ahodges
- August 31, 2009
- Millbury, OH
- 1996 XLT - 347 S/C
So the time has come to make my own 5.0 build thread. I already have the donor truck (its a 97 AWD Mounty) that I got a real good price. The plan is to put the 5.0 into my 96 Explorer and then transfer the 4.0 and its driveline into the Mounty. I have already found answers to most of my questions regarding the swap including all the 4406 transfercase swap info.
One question left un answer though is that the brake booster in the Mounty has a sticker that says 5.0l on it. Is that different than then one in my 4.0 OHV Explorer?
I have pictures posted of the Mounty in the last post on my 96 registery. I'll be following up with more pictures too.
Here is the link to my Explorer Registery..
Andrew's 1996 Explorer XLT
EDIT:
Main Parts List of finished product -
- Ford Racing 302 BOSS Block (Stroked to 347)
- Eagle rotating assembly
- AFR 185 heads (72cc)
- Explorer Express Supercharger kit (Eaton M90 pushing 7psi boost)
- COMP CAMS .540 intake lift .560 exhaust lift @ 280 and 283 duration
- Torque Monster Headers
- 75mm BBK Throttle Body
- 90mm SCT MAF
- 60lb Injectors
- BW4406 TOD transfercase
- Sport gas tank
- 2015 F150 front drive shaft (CV style) - custom adapted pinion flange and T-case adaptor
- Custom rear drive shaft
- Custom Moser 9" rear axle w/ Eaton Truetrac diff
- Caltracs Traction Bars
Dynoed RWHP = 350, Dynoed Torque = 385
If anyone has any questions I'd be happy to help as I'm sure I left something out along the way!
EDIT:
- 90mm SCT MAF
- 60lb Injectors
- Sport gas tank
