Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Best method to replace spark plugs on 98 Mercury Mountaineer V8 5.0??
Reply
Thread Tools
Old 11-27-2010, 05:08 PM   #1
mikey4040
New England
98 Mountaineer V8 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I want to attempt this this week. I've read many different threads of different ways on doing this job. Some people jack up the front and remove the tires and rubber splash guards. Some people pop the hood and do it right inside the engine and others do it from the wheel area without removing the tires or opening the hood. So my question is what's the easiest way to do it without the need of a swivel attachment cause i don't have one the only tool i don't have to do this job. Also can you use those basic Autolite Copper 764 Spark Plugs on this truck? I don't use this truck that much i drive my Lexus more often but the winter is coming so I'll be using it now for the next few months Thanks..
mikey4040 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-27-2010, 05:37 PM   #2
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
I always do them from the wheelwell area, you can probably get away with no swivels also depending on length of extensions used.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 11-27-2010, 06:51 PM   #3
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Vehicle Specs
Quoted: 465 Post(s)
Wheelwell area. Take the wheels down, makes it easyer and is not hard to do. Swivell and extension will help.
Do NOT use copper or even single platinum plugs, like the 764 or AP764, you need at least dual platinum APP104 or better the iridium/platinum XP104.
SoNic67 is online now   Reply With Quote
Old 11-27-2010, 07:25 PM   #4
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
Quote:
BS! There is not a thing wrong with running a copper plug in a 5.0. All I run is copper in my 97 Mountaineer and I have NEVER had a PROBLEM.
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Old 11-27-2010, 07:31 PM   #5
techieman33
Topeka, KS
techieman33's Avatar
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Copper is just fine, actually better than the platinum plugs. The only problem with the copper plugs is they don't last as long.
techieman33 is offline   Reply With Quote
Old 11-27-2010, 07:32 PM   #6
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
Stay away from Bosch plugs and wires. Never hear anything but bad news about them on these forums. Autolite and Motorcraft have good reviews on here usually.
__________________
There is wisdom to be found in the counsel of many.
OneLever is offline   Reply With Quote
Old 11-27-2010, 08:46 PM   #7
mikey4040
New England
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Alright thanks for the replies so jacking up the front and removing the tires and splash guards is the best bet it looks like. I'll just use those copper Autolite as long as they last at least 25,000 miles I'll be happy. The truck has 143,000 right now and i don't expect to have it much longer than another 25,000. I have 3" and 6" extensions and the 5/8 plug socket with a 3/8 ratchet and a 3/8 breaker bar if needed. I should be able to get the job done with the following you think?
Old 11-27-2010, 08:49 PM   #8
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
these v8's are good for 200k miles plus with basic maintenance
Old 11-28-2010, 12:11 AM   #9
celly
disturber of the peace
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
Quoted: 6 Post(s)
Quote:
Precisely.
Plats just last longer. Nothing more.
Posted via Mobile Device
celly is offline   Reply With Quote
Old 11-28-2010, 12:49 AM   #10
97 EB Mike
Ohio
97 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I used a swivel to get to mine from the wheel well area. They're not too expensive, and not a bad tool to have in your box for future use too. I didn't have to pick the truck up at all, let alone remove a wheel, but I'm also running a 2" TT which helped with clearance. I also had some insulator sleeves surrounding the plug. They basically look like an overgrown roll pin. They just pull out, but mine being an Ohio truck, it took some fairly serious pulling to get a couple of them out. Vice grips did the trick, but I cracked the porcelain on the plug in the process. I don't know if the 98s have the same sleeve or not. They're not a big deal, just a little time consuming and something to be aware of.
__________________
97 EB 5.0 TT AAL 32x11.5 Sadly, sold.
"Prudence" 95 Ranger 2.3 5 speed gas sipper
If it doesn't fit, force it. If it breaks, it was gonna break anyway...
97 EB Mike is offline   Reply With Quote
Old 11-28-2010, 01:00 AM   #11
techieman33
Topeka, KS
00 V8 Mountaineer
Vehicle Specs
Quoted: 3 Post(s)
Quote:
I can change mine on my lowered 2" mountaineer with 30" tires, but for a first timer it will be nice to have the extra room so they can see what they are doing.
Old 11-28-2010, 08:08 AM   #12
JOHN223
NY
'98 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Howdy! Just replaced plugs on my 98 5.0 ex. Did not even have to jack up the car, just removed the splash guards. Make sure you have the correct size plug socket. A short and a long extension and a u joint help. I tightened the new ones by hand without the wrench for fear of cross threading, then gave a final tightening with the wrench. Do one at a time. I used the auto lite double platinum - they have a rebate until the end of the month on them check their website. I believe the gap is 0.54". thought the truck is 12 years old, it has only 64k miles on it. Made a noticeable difference. Good luck!
