Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Another rear window problem
Reply
Thread Tools
Old 02-11-2010, 10:03 PM   #1
6OCTAGON
Rochester, NY
01 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
01 sport trac rear window not working. I dont know what to do next. I checked all the fuses went through all the test procedures. I just bought a used window motor (maybe a mistake) and it still isnt working. I can not get the initialization procedure to work. Has anyone one seen this TSB #03-19-5 that says the door needs to be open and closed at certain times?
2003 Ford Explorer Sport Trac - REAR WINDOW INITIALIZATION, by PAUL CMAT
HERE’S A TIP. Explorer Sport-Trac. After installing a rear window motor and regulator, the motor has to be “REINITIALIZED” or it won’t work. After trying the procedure probably 10 times and it not working (It would run through procedure, but as soon as the key was shut off the window would be in-op) Had to take a break. Looked up TSB,s. One was #03-19-5. IT explained procedure a little differently. It involved opening and closing driver door at different times. (Other one in window article simply states “Open drivers door) The TSB procedure worked first time! Keep this in mind or it just might drive you CRAZY! YUP.
Subject: REAR WINDOW INITIALIZATION
Vehicle: 2003 Ford Explorer Sport Trac
Category/Subcategory: Accessories and Equipment / Windows
Title/Heading: GLASS, FRAMES AND MECHANISMS / DIAGNOSIS AND TESTING -> Glass, Frames and Mechanisms - Window Control -> Pinpoint Test -> Pinpoint Test K: The Power Rear Window Is Inoperative (Explorer Sport Trac Only)
Shop: HARRIS TIRE AND AUTO FIRESTONE
Posted By: PAUL CMAT
Date: 1/23/2008
6OCTAGON is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-11-2010, 10:36 PM   #2
cknox69
Knoxville TN
'01 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
Ya mine has just started acting up also. It will vent and roll up from vent but will not roll down at all! I also checked all the fuses and they are all fine. I am thinking its probably a faulty switch but could use any advice.
__________________
01 Sport Trac
3'' Bodylift, 2" Torsion TwEaK, 2" Shackles
33 x 12.5 Toyo Open Country
cknox69 is offline   Reply With Quote
Old 02-12-2010, 05:41 AM   #3
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
It doesn't say anything about that.
TSB 03-19-5 BODY - POWER REAR WINDOW BOUNCES BACK OPEN WHEN CLOSING
ELECTRICAL - POWER REAR WINDOW BOUNCES BACK OPEN WHEN CLOSING
Go here and read #3 and follow the directions. Diagnosis info is included there too.
http://www.explorerforum.com/forums/...d.php?t=238632
I'll ask John to include that TSB in the FAQ thread.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 02-12-2010, 06:30 AM   #4
John_Rock
Elite In Memoriam
Houston, TX
John_Rock's Avatar
2001 Sexy Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
Done.
http://www.explorerforum.com/forums/...72&postcount=1
__________________
John_Rock - Mugshot - Click Here For info on my 2001 Sport Trac 4x4
- 2000 Explorer Limited AWD, 5.0L v8; 4.10 gears, KKM True Rev filter, B&M Tranny Super Cooler, Aux. Tranny Filter, Autometer Tranny & Water temp gauges.
Demon4x4.com
John_Rock is offline   Reply With Quote
Old 02-12-2010, 07:21 AM   #5
6OCTAGON
Rochester, NY
01 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks!!!! I will try this, this afternoon.
Old 02-12-2010, 08:08 AM   #6
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
Just follow this one to the letter and it should work. I had my window out and it worked the first time after going through these instructions. You only have to open the door as part of the first step.
__________________
How to post photos
Old 02-12-2010, 12:47 PM   #7
6OCTAGON
Rochester, NY
01 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I guess i was sold a bad motor because it still dont work. I did both version of the initialization and got nothing. I put the old motor back in and tried the alternate version in the TSB and i almost go some movement. I got to the part were you hold the up position till it times out i can hear that it moved up about a 1mm then stalls. Then i turn it to the down position and nothing happens. I tried holding it for over 30 sec. Here is the motor i bought.
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1576wt_867
Old 02-12-2010, 12:53 PM   #8
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
Are you sure the glass is not binding or that the regulator cables aren't broken?
__________________
How to post photos
Old 02-12-2010, 01:00 PM   #9
6OCTAGON
Rochester, NY
01 Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Everything looks good. I moved the window up and down about an inch when i pulled the motor. Does the window have to be down a little when you initialize? Mine is up all the way. Weird that the new won does nothing. The old one i think will go up but like i said it is all the way up now. I called them and they said they would send me a new motor. But what a pain in the butt. I just want to make sure im not missing something before i send back this motor.
Old 02-12-2010, 01:08 PM   #10
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
Mine was all the way down when I started because I had dismantled and removed the whole assembly but I don't see anywhere it states what position the glass has to be in to begin the process.
__________________
How to post photos
Reply
Tags
rear window motor sport trac
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
