How To: Fix ARB Awning on 4th Gen OEM Roof Rack | Ford Explorer Forums
The Electrician
Makkah
2008 XLT 4WD V6
Hi ever one
Here are the photos of the mounts that I made to fix ARB Awning on 4th gen Explorer OEM Roof Rack
I fixed the Awning using 2 mounts
each mount consists of 2 pieces
one is made of 1/8" galvanized sheet and the small one is made of 2/8" steel sheet
a thread should be made in the small piece
they are overlapping on each other
and a head of a bolt should be inserted inside the awing rails
then you need to remove the back corner of the roof rack
remove the crossbar and crossbar mount
the small piece should be inserted in side the roof rack rail and then a bolt should fix the large piece to the thread within the small piece
this is the front mount
this is the rear mount
and voila
and that's all guys :D
That is awesome.
Cool! this might be a stupid question, but what happens when you drive? can you easily remove it? or once retracted it just sits there?
when I drive from the shade I notice some vibrations on the awning but I don't feel it at all. I drive on high way up to 105-110 mph with out any problems.
it is very easy to remove it, just remove 4 bolt (2 for each mount) the bolts that attached the large peace with the small peace.
Other Awning Options
ARB Touring Awning 2500mm #ARB108US is hand operated roll up awning, and it can withstand mild wind if strap tied well, generally it is okay.
check the following link:
http://www.sierraexpeditions.com/index.php?l=product_list&c=129
I used to love it before FOXWING Awning was invented. and now I wish for one of FOXWING Awning
FOXWING Awning
watch these videos
http://www.rhinorack.com/ShowVideoLibrary.aspx?oType=3&linkid=358
Also there is the famous South African Eezi-Awn 2000 series (self retractable awning)
you can buy them in USA from http://www.sierraexpeditions.com
and all of them could be fixed with the same method
