#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Fuel gauge issues
Reply
Thread Tools
Old 10-12-2011, 07:42 PM   #1
JamiesTSI
Johnstown, PA
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Fuel gauge issues
Hello everyone, first time poster. I have a 2004 sport trac with a fuel gauge problem.
A few months ago the gauge started acting funny by reading correctly then reading empty. It did this for a few days then all it would read is empty with low fuel being indicated.
I replaced the fuel pump assembly today and the gauge still reads empty. I did notice that when I pull the #25 fuse it seems to reset the instrument cluster. It actually looks like the gauge needle moves ever so slightly above the E mark. After I shut the truck off then back on the needle will rest below the E mark.
Anybody have any thoughts or suggestions? Thanks in advance.
JamiesTSI is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-12-2011, 09:11 PM   #2
brianwsnc
Winston Salem, NC
2004 Sport Trac Adrenlin
Vehicle Specs
Quoted: 0 Post(s)
Keep it filled up...
haha.. just kidding of course..
Looks like you did the most logical thing by replacing the sending unit... There is a way to test before replacing..
take the lead wire off the sending unit and ground it... the gauge should go to full...if it doesn't .. the gauge is bad...
brianwsnc is offline   Reply With Quote
Old 10-13-2011, 04:02 AM   #3
600remguy
SW Ontario
'04 SportTrac XLT 4Paw
Vehicle Specs
Quoted: 5 Post(s)
Is yours a flex-fuel? Sounds like mine when I had a slight problem with the wiring harness plug directly behind the interior fuse panel. Bumping this plug set things straight, although my plug had been monkeyed with. Check all your wiring and plugs. Testing for standard and flex-fuel gauges is different! Pulling the fuse on mine did exactly what yours did for you.
600remguy is offline   Reply With Quote
Old 10-13-2011, 06:21 AM   #4
JamiesTSI
Johnstown, PA
2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes, it is a flex fuel truck. I'll have to give the plug a wiggle. Thanks for the idea.
I was under the impression that the additives they are putting in the fuel where putting deposits on the float assembly causing it to tread inaccurate. I guess in my case that was not the case.
I think I read somewhere on the internet that the cluster gauge could also be bad. Also some kind of card that plugs in the back of the cluster gauge that controls slosh.
I noticed this morning the needle was resting on the red part, when I started the truck it actually moved belowe the red mark. Not sure what it means just thought I'd throw that out there to.
Anybody else have any ideas?
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Computers, Sensors, MILs, CELs, PCM Inputs and More ExplorerDMB Explorer, Ranger - Computers, Chips, Tuning 58 03-20-2011 05:12 PM
Gas gauge update slow burketd Stock 2002 - 2005 Explorers 47 04-24-2008 02:13 PM
Fuel Gauge & Fuel Economy Sensor Calibration? Iron-Mike Stock 1995 - 2001 Explorers 4 03-30-2007 04:43 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
