jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
so i finally got around to doing my 2nd gen axle swap into my 92.its out of a 99 explorer.im putting 4.88 yukon gears,timken bearing and R1 brakes into it,all new.im also swaping out the MC to a 95 with NO ABS and NO proportioning valve and putting pro comp springs in.i sandblasted and coated it with truck bed liner and the sprayed it with the same colors as my motor!!on to the pics,witch do it NO justice!!any questions just ask and MANY THANKS to Boomin as he helped alot with this swap!!!!
out with old!!
yes its snowing wile im doing this and 27* without wind chill!!!!
in with the new
this is how i got the paint to dry,army cover and a heater for 3 hours!!!
meaty
and how i did the brake line,i extended it 8" and hook it to a spring,under full droop it wouldnt fit
ill post a final pattern when i get it all the way set up and a pic of it in the truck!!
out with old!!
in with the new
meaty
