Out of time?
Hello all,
Just went out the other day to start my truck and it wont start.Battery is fine,fuel rail has pressure plugs have spark has compression but not great but it does have 214k on it front timing chain is okay and is moving but of course i cant see the back one and know of no way to check it please help!
Thanks
Mike Gaebelein
You will know if your rear guide is broken because the passenger side camshaft's timing will be over 10 degrees retarded. You may not hear any noise, however this will cause a poor and shakey idle. The cat on the passenger side will smoke under heavy load (such as driving in sand, driving up a mountain or towing) and you will notice some performance degredation. Some times when you turn the engine off, listen closly and you will hear a "hiss" into the exhaust just as the engine stops turning. Once you give her a proper compression test, all the cylinders on the passenger side will have a lower compression reading than the drivers side.
If the guide is broken and you do not want to remove the engine, you can simply retime the passenger side camshaft as a temporary measure be removing the timing cover only. Vice grips on the camshaft work just as well if not better then the flimsy timing tools avaliable from Ford.
If the guide is indeed broken I suggest you remove the lower oil pan, 10x10mm bolts, and remove the broken pieces as they will eventually work there way into the oil pickup giving you oil pressure issues at higher RPM's, you don't want that.
If you would like more information on retiming the camshaft to suit the rest of your engine simply say so and I will be more then happy to help out.
Contrary to popular belief the SOHC is a strong and resiliant engine. My truck has done well over 10,000 miles with a broken guide and the camshaft retimed to suit, and I drive her hard!
Good luck and happy exploring...
