manaen
- February 27, 2007
- Clear Spring, MD
- 2011 Xterra Pro-4X
OK so I have been gathering parts together for my project over the past few months. Things got delayed a bit since apparently Maryland now gets as much rain as London, or so it seems.
The Goal of this project: give me a slight bit more lift to even out my wheel wells and provide tire/ground clearance. Also, need to repair some damage incurred over the winter..
I have finally found the time and dry weather to start the largest portion of my build which was my low budget body lift, and a custom offroad bumper.
So it all started the other night with the Body Lift First lets cover logistics. I wanted to add 2" only, just to add a little frame clearance. I did not want to go higher than that since I tow regularly and did not want to raise the weight too high on the frame. As I was planning it out, an idea hit me to just purchase 3" lift blocks and cut them in half. This would give me 1 1/2" of lift which was exactly what I was looking for. Additionally it saved me a bundle because all the 2" lift blocks I found were basically the same price as the 3" so this cut costs in half!!
So here is the bottom line on the lift
6pcs 3" lift blocks w/ shipping $27.50
6ea 12mm bolts - $12.00 (more about this later)
Ok so here are the parts (minus 2 bolts they came later...)
There is not much to tell about the lift really. I had the whole thing installed and on the road within 2 hours. It was really quick for a few reasons. First, I have a electric fan installed so I didn't need to worry about the radiator. Second, with only 1.5" of lift you don't need to worry about things like steering linkage, and shift linkage. Third, my bumpers are not a concern at this point since I will be making an entirely new front bumper as the next part of the build. Last, I found the bolts locally so I could run and pickup additional parts quickly.
Some of you may remember this diagram that I made for the body lift bolt positions (it's linked in the sticky). The bolt lengths were from the body lift sticky I just plugged in the numbers into the diagrams. Well something was slightly different on my truck.
Here is what I ended up with for bolts
P5 - 12mm x 150mm new
P4 - re-used P5 bolts (124mm stock)
P3 - re-used P1 bolts (104mm stock)
P2 - 12mm x 120mm new
P1 - 12mm x 140mm new
Here are some shots of the bolt locations
This is P5 it is located under the plastic hatch trim
This is P4 it is located behind the rear seat
This is P3 it is located just behind the front seats
This is P2 it is under the carpet in the front foot well
Sorry no picture of P1 but if your next to your truck just bend over and look up it is visible just behind the front bumper...
More to come in the next section....
On to the Custom Bumper..
