2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Listed below are Ford part numbers for SOHC V6 timing chain related components. I try to keep this list current. Two possible discount online Ford OEM suppliers are tousleyfordparts.com and tascaparts.com
Jackshaft/primary timing chain kit 2U3Z6D256CA includes:
Crankshaft bolt harmonic balancer E7RY6A340B
Tensioner-engine jackshaft chain YL2Z6L266AA
Gasket-cylinder/timing front cover F77Z6020AB superseded by 1L2Z6020AA
Sprocket/gear-engine jackshaft/intermediate 2U3Z6M264AA
Guide-engine jackshaft chain 2L2Z6K297AA
Bolt-jackshaft sprocket bolt F77Z6M264BA superseded by 2L2Z6279AA (included when 2U3Z6M264AA is purchased)
Sprocket/gear-crankshaft two wheel drive 2L2Z6306BA
Chain-engine jackshaft F77Z6268AB
Bolt-right camshaft sprocket F77Z-6279-AD
Bolt-left camshaft sprocket F77Z-6279-CB
Left/front timing chain cassette assembly 7U3Z6A257A thru 2006, 7L2Z-6M289-A for 2007 thru 2010 includes:
Timing chain
Guide assembly YL2Z6M273AA superseded by 7U3Z6A257A
Bolt-guide assembly upper mount
Sprocket/gear-camshaft
Sprocket/gear-jackshaft front
Right/rear timing chain cassette assembly 4L2Z6M290AA includes:
Timing chain
Guide assembly
Sprocket/gear-jackshaft rear
00M12 intake manifold kit YL2Z9E473AA includes:
Lower intake manifold gasket set of six YL2Z9461AA
Upper intake manifold gasket set of two YL2Z9E436AA
Left timing chain tensioner 7U3Z6K254B
Tensioner metal O ring XU2Z6M252AA
Oil restrictor
Galley plug
Right timing chain tensioner 7U3Z6K254A supersedes XU3Z6K254BA
Right timing chain guide assembly upper positioning bolt F77Z6U000BA
Jackshaft rear sprocket retaining bolt W703167S430
Cover assy/rear of block jackshaft opening plug F77Z6026AB
Left cassette assembly lower mounting bolt W500100S300
Jackshaft chain guide mounting bolt W500100S300
Sprocket/gear-crankshaft inner four wheel drive F77Z6306BE
Sprocket/gear - crankshaft outer four wheel drive 2L2Z6306AA
Balance shaft chain guide F77Z6K297BC
Balance shaft chain tensioner 1L2Z6L266AA
Balance shaft chain F77Z6268BC
Balance shaft assembly 1L2Z6A311AA
Seal-front timing cover E6TZ6700A was superseded by 5H2Z6700AA
Seal-rear main crankshaft F5TZ6701A
Gasket set-valve cover F77Z6584AE
Gasket-lower oil pan 4L2Z6710AA year 2000+ F77Z6710BA year 1997-1999
Gasket-upper oil pan/reinforcement section F77Z6710AA
Block cradle retaining bolt seal F77Z-6734-AB (Listed as engine oil drain plug gasket)
Left camshaft F7TZ6250AEE was superseded by 7L2Z6250D
Right camshaft F77Z6250AE
Exhaust manifold outlet bolts (M12-1.75X54.5 H) N811747S2
Timing chain
Timing chain
Guide assembly
Oil restrictor
Galley plug
