It's officially called a CMP Syncronizer.
There are stern warnings on the page associated with this.
CAMSHAFT POSITION (CMP) SENSOR
Removal & Installation
CMP sensor is located on rear of engine, behind intake manifold. Before removing, note position of electrical connector on CMP sensor. Remove upper intake manifold. See UPPER INTAKE MANIFOLD . Disconnect CMP sensor. Remove CMP sensor screws and CMP sensor. To install, reverse removal procedure. Ensure CMP sensor electrical connector is pointing in original direction. Tighten CMP sensor to specification. See TORQUE SPECIFICATIONS .
CMP SYNCHRONIZER
CAUTION: Synchro Positioner (T95T-12200-A) is required to properly install synchronizer. See Fig. 2 . Failure to use synchro positioner during installation will cause fuel injection to be out of time and may cause engine damage.
CAUTION: DO NOT rotate crankshaft when Synchro Positioner (T95T-12200-A) is positioned on CMP synchronizer. Armature tab will be damaged and synchronizer timing may be shifted.
Removal
1. Position crankshaft to TDC of cylinder No. 1, on compression stroke. Note position of electrical connector on CMP sensor.
2. Disconnect negative battery cable. Unplug harness connector from CMP sensor. Remove CMP sensor screws and CMP sensor from positioner. Remove synchronizer hold-down bolt and CMP synchronizer.
Fig. 2: Exploded View Of CMP Synchronizer Assembly (Typical)
Courtesy of FORD MOTOR CO.
CAUTION: DO NOT rotate crankshaft while synchronizer is removed from engine.
Installation
1. Install Synchro Positioner (T95T-12200-A) on synchronizer housing. See Fig. 3 . Rotate synchronizer shaft until vane on shaft aligns with slot on synchro positioner. Rotate synchro positioner until engaged into notch in housing. Dip drive gear in engine oil.
Fig. 3: Installing Synchro Positioner On Synchronizer Assembly (Typical)
Fig. 4: Positioning Synchronizer For Installation
2. Rotate sychronizer assembly so that synchro positioner is 60 degrees counterclockwise of crankshaft centerline before inserting synchronizer assembly into engine. See Fig. 4 .
3. As synchronizer is inserted into engine, synchronizer will rotate. When seated, synchronizer electrical connector should be located in original position.
CAUTION: If CMP sensor electrical connector is not positioned correctly, DO NOT reposition connector by rotating synchronizer. This may cause fuel system to be out of time with the engine, causing possible engine damage or an engine misfire. Remove synchronizer and reinstall. See step 3 .
4. Install hold-down clamp and tighten bolt to specification. See TORQUE SPECIFICATIONS . Install CMP sensor to synchronizer and tighten to specification. Ensure CMP sensor electrical connector is in original position. Reconnect wiring to CMP sensor. Connect negative battery cable.
