Ohv tb will not fit plus the sohc is better,i cant remember how sihc tb works,the aic may be made into it.i think it was the 4.6 tb will fit on the sohc and pretty sure its made into it.also sohc and 4.6 make larger tb witch you will want.google the sohc tb and see if its made in or google the 4.6 tb on a sohc and see if it fits or is built in.
Do i understand correctly, that there are parts available to supercharge an OHV?
is there a kit (or adapter plates and parts list etc) to supercharge a first gen 4.0?
Yes, this is the beginning of a 2nd gen ohv m90 install. JD has a thread going on his 1st gen install. JDs is far more radical.
Thanks Rocket, Ill go to the yard and see what I can find. Sunday is suposed to be a bit warmer. I was just looking at the pics JD posted, and couldnt help but notice it looked warm there. I should be able to find a 5.0 tb somewhere here, I just needed to understand how an iac works to know whats required. Makes perfect sense to me now.
Im going to be on my own from here on in.
Ron supplied the basics, and didnt pretend to sell a kit. If I need to, Ill make an adapter. Its just a matter of the best route to go, giving the cleanest, most reliable result.
custom fab work is the most hair pulling
