#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 Explorer blower motor-resistor help
Reply
Thread Tools
Old 01-18-2010, 01:25 PM   #1
sdh0001
Minnesota
2002 Explorer 4.6L V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have an 02 4 door 4.6l with the electronic climate controls. When I start up the car and turn the fan control to any speed except the very highest, my dash lights dim a bit and it seems like the motor is jammed or shorted. The moment i switch it to high, the motor kicks on, then I can go to all the different levels and it works fine.
So is there a resister pack I need to replace? Should I replace the blower motor? (If so, is there a post that explains how its done)?
Any help would be great!
I'm worried other things may short out if on low speeds there is a short.
sdh0001 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-18-2010, 04:04 PM   #2
RickM
'02 Explorer 4.6 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Did you do a search?
This thread should explain... http://www.explorerforum.com/forums/...light=resistor
__________________
'02 XLT 4.6 4x4
'85 Carrera Flatnose
'71 280SL Pagoda
RickM is offline   Reply With Quote
Old 01-18-2010, 11:55 PM   #3
sdh0001
Minnesota
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes I saw this post. Assuming is is the resister module is gives me enough info, but if I need a new blower motor do you know if there is a breakdown how to install it? In other words, does the whole dash have to come out? thanks
Old 02-03-2010, 05:17 PM   #4
Claus
Ames, Iowa
2003 V8 Eddi Bauer AWD
Vehicle Specs
Quoted: 0 Post(s)
I have the same/similar issue for a while on my 03 EB V8 with electronic climate control. The blower doesn't really blow until I turn it up all the way to high. In this really cold weather often the engine also needs to be warmed up a bit. On my car the air bag light dimly glows along with the other effects you saw. I haven't been able to track it down either but I can tell you it's a cold weather issue. In the summer you'll forget about it again until next fall. So far my car hasn't exploded because of it.
Claus is offline   Reply With Quote
Old 05-12-2011, 06:43 PM   #5
jsides
Eugene, Oregon
2004 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
Exclamation Blower motor or resistor problem
I'm having an issue with my 2004 Explorer, the fan won't blow for the driver/passenger but the auxiliary fan for the back seats does work. So are there 2 blowers or what? My fan won't even blow on High. Here is the link to my original post
http://www.explorerforum.com/forums/...d.php?t=316588
jsides is offline   Reply With Quote
Old 05-25-2011, 08:43 AM   #6
JChappy
Florida
01 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
I had the same problem on my 01 sport trac. The fans would only work on the highest settings. It turned out to be the blower motor resister a 16 dollar part for me and a couple of hours time. I found a you tube video from 1AAuto.com that walked you through it. The resister was rusted out. Not hard to replace at all.
JChappy is offline   Reply With Quote
Old 01-23-2013, 09:40 AM   #7
Rrunkle
2003 Limited
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Claus,
My 03 is having the exact same problem as yours with the airbag light also. See thread with my symptoms at the bottom.
I have NOT found the solution yet.
Rob
Rrunkle is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
