Vette76
- March 8, 2011
- Maine
- 02 XLT 4.0L & 97 XLT 5.0L
Unfortunately, when I got everything back together after replacing the front primary timing chain and the left cassette on my 02 4.0L I had this weird suspicion that I wasn't done yet. Even after replacing the right camshaft (another story) I thought I was ready to time the camshafts and call it good.
For some reason, and I don't know why I didn't even look at doing this to begin with, I stuck my fingers down inside the back side of the right cylinder head and gently poked around to make sure there was no damage to the back timing chain cassette. To my surprise, the rear cassette had been broken all along!! I had been absolutely, unbelieveably careful to not even create tension on the back chain. To then find out it was broken in half to begin with just about set me off!! Now I'm into this thing all the way. The engines coming out baby!
After reading all the posts, I can't tell if it is necessary to undo the rear jack shaft sprocket bolt just to simply replace the rear timing cassette. It looks like a near impossible job (from the pictures) to replace the rear jackshaft sprocket and chain, though.
I also believe that you DO NOT have to take off the head to replace the rear timing chain cassette.
Do I have both of these things right?
Thanks guys! I promise that when I have this whole thing back together, I have learned a few tips along the way that will be helpful for the next poor chap who has to go through this
