2000 Ford Explorer - Defrost Only | Ford Explorer Forums
Stefanlg55
Middleborough, Ma
2000 Explorer Police Pack
On my 2000 ford explorer only the floor and defrost vents work? The vents that blow on your face do not. I can switch between Ac/Head fine, and i can set how high or low it blows. But for some reason it only works on the floor and defrost. Does anyone know how to fix it?
You have a vacuum leak, broken or burned vacuum hose or pulled off somewhere. Or broken linkage or vacuum motor. Possible vacuum switch. The vents are controlled by vacuum motors that open/close plenum doors. Check under the dash and under the hood.
You'll solve your problem here. (been there, done that).
(the search tools are your friends).
Welcome to the site. Lots of stuff in the archives if you have other Exploder issues you want to resolve.
thanks celly for the thread. I had two broken lines on near the vacuum reservoir got it working now and probably saved over $100 easily :)