JOHN223 is offline   Reply With Quote
Old 11-28-2010, 08:16 AM   #13
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
Quoted: 0 Post(s)
The most pain-free method is to remove the front tires and go thru the wheel well. Unlike the SOHC or OHV, all the plugs are right there ready to be removed. Let me say that using a swivel extension makes things that much easier....it's a good investment and you'll find yourself using it on a lot of other things as well.
__________________
1996 Explorer 5.0 V8 - TT/shackles, 31" BFG A/T - Registry thread
2005 Mustang GT - Sonic Blue
Hartman is offline   Reply With Quote
Old 11-28-2010, 08:55 AM   #14
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
I second taking off the plastic well wheel covers and splash guards. They're held in place by maybe six screws and after they're off you can access anything. I had a hard time getting 0.54" spark plug adjusters except for the little continuous circle kind. The wire gauges work better but they don't carry them in that size around here.
What kind of anti-seize do you guys use on the plugs? The copper based Napa stuff or regular silver colored Permatex?
__________________
Old 11-28-2010, 09:40 AM   #15
celly
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
Quoted: 6 Post(s)
I'm a horrible mechanic, but I find the plug change on the 5.0 to be simple. I just remove the soft spash shield and leave the wheels on. The plugs are pretty much right in front of you. I use a standard plug socket and make good use of some long wobble extensions I scored from the parts place in the US when I was there last summer.
Dead simple.
Thanks Eric (Techie) for showing me how easy it was just before we left Humboldt for Topeka. While removing the hard plastic wheel well liners would make it easier, it looks like a hassle getting those back in so why bother when you don't have to? Same with the wheels.
__________________
'99 EB
5.0 AWD, Torque Monster Headers, 1" Trick Flow UI spacer,
Custom Volant based CAI (incl C&L MAF body),
SCT XC2 w/Henson tunes, Flo Pro catback, EE swaybar & airdam, Morimoto HID projector retrofit (4300K), Bilstein shocks, Powdercoating by Turdle, Amsoil everywhere, other stuff.
Quote:
I didnt even waste my time to read that, nor will I, however I read some of it.
I, I, I, Me! Me! Me!,
Craigslist Scams for Dummies, Don't Be a Wannabe.
Old 11-28-2010, 10:20 PM   #16
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
If you remove the rubber splash guards, that will be enough to get in there.
Hint: Change the plugs and the corresponding wire one at a time. It'll save the hassle of worrying about firing order on the coil.
This was my '97 for hints:
(And what came out to put in my Motorcraft Plats...)
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 06-11-2015, 11:39 AM   #17
Dovii
Melrose, Wisconsin
1999 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
This video explains it all:
https://www.youtube.com/watch?v=V0RP7HXUMIs
Dovii is offline   Reply With Quote
Old 06-11-2015, 12:43 PM   #18
Dan Whitaker
One fast putty tat
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
Quote:
Originally Posted by Dovii View Post
You're 5 years too late. The OP hasn't posted since Nov 2010.
__________________
Old 06-11-2015, 03:27 PM   #19
Dovii
Melrose, Wisconsin
1999 Explorer XLT
Vehicle Specs
Quoted: 3 Post(s)
I don't understand. Please explain.
I mean, if you think I shouldn't have posted this because the discussion ended five years ago and nobody cares anymore, you may be wrong. I found this thread because I looked at the difficultly at reaching some of the spark plugs and searched this forum for advice.
I am sure other people who need advice about this subject will do the same.
Is there a deadline for giving advice on changing spark plugs on a 5.0 engine? If there is, I apologize.
Old 06-11-2015, 07:21 PM   #20
bill06447
Connecticut
1997 Explorer XLT 5.0 AWD
Vehicle Specs
Quoted: 147 Post(s)
Just did my plugs a couple days ago. All you need is a 5/8 plug socket and a long (18") extension. Go through the wheel wells, no jacking necessary. I only had to pop off two of the plastic retainers holding the splash shields on. The most difficult part was releasing #4 plug wire from the solitary loom that sits under and behind the HVAC box.
Bill
__________________
1997 Explorer XLT 5.0 V8 AWD 187k
1986 F150 4x4 300/4 spd 128k
1978 Eldorado Biarritz now with 8.2L EFI
2005 PT Cruiser 2.4T 86k
1991 Winnebago/GMC 7.4L 109k
bill06447 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
