Gadget X
- March 13, 2007
- Gibsonville, NC
- '94 XLT 5-speed
I need help! (other than mental) Ok, here's the deal. I have been extremely happy with my explorer... until now. A couple of weeks ago, it started, well, just not running right. Then a couple of days after that it started really running bad! It doesn't idle as smoothly as it used to, and under a load, it misses, hiccups, sputters, loses power, and occasionally "backfires" in the manifold. It also seems like it is using a lot of gas. Also, if I am "easy" on the gas pedal it seems to run pretty much normally, so long as I don't push too hard on the gas pedal. It's just really annoying, and it seems like there should be some simple "fix" for this problem.
So far I have replaced the MAF sensor, plugs, wires, air and fuel filters, and the fuel pressure regulator.
I have checked the IAC valve, EGR valve, checked the fuel pressure (it's 30 PSI at idle), checked the TPS, checked the crankshaft position sensor (CMP?), checked for vacuum leaks, checked the ignition coil, checked for oil in the coolant and for coolant in the oil, checked that the injectors were firing, checked the codes (got only "pass" codes), sprayed some carb cleaner around the intake manifold to check for leaks there (just replaced the intake manifold gaskets 6 months ago).
If anyone has any ideas on what might be the problem with this thing, I would be eternally grateful!!
I have been messing with this thing long enough with no changes that I am starting to consider dousing it in gas and throwing a lit match at it!
It just really seems like there has to be some sensor or something that I'm overlooking. Is there a chance that the fuel pump is putting out enough pressure (30 PSI at the schrader valve), but not enough volume to keep enough pressure under heavier demand? Any help here would be great, I'm truly approaching my wit's end! Thanks!
