#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
door ajar light stays on
Reply
Thread Tools
Old 11-11-2012, 12:53 PM   #1
Daver
Vancouver,Washington
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2000 Explorer XLT with 200,000 miles on it. Runs perfect, doesn't leak a drop. Life is good. Problem is, recently when I put the vehocle in gear, after taking my foot off the brake, the doors don't automatically lock. Doesn't happen every time, just some of the time. The door ajar light on the dash will light up. Once, when I manually locked all of the doors, the ajar light went off. Now it stays on and also the interior light stays on after I exit the vehicle, then extinguishes itself after it times out. Needless to say, all the doors, the rear hatch and the rear window are securely closed. Any ideas on what the problem could be would be appreciated.
Daver is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-11-2012, 03:10 PM   #2
koda2000
Georgia
2001 Explorer EB 5.0L
Vehicle Specs
Quoted: 1076 Post(s)
very common problem. all five doors have switches attached to their latch mechs. sometimes these switches will stick or break, this causes to DOOR AJAR light and interior lights to stay on. it usually turns out to be the driver's door switch (because it gets the most use) that causes the problem. sometimes spraying the switch with wd40 will get it working again and sometimes you need to replace it. with 200K you may need to replace it. at any rate, i'd start with the driver's door. pretty easy job and there are many posts on this subject (some with great pictures) showing how to o it.
__________________
I reject your reality & substitute my own...
2001 Explorer Eddie Bauer 5.0L V8 2WD
2000 Mountaineer 5.0L 2WD/2000 Expl XLT 5.0L 2WD
2000 Mountaineer 5.0L V8 AWD, 2001 Expl Sport Trac
2001 Explorer XLT 4.0L SOHC V6 auto 2WD (RIP 5/13)
1997 Explorer Sport 4.0L SOHC V6 auto 2WD
koda2000 is offline   Reply With Quote
Old 11-11-2012, 03:28 PM   #3
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Vehicle Specs
Quoted: 455 Post(s)
Silicon spray into the door mechanism (strike) to lubricate it again.
SoNic67 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Door ajar light stays on?? davis911s Stock 1995 - 2001 Explorers 1 08-23-2010 07:39 PM
Check Engine Light stays on 1996 Explorer peterson50 Stock 1995 - 2001 Explorers 3 09-07-2009 09:57 PM
94 explorer brake light stays on angelbaby4078 Stock 1991 - 1994 Explorers 12 12-16-2007 06:50 PM
1999 ranger abs light stays on all the time wdpropes Ford Ranger - Mazda B-Series Forum 2 02-19-2007 01:10 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
