mac999993
- June 6, 2006
- Newtown Square, PA
- 02 XLT
I have been looking through the forum for a few days to figure out what is causing the steering on my 2002 Explorer XLT to wander when driving "straight", and particularly noticebale at higher speeds...say above 40 MPH. I noticed that when turning very slightly to the right or left the wandering does not exist. If am lucky enough to "quiet" down the wander by making slight wheel adjustments, it can be easly set off again from a bump in the road. It feels very unstable.
Based on the posts that I read (most of them I listed below for future readers) I've used to trouble-shoot:
I lifted the front end up:
Checked all my suspension components:
- upper and lower ball joints- and they are very solid on both sides.
- I pulled each tire from top and bottom - no looseness, and front and back - again, no looseness.
- the sway bar links are new - I replaced them a few months ago.
I also checked the steering linkage componenets - and they all appear solid as well.
- no looseness when I push or pull each wheel from under the vehicle. I tugged on each tie-rod (Left and right), inner and outer, and they are solid.
- I had my daugher get in the vehicle (with the engine off) and turn the wheel one rotation to the left and then to the right several times, while I put resistant pressure on both tires (while laying in the middle under the vehicle), and I felt no looseness or sloppiness whatsoever.
I am curious if the gear box (rack and pinion) is bad. With the engine off and turning the steering wheel left and right (as mentioned above) I didn't feel or see any sloppiness... could it still possibly be bad? I have read that earlier Explorer gear boxes (rack & pionion), have a gear wear adjustment on them. Does the 2002 gear box have one? It sounds like a remove and replace of the gear box is a pain, so I want to make sure that it is the problem before taking it out.
The XLT has a little over 141K miles, and all the suspension and steering components are original...but are still solid from what I can tell - I've been pretty careful to keep all the components lubed regularly.
Any other diagnostic tests that I can try?
Are there any available diagrams or pictures to show the remove and replace steps of the gear box (rack and pinion)?
Thanks for any help. I still have my car up on stands...
Reference Links:
Problem Removing Steering Rack http://www.explorerforum.com/forums/showthread.php?t=96196&highlight=remove+steering+gear
Removing Steering Rack from Vehiclehttp://www.explorerforum.com/forums/showthread.php?t=124961
How to: Rack & Pinion Removal:http://www.explorerforum.com/forums/showthread.php?t=150850&highlight=remove+steering+gear
How to Remove and Replace Steering Gear Box:http://www.explorerforum.com/forums/showthread.php?t=301428&highlight=remove+steering+gear
2002 Explorer Steering Assembly Parts Diagram - Parts:http://www.parts.com/oemcatalog/ind...2830&callout=1&catalogid=2&displayCatalogid=0
2002 Explorer Suspension Assembly Parts Diagram - Parts:http://www.parts.com/oemcatalog/ind...070&callout=12&catalogid=1&displayCatalogid=0
2002 Explorer Power Steering System Diagnosis & Diagrams: http://www.scribd.com/doc/14896083/2002-Explorer-Power-Steering-System-Diagnosis
Explorer Steering Problems - Diagnosis: http://www.carkb.com/Uwe/Forum.aspx/car-maintenance/11474/2000-Ford-Explorer-Steering-Problem
Wandering Steering: http://www.explorerforum.com/forums/showthread.php?t=237079&highlight=steering+wander
Wandering Steering: http://www.explorerforum.com/forums/showthread.php?t=240749&highlight=steering+wander
Loose Steering: http://www.explorerforum.com/forums/showthread.php?t=169840
Replace Steering Box: http://www.ehow.com/how_8003144_replace-steering-box-ford-truck.html
Signs of a bad Steering Rack and Pinion: http://www.ehow.com/list_6458927_signs-bad-steering-rack-pinion.html
How to Diagnose Power Steering Problems: http://www.ehow.com/video_5103506_diagnose-power-steering-problems.html
Reference Links:
