Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Street Truck & Performance Forums > Street Trucks > Need for Speed!
Notices
Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move!
Another OHV M90 build
Reply
Thread Tools
Old 02-10-2012, 02:22 PM   #1
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
00 Explorer XLT 4.0 OHV
Vehicle Specs
(Original Poster)
2000 OHV + rpcaster + henson performance = another supercharged 4.0 ohv Explorer
I have goodies from James already (New MAF, 36lb injectors, wideband O2 for tuning)
Here's what came from Ron (Also a fuel pressure gauge and boost/vacuum gauge)
__________________
Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it.
Dono is offline   Reply With Quote
Old 02-10-2012, 02:26 PM   #2
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
My question is around what plugs in where (Specifically, the iac). Where? The iac has 2 holes in it. Whats that about? How do I make it work on the new intake?
Also, the EGR. Can I just get a second egr tube, and use the side with the two bolt holes to attach to the intake?
This is little stuff, but important.
I want to maintain my egr since I'm not inter-cooling. I'll need all the help I can get at lowering combustion chamber temps.
Let the fun begin!
__________________
Old 02-10-2012, 04:29 PM   #3
phix-
96.5
Vehicle Specs
Ok, so I can chime in about the IAC. I have a instacharger setup and I figured I could just hook it up any way I want. WRONG! there is a valve that controls the top and bottom as in and out (read:vaccum, it may not be but to me it seemed like a logical label). I extended my wires and replaced with a new one and the truck seemed happier. As for egr, I have modified tube that bolts up to egr. Oh oh.. before I forget, you might want to relocate your coilpacks over the years of owning this kit I had noticed that the hotter I ran the blower the more it would cause mis-fires.
phix- is offline   Reply With Quote
Old 02-10-2012, 04:45 PM   #4
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
I understand pure vacuum needs to be before the supercharger. I also understand Boost/vacuum gauge needs to be after the supercharger.
I know the iac needs to be before the supercharger, but can I just adapt it to the intake and away I go, with both iac holes going to exactly the same spot? This part truly has me scratching my head. So, can you explain further on what you did with the iac? Im still not getting it.
I can add a port before the supercharger for the pcv valve line, and I think I see how to do the egr.
Thanks for the tip on the coil pack. I'll have to make sure I fabricate some kind of a mount well out of the way of the heat.
__________________
Old 02-10-2012, 04:56 PM   #5
phix-
96.5
Vehicle Specs
Going out to take a picture, but I have a bracket.
Old 02-10-2012, 05:19 PM   #6
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
the holes have to be on each side of the tb butterfly.it lets air around the butterfly to adjust your idle.i would send rp an email,also what tb does it use?i know that manifold is for the sohc so i figure it uses a sohc tb
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is offline   Reply With Quote
Old 02-10-2012, 06:11 PM   #7
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
The tb holes are made for sohc. I'm hoping the mounting holes allign for the ohv, otherwise Ill try to make an adapter. I want to stick with the tb I have to avoid cable issues for throttle and cruise.
It does make sense on the iac that one hole goes before butterfly, and 1 after. I'm sure I can make an adapter plate with 2 hoses on it. That would make routing fairly easy.
__________________
Old 02-10-2012, 06:22 PM   #8
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Ohv tb will not fit plus the sohc is better,i cant remember how sihc tb works,the aic may be made into it.i think it was the 4.6 tb will fit on the sohc and pretty sure its made into it.also sohc and 4.6 make larger tb witch you will want.google the sohc tb and see if its made in or google the 4.6 tb on a sohc and see if it fits or is built in.
__________________
Old 02-10-2012, 06:29 PM   #9
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
here is mine,its on the bottom,no tubes pipes or anything nice and clean.plus 5.0 tb are like a dime a dozen and use all the same stuff as the 4.0
__________________
Old 02-10-2012, 06:50 PM   #10
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
That looks awesome! Looks like my existong cables will work. What's the cross section measurement on the bolt holes for mounting? I'm not home to measure mine now, but that tb sounds like it will solve my issue, for sure!
__________________
Old 02-10-2012, 07:31 PM   #11
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
No pic Phix? Its all learning for me. I'm always interested in how guys do things.
__________________
Old 02-10-2012, 11:30 PM   #12
rocket 5979
Resident Gearhead
Lake Villa, Illinois
rocket 5979's Avatar
'03 XLT 4.6
Vehicle Specs
Quote:
The 4.6 TB does not have the IAC ports built into it. The 4.6's use a different IAC where it has one port that is on the flange side of the IAC that mounted to the intake manifold and then on the other side of the IAC housing is a hose barb nipple that routes a hose to the intake tube post MAFS/pre-TB. This is how the IAC airflow routing happens in the 4.6 SOHC's.
