M50D popping out of fifth | Ford Explorer Forums
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
I've recently completed a manual transmission swap with a junk yard(emphasis on the junk part) trans. Gears 1-4 and reverse function as I would expect them to. Fifth is a different story however. When power is applied you can see the shifter moving back and it will eventually pop out of gear. I have tried adjusting the bolt on the drivers side of the trans and it might have helped some as I can sometimes run in fifth now but it will still randomly pop out.
It will be a little while before I pull the transmission again. I'm not looking forward to that at all but it has to be done. I am looking at what the issue may be. Fifth gear definitely feels different when selecting. All other gears have a noticeable click when engaged, fifth just needs to slide in with no click.
Any help would be greatly appreciated.
Just an addition, there was no fluid in the box when I got it so I don't know the condition but there was a good amount of build up on the magnet when I pulled it.
If the top of the unit was greasy and it looked like it had been leaking for a long time there is a good chance it lost all it's oil through the rubber shift rail plugs. If that's the case, it's trashed. :(
It was rather dirty but the plugs were RTVd in to seal them up. Looks like I will be pulling it to check on it. If not it will be a $100 core for a rebuilt one. :(
