- September 6, 2006
- South Central PA
- 1994 Explorer
- Callsign
- yosty
I just swapped in the clutch and brake pedals from a 1990 ford ranger into my 1994 ford explorer. They swapped easily and I did not remove the dash to install it in my explorer.
Remove the e-clip
Slide the clutch pedal over
The clutch and brake pedals removed that will be swapped over
Here is how you remove the auto pedal. It is easier to show how it is done on the steering column support that I had out of the 90 ranger than it would have been trying to take pictures from underneath the dash out of my 94 explorer
Complete assembly
Remove clip
Remove white bushing on brake switch
Note the black bushing in the switch
Another white bushing
Remove e-clip on the right side
Remove the e-clip
Complete assembly
Remove clip
