#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How To Change Crank Shaft Position Sensor -- 97 5.0
Reply
Thread Tools
Old 08-17-2012, 12:51 AM   #1
mbruffey
MN, MN
1997 5.0 AWD Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Here's how I did it. My 97 5.0 has the tow package / tranny cooler which is kind of in the way.
(0) Prepare to get really gicky.
(1) Remove the serpentine belt (15mm on the tensioner)
(2) Remove the tensioner (2 @ 10mm). Go ahead; just do it now.
(3) Clean all the glop off the crank sensor that so you can actually see it. Yeah, you do have one . . . . It's more or less right behind the tensioner, which you just removed.
(4) Remove crank sensor bolts (2 @ 5/16"). They're right snug. I had to go to a 6-sided socket to prevent stripping the head of one. You can get them from beneath, but you have to go by feel for the upper, since you can't really see it. Just be sure to get a good bite, or, as I mentioned, you might strip the head.
(5) Now, from the top side, work the sensor wire retainer off the bolt and work the sensor up to where you can carefully disconnect, inspect, and clean it.
Slap a little silicone grease on the connector and reverse the process. Might want a bit of Threadlok Blue on the bolts, too.
**The most commonly available replacement (for the 5.0) seems to be made by Standard (PC325, or PC350[w/bracket]). Pics online look like they have Ford part numbers, so I'm guessing that Standard is actually the OEM for the part. I'd love to have confirmation of that . . . .
mbruffey
kw: CKP, crankshaft position sensor, crank position sensor
mbruffey is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-25-2012, 11:48 PM   #2
kdspapa
Southern Oregon -Grants Pass
kdspapa's Avatar
99 Mountaineer AWD 5.0L
Vehicle Specs
Quoted: 2 Post(s)
Replacing crankshaft sensor 99 Mounty 5.0
I just replaced mine by just removing the serpentine belt and feeling my way around. It turned out all right but if I had to do it again, I think I would pull the fan shroud and fan/clutch assembly first. That would give you plenty of room to work and room to inspect and cleanup everything up front. Live and learn!
kdspapa is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to change radiator 5.0 V8 jamesrangitsch Under the Hood 10 06-05-2010 01:43 PM
99 5.0 cam position sensor.. 2 or 3 prong? lastlapracer302 Under the Hood 1 07-03-2009 01:22 AM
Balance shaft position cleudard01 Modified 1995-2001 Explorers 0 07-02-2008 12:30 PM
Cam Shaft Position sensor chirp Mikeri Stock 1995 - 2001 Explorers 18 08-11-2007 04:53 PM
5.0 cam sensor body shaft play? lowflyingbird Modified 1995-2001 Explorers 9 05-03-2007 12:48 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
