Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Saginaw steering pump fluid type???
Reply
Thread Tools
Old 10-20-2009, 07:07 PM   #1
35Remmy
Binghamton NY, Hazleton PA, Northern NJ
'88,'99 Ranger, '00 EX
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys...I'm getting ready to install a saginaw pump (20-6244 heavy duty for a 79 F-250) into my Ranger ('99 4.0). Did pumps of this year ('79) use trans fluid like my current one does? I took the cap off of the new pump and there is definately what looks like trans fluid residual (it's red) on the inside.
35Remmy is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-20-2009, 07:16 PM   #2
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 300 Post(s)
...They did use ATF but, using a synthetic like Royal Purple or Red Line power steering fluid, from the beginning would help it live a long and healthy life...
...The following is from this thread...
http://www.explorerforum.com/forums/...&highlight=agr
Why did you use "Royal Purple" instead of ATF?
...Note found in box on install instructions...
"Use only clear, name brand, premium, racing or synthetic power steering fluid, such as Royal Purple or Red Line. Do not use transmission fluid, as transmission fluid does not contain the same friction inhibitors/additives and tends to breakdown and overheat. Use of transmission fluid will void warranty.
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 10-20-2009, 08:17 PM   #3
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
TBARS, but I'm using a Saginaw-brand pump, not an AGR pump. It's a totally different pump...Ford just added a different bracket to the "non-Ford" pump so it would work...look at this thread...
http://www.therangerstation.com/foru...d.php?p=526096
Maybe I'm misunderstanding you? That AGR pump does look sweet!
Old 10-20-2009, 08:45 PM   #4
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
...Your question was on the fluid and I have owned an F250 for every year from the 60's thru the eighty's...
...The emphasis of my last post was on the fluid and it's properties...I'm sorry if you thought I meant get an AGR pump....
.."Do not use transmission fluid, as transmission fluid does not contain the same friction inhibitors/additives and tends to breakdown and overheat."
...This thread also talks about the saginaw swap on a Bronco....
http://wt4x4.net/tech/saginawswap.htm
...If you start reading a couple paragraphs above the "Results" section at the bottom, you will see he used atf and Power steering fluid has better properties...The synthetics are better yet and he somewhat explains it...
...Bottom line:
1)ATF Type "F" is stock
2)Power steering fluid for replacement of Ford ATF type "F" is better
3)Synthetic power steering fluid is the best
...I hope this helps but I know Izwack has some better info on the Saginaw pump...
__________________
Old 10-20-2009, 09:12 PM   #5
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
TBARS...yeah, I misunderstood you!!! Thanks a TON for the information. I have searched everywhere and no one could answer my question. I really appreciate it!!! Now I just need to find synthetic power steering fluid!
Oh, I forgot to ask...is the fluid filter really needed? Did they come stock?
Old 10-20-2009, 09:29 PM   #6
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
...I found my synthetic at a local race shop but you can get Royal purple easier from most auto parts houses...
...Filter??? as in that threads diagrahm with the cooler also???...That's an option...
__________________
Old 10-21-2009, 05:55 PM   #7
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
TBARS...so I went looking for synthetic power steering fluid today at Advance Auto and they don't carry it anymore (Valvoline SynPower). I'll look more tomorrow. That's what I want to use, but don't know if it would be OK for my rack and pinion, although its all hydraulic fluid.
Mechanic at work thinks that since ATF Type F is stock that a full synthetic Mercon V would work fine.
He also mentioned to remember that my rack and pinion is full of Mercon V and it shares that same fluid with the steering pump...if I switched fluids, wouldn't I have to somehow drain the rack/pinion so I'm not mixing different fluids together?)
Old 10-21-2009, 06:02 PM   #8
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
...You should be fine with the Merc V...There is also talk about that on the first page of the first link I posted about the AGR..
__________________
Old 10-21-2009, 06:32 PM   #9
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Man, the obvious evades me. Thanks a lot for the enlightenment! I'll be sure to let you know how the install comes (next week, argh!!!). No time anymore. What happened to this world?!
Old 10-21-2009, 06:38 PM   #10
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
...Do a project thread on it...I am sure others would like info on how it is done...Be sure to take lot's of pics and post a link here...
__________________
Old 10-21-2009, 06:50 PM   #11
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yeah I totally will...I just have to get my wife to show me how to post the pics, heh. I've always wanted to do a how-to. Thanks again.
Old 10-22-2009, 06:13 PM   #12
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 223 Post(s)
I wish you well with that, do use the PS fluid instead of ATF.
I wish this would help me to use the Saginaw with my 5.0 or SOHC trucks. I know how good the Saginaw pumps are, I've got one somewhere for my old Ranchero.
I like the bolt on PS pulleys of my two trucks, but the PS pumps are not up to hard use. My SOHC truck is a mail vehicle, and I have heavy wheels on my 98 truck.
I appreciate the link showing the Bronco 5.0 stuff. I wonder if those brackets can possibly be cut and welded together with my brackets. I have to keep the AC compressor on the side, and the PS up top.
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is online now   Reply With Quote
Old 10-22-2009, 07:05 PM   #13
Tbars4
Tbars4's Avatar
Vehicle Specs
Quoted: 300 Post(s)
......Do I smell another project in the making???...
__________________
Old 10-22-2009, 07:19 PM   #14
35Remmy
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CDW, TBARS and I concluded that the Mercon V should work fine. The original fluid the Saginaw ran was Ford Type F transmission fluid, so there's no reason that a fully synthetic transmission fluid like Mercon V that my current steering pump/rack and pinion use should cause any problems, especially considering that I could run synthetic power steering fluid.
If I had a 78-79 (which I dream of having one day, fully restored!) I'd probably be using the Ford Type F fluid that it used from the factory!
What years were the Hi-boys built? Are they hard to find? What were the modifications from Ford?
Old 10-23-2009, 12:54 AM   #15
nitro71
Spokane WA
Vehicle Specs
Quoted: 0 Post(s)
Hmm, maybe I better quit using normal power steering fluid.. Mine leaks so fast it'll get cycled out anyways!
nitro71 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
