Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Headlight relay location
Reply
Thread Tools
Old 04-16-2010, 07:16 AM   #1
po-po 5.0
Houston, TX
'98 5.0 EB 2WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Just got pulled over for no headlights. I can't imagine that BOTH lamps went out at the same time so where's the headlight relay? The stupid owners manaul lists it in slot 11 in the power distribution box..................except the part where there IS no slot 11.
po-po 5.0 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-16-2010, 08:15 AM   #2
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
IF you have autolamps, the relay is in the relay module (dash area).... BUT if you don't have autolamps, then there ain't no relay.
budwich is offline   Reply With Quote
Old 04-16-2010, 07:49 PM   #3
po-po 5.0
Houston, TX
'98 5.0 EB 2WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
It has autolamps, but there doesn't appear to be any relays in the fusebox on the side of the dash.
Old 04-16-2010, 09:04 PM   #4
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
not the fuse box... center / under of the dash
Old 04-17-2010, 12:43 AM   #5
Delonybro
Abilene, TX
2000 XLS 2WD
Vehicle Specs
Quoted: 0 Post(s)
On my 2000 XLS, when 1 bulb dies, the other one fails to turn on. I learned this the hard way in the middle of nowhere 30 miles from home and had to limp home on just the fogs. I just replaced the bad bulb and all was well, I did not have to replace both. Don't know if this is normal or just my X but it's an idea for you...
Delonybro is offline   Reply With Quote
Old 04-17-2010, 06:31 PM   #6
strizzlow20
Sebastian, FL
1998 Explorer 4X4 SOHC
Vehicle Specs
Quoted: 2 Post(s)
I had an issue with my headlights only the brights would work and eventually they went out as well. The issue was with the multi switch. When I asked my mechanic to change that (which I should have did myself) he said he didn't think that would fix the problem. It did fix the problem and both headlights and high beams worked. Im not sure if this is the issue but its worth a shot.
strizzlow20 is offline   Reply With Quote
Old 04-18-2010, 08:43 AM   #7
po-po 5.0
Houston, TX
'98 5.0 EB 2WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So you're saying I need to yank out the center console to get at it?
Old 04-18-2010, 12:03 PM   #8
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
There is a headlamp relay in the Power Distribution Box under the Air Filter box, mounted to the Air Box Plate.
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 04-19-2010, 07:51 AM   #9
po-po 5.0
Houston, TX
'98 5.0 EB 2WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Ryan
Alright. I will look there.
Old 04-19-2010, 09:43 PM   #10
mic98xlt
West Haven, Ct.
mic98xlt's Avatar
98 XLT
Vehicle Specs
Quoted: 14 Post(s)
Do you have the "message console" in the center of your floor console. If so the common problem is the circuit board on the "lights out module" (LOM). The circuit board goes bad and basically it leaves an open circuit causing head lights to go out. There are many "LOM" repair threads if you do a search here on Explorer Forum. Good luck.
mic98xlt is offline   Reply With Quote
Old 04-19-2010, 10:05 PM   #11
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
I was slow... just answering the "where the headlamp relay"? instead of thinking about the actual problem (no lights).... but of course, you are right.... its a LOM issue (EB standard option).... BUT that's if the headlamp relay is OK.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
