#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
squeaky suspension
Reply
Thread Tools
Old 11-18-2012, 09:00 AM   #1
Greatlaker
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
squeaky suspension
My 05 4x4 Ex has 125,000 miles on it and has a squeaky front end....pretty much just on the trails, its not that bad but it is annoying. Seems like a combination of the control arm bushings, etc. Besides replacing everything, are there any options to quiet it down? I'm sure others have had this happen... Thanks! Rob
Greatlaker is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-18-2012, 10:58 AM   #2
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
Quote:
Probably the swaybar bushings that are mounted in those U-shaped brackets on the underside of the frame. You can take them off, clean the gunk out, and put a thick layer of marine grease on the inside surfaces and that will keep them quiet for a good while.
Ronin8002 is offline   Reply With Quote
Old 11-18-2012, 11:05 AM   #3
Flag Gibby
Flagstaff, AZ
2006 Mountaineer AWD
Vehicle Specs
Quoted: 170 Post(s)
It may be squeaky because the factory rubber bushings are dried out and worn. Fresh bushings will take care of the front end noise, just be careful what kit you get because some of the heavy duty off road kits can cause a lot of front end noise too. You could also try squirting some motor oil on the bushings to see if it helps knock some of the noise down.
From the Offroad Design web site refering to rear shackles but still applicable:
"A often misunderstood fact is that factory rubber bushings offer less flexibility than aftermarket urethane. Most people have heard or read otherwise but rubber does not work as well in the real world. The reason is that the factory rubber bonds the inner sleeve to the outer sleeve and spring. Since they're bonded together, the inner sleeve can't twist relative to the spring. When you tighten your shackle and spring bolts the inner sleeve is locked solid to the vehicle so the suspension is limited by the rubbers inability to rotate. Urethane bushings on the other hand, can rotate freely around the inner sleeve and will not bind up the suspension."
Edit: Sorry for duplicity, Ronin posted as I was formulating my response.
__________________
"my muddled brain tells me one thing but the facts state something else completely different"
2006 Mountaineer AWD 4.0L with factory tow, EBC USR rotors with green stuff pads, K&N drop in, flowmaster cat-back, and superchips 1865
Flag Gibby is offline   Reply With Quote
Old 11-18-2012, 11:17 AM   #4
Ronin8002
Virginia
2008 XLT Ironman
Vehicle Specs
Quoted: 125 Post(s)
On that note, the swaybar bushings I mentioned are made of urethane, but when the lube that's in them gets dried up or washed away over time, the bushings squeak when the swaybar cycles up and down with suspension movement.
Old 11-18-2012, 07:09 PM   #5
Greatlaker
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys! Yep, it was the sway bar bushings...I spray lubed the heck out of them for now and they are quiet again. Probably will replace them at some point, but seems ok for now. I appreciate the replies. ----Rob
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Somebody School Me on Link Suspension Design MountaineerGreen Explorer - Ranger Shocks, Suspensions, Lift Kits 12 08-18-2008 11:05 PM
Want 6" Suspension lift for 98 Explorer! King$nake Explorer - Ranger Shocks, Suspensions, Lift Kits 40 07-05-2008 10:41 PM
suspension kit for a 2001 Explorer Sport Jsmith180601 Explorer - Ranger Shocks, Suspensions, Lift Kits 15 04-30-2008 06:22 PM
suspension problems!! need advice in a hurry! toddious Explorer - Ranger Shocks, Suspensions, Lift Kits 7 02-27-2004 02:29 AM
Adjustable Lowering Suspension For 02-04 Explorer 4-Doors Coming Soon! JOHN V. Seriously Lowered Explorer - Ranger Suspension Tech 8 01-29-2004 01:47 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