Dono if you don't end up being able to use the 5.0 TB for some reason then let me know if you may need some recommendations on some other IAC options. There are a few different styles of IAC out there that may allow you some flexibility if you end up needing it.
__________________
2003 4.6 V8 XLT Black Explorer, Kenne Bell 2.2 Supercharger, VT Billet bottom end, MPH 2.5 Heads, Blower cams, A1000 custom fuel system, and on and on...
2009 6.6 V8 Pontiac G8 GT, Twin Turbo, 402ci, Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, new fuel system on its way...Shooting for 750+rwhp and easy middle 10's.
2002 4.0 V6 Explorer Sport, CAI, Gibson Exhaust...
2005 3.9 V8 Lincoln LS, KBX Performance Garrett Turbo System...Sold...
rocket 5979 is offline   Reply With Quote
Old 02-10-2012, 11:39 PM   #13
rhauf
Ca
rhauf's Avatar
'93 and '91 explorer
Vehicle Specs
Do i understand correctly, that there are parts available to supercharge an OHV?
is there a kit (or adapter plates and parts list etc) to supercharge a first gen 4.0?
__________________
Check out my Youtube page, many explorer and 4wheelin' videos
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 02-10-2012, 11:45 PM   #14
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
This is a secret! !shhh
__________________
Old 02-10-2012, 11:50 PM   #15
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
Yes, this is the beginning of a 2nd gen ohv m90 install. JD has a thread going on his 1st gen install. JDs is far more radical.
Thanks Rocket, Ill go to the yard and see what I can find. Sunday is suposed to be a bit warmer. I was just looking at the pics JD posted, and couldnt help but notice it looked warm there. I should be able to find a 5.0 tb somewhere here, I just needed to understand how an iac works to know whats required. Makes perfect sense to me now.
__________________
Old 02-10-2012, 11:57 PM   #16
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Question
The 5.0 is way bigger,wouldnt fit with out a major adaptor plate.before you go there i would find out what he uses for iac.pretty sure from the org pics he had a spacer that has the iac built in,cant find our original thread.but either way i would find out if the 4.6 fits,way more aftermarket things.
__________________
Old 02-11-2012, 12:14 AM   #17
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
Im going to be on my own from here on in.
Ron supplied the basics, and didnt pretend to sell a kit. If I need to, Ill make an adapter. Its just a matter of the best route to go, giving the cleanest, most reliable result.
__________________
Old 02-11-2012, 12:20 AM   #18
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Oo welcome to the months of research and stress!!custom fab work is the most hair pulling but funnest stuff for me
__________________
Old 02-11-2012, 03:01 AM   #19
rocket 5979
Resident Gearhead
'03 XLT 4.6
Vehicle Specs
Shoot, custom fab work relaxes me and in many cases I prefer it. That way I can manufacture items under my own design constraints and requirements versus having to operate under someone else's idea of how something should be built. It may take a little longer but I know it is more likely to be done right in the end. I am not saying I prefer to reinvent the wheel on everything, but on certain things I do.
__________________
Old 02-11-2012, 09:52 AM   #20
Dono
Supercharged OHV
Winnipeg, Manitoba
Dono's Avatar
Vehicle Specs
(Original Poster)
Im pretty confident that with you guys helping me with whats required, I can do the rest. Ron gave me a great start on the required parts that I couldnt do myself.
i think once I get the iac sorted out (hopefully the 5.0 tb will do the trick), tap in the pcv line to the intake, and get egr sorted out ill be there.
One of the sticking points is finding a local supply source for these different nipples and screws. Bolt supply houses dont even seem to have this stuff.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
1999 Ford Explorer 4.0 SOHC swap to 4.0 OHV Pckid212 Stock 1995 - 2001 Explorers 33 02-06-2013 03:12 PM
Brandon's mild 4.0 OHV build Brandon96 Need for Speed! 633 01-23-2012 01:59 AM
98 EGR tube (4.0 V6 OHV) brukshut Stock 1995 - 2001 Explorers 8 10-18-2010 06:49 PM
Eddie Bauer Question erixon Stock 1995 - 2001 Explorers 9 09-08-2009 11:43 PM
Tranny code between 95 ohv and 97 ohv. jasonphan Stock 1995 - 2001 Explorers 5 08-17-2009 11:06 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
