Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
Airbag Code 44
Reply
Thread Tools
Old 02-23-2011, 06:03 PM   #1
blueka
Elite Pickler
Saskatchewan, Canada
blueka's Avatar
97 UK XL & 99 Sport V8
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
Airbag Code 44
Had the airbag light flashing a code 4 4
I replaced the front right airbag sensor behind the front bumper and I'm still getting the same code.
Any suggestions? It's gotta pass a safety.
Si
__________________
'97 Explorer XL 4.0 SOHC V6 "Betty"
'99 Explorer Sport Limited 5.0 OHV V8 "Pickle"
My "Betty" Registry My "Pickle" Registry
blueka is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-23-2011, 08:14 PM   #2
TxPlates
Marble Falls, TX
TxPlates's Avatar
2001 "Rock Trac"
Vehicle Specs
Quoted: 3 Post(s)
The control module may be the point that is failing. I assume you disconnected the battery when you installed the sensor? My other suggestion would be to make sure all wires are secure and if so, start looking for a new control module.
TxPlates is offline   Reply With Quote
Old 02-23-2011, 08:48 PM   #3
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
Which of your listed vehicles are we discussing? The codes mean different things.
1997 44 RH Air Bag Sensor Not Mounted to the Vehicle Properly or Ground Circuit Open
1999 44 Driver Side Crash Sensor Communication Fault (Id think this was assuming left hand drive)
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 02-23-2011, 08:53 PM   #4
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
it's a 2000 EB that i'm working on.. It's left hand drive..
Si
Posted via Mobile Device
Old 02-24-2011, 10:05 AM   #5
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
I'll try replacing the driver's side sensor see if that helps....
Si
__________________
Old 02-24-2011, 12:44 PM   #6
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
I've changed D/S side impact sensor, still flashing 44
Si
__________________
Old 02-24-2011, 01:31 PM   #7
cybergasm
B
Humboldt Ks
cybergasm's Avatar
1997 Mountaineer 5.0
Vehicle Specs
Quoted: 0 Post(s)
well check/change the RH side one like we discussed earlier. pretty sure it is the one causing the problem here
cybergasm is offline   Reply With Quote
Old 02-24-2011, 01:55 PM   #8
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
I've changed the front passenger side sensor and the driver's side side impact sensor.
still got the 44
Si
__________________
Old 02-24-2011, 03:08 PM   #9
cybergasm
B
Humboldt Ks
cybergasm's Avatar
Vehicle Specs
Quoted: 0 Post(s)
are ya making sure they level with the vehicle ? have seen some stuff about if you so much as bump off level that will trigger a code
Old 02-24-2011, 03:12 PM   #10
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
I've bolted them back up, and got the marker pins lined up... not sure what else to do...
I've just taken the steering wheel airbag off now, gonna see if resetting the clock spring helps...
Si
__________________
Old 02-24-2011, 05:39 PM   #11
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
Why was this moved to the modified section? it's a totally standard 2000 EB... no mods
I've removed/replaced D/S airbag, D/S side impact sensor and the P/S front airbag sensor... still flashing....
Si
__________________
Old 02-26-2011, 10:38 PM   #12
k-pendow
Northwest Indiana
95 Ranger
Vehicle Specs
Quoted: 0 Post(s)
I know its obvious but did you check to make sure the pins in the connector are not green, also I would pull back some of the convoluted wire tubing and check to make sure the wires are good for at least the first 6 inches. After that you need to ohm out the wires from the sensor to the module, at module pins 8 & 9 (with release tab up it is the two bottm right pins, should be less than .5 ohms, also check them for a short to ground or battery voltage. Also the code is for the side crash sensor mounted to the B pillar in the truck not the ones one the core support. You could probably swap them from side to side to see if the concern follows the sensor. If wires test good and it doesn't follow the sensor then it would have to be the Restraint Control Module.
k-pendow is offline   Reply With Quote
Old 02-27-2011, 06:46 AM   #13
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
Quote:
YES, Correct.
__________________
How to post photos
Old 02-27-2011, 10:08 AM   #14
MNBen
Cosmos, MN
99 Ranger 4x4 XLT Ext. Ca
Vehicle Specs
Quoted: 0 Post(s)
I've read some threads that there may be issues in the seat/seatbelt wires. One user just had to wiggle them. Another user had it happen to her but not her husband, turned out they have the seat adjusted differently which triggers the light for her but not him. Wires were kinking.
My two cents. Good luck.
MNBen
MNBen is offline   Reply With Quote
Old 02-27-2011, 12:29 PM   #15
blueka
Elite Pickler
blueka's Avatar
Vehicle Specs
Quoted: 66 Post(s)
(Original Poster)
the seatbelt wires were snapped, so I rewired them
but the light was flashing 4 4 before that and after that too
Si
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
