sensor and my MAF sensor amplifier (MAFSAmp) http://www.explorerforum.com/forums/...d.php?t=249266 and compare the results. I anticipate the PCM generating some DTCs when I adjust the mixture to 20% rich and 20% lean when driving even though none were observed when the engine was revved to 5500 rpm while in Park. __________________ My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank Last edited by 2000StreetRod; 05-19-2010 at 04:08 PM. |
#8 |
Knoxville, TN
98 Mountaineer A4WD
Good work, I need to add a bung like that in mine also.
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
| Thread Tools | |
