Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
91 Explorer 4x4
Reply
Thread Tools
Old 05-28-2012, 10:36 PM   #1
justus124
Louisiana
1991 Ford Explorer 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
91 Explorer 4x4
I have a 91 Ford Explorer 4x4 that when and if it starts it doesnt want to stay running I have replaced the fuel filter, fuel pump, fuel pressure regulator, mass air flow sensor, idle air control valve, throttle position sensor, computer brain. When it does start it idles rough and dont stay running for long. There are no computer codes stored in the computer. While trying to start it the entire top end of the motor (all the sensors) are hot to the touch. The truck dont run hot just the sensors get hot. any help would be greatly apriciated
justus124 is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-29-2012, 03:47 PM   #2
arco777
arco777's Avatar
1994 Explorer 2dr 4x4
Vehicle Specs
Quoted: 99 Post(s)
What led up to the failure? Did it gradually get worse or fail all at once?
You stated there are no stored (CM) codes, but are there any KOEO or KOER codes?
I would recommend not throwing parts at the problem - that will just cause frustration. Sometimes it is a simple fix or even something you did yourself.
Check that your plug wires are going to the right places. You can also check for arcing by looking under the hood at night - in the dark you can see arcs with the engine running if there's ignition wire damage. Arcs will cause all kinds of problems.
A possibility - Sounds like the computer has no idea where the engine is at - perhaps it is not reading timing properly. Two main sensors for this are CKP (crank position sensor, at harmonic balancer and easy to change), and the more notorious CMP/CPS (cam position sensor). The cam position sensor unfortunately is a pain to remove; Ford service manual says to remove engine to get at it, but there may be another way if you search the forum.
__________________
-1994 Explorer 2DR 4x4 - Explorer Express X-Spec swaybars/shocks, BBK throttle body, Dynomax exhaust, misc trans upgrades.
-2008 Mustang GT Bullitt #5560 - Brenspeed tuned
-1995 fullsize Bronco 5.8L - intake, exhaust and trans mods, cosmetic mods.
arco777 is offline   Reply With Quote
Old 05-30-2012, 12:49 AM   #3
justus124
Louisiana
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
We didnt throw parts at it. The parts we replaced were coded repairs that needed to be repaired. If there are no codes then there are no codes wheter the engine is running or not. I have no codes period.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
95 2x4 Ranger 5 speed into a 91 Explorer 4x4? tweakedlogic Explorer & Ranger Transmissions, Transfer Cases, & Differentials 4 01-26-2010 09:59 AM
91 ford explorer XLT 4x4 ERIC BARTOK New Member Introductions 2 03-29-2009 07:15 PM
Need transmission for a 91 4x4 explorer lpmorgan Explorer & Ranger Transmissions, Transfer Cases, & Differentials 8 05-09-2006 01:11 AM
91 Explorer Eddie Bauer no 4x4 no OD DJ Koz Explorer & Ranger Transmissions, Transfer Cases, & Differentials 11 02-24-2006 05:09 PM
AC Oil Capacity '91 Ford Explorer 4x4 Ross Havens Under the Hood 1 08-02-2000 10:40 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
