doonze
- May 16, 2009
- Fayetteville, Ar
- '93 X Sport
Ok, so here is the entire story.
And just FYI, it's very easy when replacing the temp sender to also accidently unhook the fuel injector by accident. Makes the truck run funny, but it does run and throws no codes, just thought I'd share.
Ok, so anyway, to begin with I had a overheating issue. Many flushes later I was able to save the radiator and all had been well. About 2 weeks ago now I finally switched back to using Anti-freeze and everything has gone south since.
When I first switched i also replaced the sending unit for the temp needle, becuase at times it would swing some, worked like a champ for about 3 days.
3 days after switching to AF I walked out and found a puddle under the truck,(I found it seems to be leaking from what seemed at the time the middle of the radiator) I put some pepper in per many suggestions on many places I googled and drove onto work, my temp needle wouldn't sit still. Once it started to rise, it rose all the way to M/A, then fell back to N. Then kept swing back and forth the whole way. It would sit on N/O for about 5 seconds, rise slowly to M/A, stay there for about 3 seconds then fall back to N/O. Rinse, repeat, does this non-stop.
So, THIS weekend, I fired the truck up so I could use my portable air compressor to air up the car. While it was idleing (about 5 mins) I hear the sound of falling water, look over and coolant is pouring out of the radiator. Shut her down, pick up a new radiator and pull the old one. It's blown out the plactic on the inside of the tank right above the drain hole.
I replace the radiator and the thermostat that I had thought was clogged (causing my needle problem), and when I tested it out, still doing it, exactly like it was before. I also replaced the sending unit again just for giggles, still exactly the same.
It's so regular of a swing up and down, you could set your watch to it. It does slow down and speed up based on what seems to be RMP's. In other words, it stays still longer, and moves slower at 45 then say 75. But heat builds slower too.
As a side note, it has something to do with the stat (if the needle is correct), because I can go drive 200 miles and grab the radiator cap and it will be cool, and the tank will not be very hot, but the heater loop side of things will be hot as hell.
Only ideas I can some up with is my temp gauge needle went south at the same time the leak started, OR i have bubbles somehow in my coolant. I have no smoke(steam) in exhaust, no water in the oil or oil in the water. And when I burp it I can leave the funnel in forever and no bubbles come up, also no bubbling into the over flow.....
I'm stumped.....
Replaced so far: Radiator, temp sending unit, thermostat (2x)
I'm stumped.....
